Old Nov 01, 2010, 08:08 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by pattypilot View Post
Well that oneís not shabby either. Iím going to try my hand at it. You guys are really turning out some great looking ships. Iím interested in this Lozenge pattern printing that UNGN has been talking about. So many models So little time. Jim
I still need to work on it. When I matched it to the wing, the B/P wings are different from the Models... different rib count, different wing tip, so I'm going to make it match the models wings, even if it isn't quite scale.
UNGN is offline Find More Posts by UNGN
Old Nov 01, 2010, 08:24 PM
pattypilot is offline
Find More Posts by pattypilot
No dear, That isn't New!
pattypilot's Avatar
United States, IL, Urbana
Joined Nov 2006
That makes since! It will almost have to match the model or getting it all lined up would be a bugger. Have you done much of this decal printing? I have been looking at a laser printer, but dang the toner cartridges are pretty steep. I still think this is going to be my next major purchase, just endless on what you could make. Jim
pattypilot is offline Find More Posts by pattypilot
TurnerVoss is offline
Find More Posts by TurnerVoss
NC
Joined Nov 2008
I was going to do this for the lower wing: Print this lozenge and cut to fit, then scale the cross and print on a white decal sheet.
TurnerVoss is offline Find More Posts by TurnerVoss
Last edited by TurnerVoss; Nov 07, 2010 at 06:08 PM. Reason: Fixed lozenge pattern
Old Nov 01, 2010, 08:29 PM
pattypilot's Avatar
Joined Nov 2006
I seen a set of wings, that looked amazing. I can't say much about it. I don't want to spoil his debut. It's coming though.
Old Nov 01, 2010, 08:35 PM
NC
Joined Nov 2008
Originally Posted by eli5539 View Post
Thought I would post these here
Attachment 3570383
Nice! Did you paint over top of the existing or soak the foam in alcohol?
Old Nov 01, 2010, 09:30 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Here's a word version of Wing lozenge pattern that was made from a DVa blueprint, just not this DVa's blueprint. My PDF is slightly scaling it, though I said no scaling.
The Wingtip would need to be trimmed for it to work.
Lozenge/Cross pattern is based on the Smithsonian plane, with the colors roughed from Replica DVa's.
Old Nov 01, 2010, 09:33 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The Lozenge patterns run Leading edge to trailing edge, with with adjacent sheets flipped 180 degrees. Only Fuselages and Ailerons had the pattern running length wise with the sheet.
Old Nov 02, 2010, 01:23 AM
speedy01 is online now
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Jim,
Don't know if you have Sam's Club up there, but here in FL they are selling the HP CP1215 Color Laserjet for $150 - pretty amazing price. The output on decal paper is outstanding! You just have to smile and swallow the cartridge costs - be happy!
Gene K
speedy01 is online now Find More Posts by speedy01
Old Nov 02, 2010, 04:45 AM
eli5539 is online now
Find More Posts by eli5539
eli5539's Avatar
Western New York
Joined Dec 2007
One I removed all the paint and the other I just painted over. From my stand point I did not notice much of a change in flight time.
eli5539 is online now Find More Posts by eli5539
Old Nov 02, 2010, 05:32 AM
pattypilot's Avatar
Joined Nov 2006
Thanks Gene, I'll go look tonight. Jim
Old Nov 02, 2010, 07:35 AM
D Johnson is offline
Find More Posts by D Johnson
Just some guy
D Johnson's Avatar
Joined Aug 2006
Look into toner costs and what you get for your money. Someone told me to do so and I ended up paying a bit more for a Brother but my long term cost shrank a ton.
DJ
D Johnson is offline Find More Posts by D Johnson
Old Nov 02, 2010, 08:11 AM
pattypilot's Avatar
Joined Nov 2006
Thanks DJ, I've been looking around! You like the Brother? Sean's an HP man, How do you get along? You still up for the trade we talked about? Jim
Old Nov 02, 2010, 08:30 AM
Gulf Breeze, FL
Joined Jul 2006
Your cost shrank using the Brother compared to what? Another laser, inkjet,...?
Here's a link
to an older article (which doesn't compare specific models or color/mono) that says, in part:
QUOTE
An HP laser printer with an estimated machine cost of $400, combined with a $115 toner cartridge, yields 8000 pages. Printing 40,000 pages costs you $400 plus $460 for the ink for a total of $860. A Brother 1440 laser printer works out at about $930 for the same number of pages. That comes to around two cents a page, or eight times less than an inkjet printer.
UNQUOTE
I never owned a Brother machine, but it certainly doesn't appear in any comparison of "Top Ten xxxs" that I've seen). On the other hand, I've always had great results with HP printers especially the bargain CP1215 that I picked up only two weeks ago (limited use, but WOW so far).
Gene K
Old Nov 02, 2010, 08:31 AM
Just some guy
D Johnson's Avatar
Joined Aug 2006
Sean seems to like the decals I've been feeding him. Yes we are.
DJ
Old Nov 02, 2010, 09:16 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
DJ
Dave,
are you using Decal paper? Are there any issues with shinkage distorting the wings?
Sold Flyzone Albatros RX brick and Transmitter Tim Wolff Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 05, 2010 08:24 AM
Sold Flyzone Albatros 2.4GHz TX - RX - Motor/Gbox - Battery + hauntfreaks Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Oct 04, 2010 03:35 PM
Sold Flyzone Albatros RX/Servos and TX - $35 Shipped UNGN Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Sep 28, 2010 08:09 AM
Found Trade my Flyzone Playmate for your Flyzone Albatros Flyboy70 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Sep 07, 2010 05:25 PM
