Old Dec 30, 2012, 09:41 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by kostuk View Post
Hi,
Is the Naptha lighter fluid also used to remove the glue holding the gear box/motor in place or do you need to cut it out?
Do you use the naptha for removing the struts and landgear?
RAy
The motor need to be cut out.
Very little holds plastic to foam. trace around the plastic with a sharp exacto and put apart.
UNGN is offline Find More Posts by UNGN
Old Dec 30, 2012, 10:05 AM
Tim Wolff is online now
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Remove the interplane struts from the top wing leaving the bottom intact. Removing the bottom may take a little paint off the bottom wing.
Tim Wolff is online now Find More Posts by Tim Wolff
Old Dec 30, 2012, 02:43 PM
beetyii is offline
Find More Posts by beetyii
Make the best of all you have
beetyii's Avatar
Essen/Germany
Joined Dec 2006
Make a clean cut under the elevator ...
Rolf
beetyii is offline Find More Posts by beetyii
Old Dec 30, 2012, 03:47 PM
kostuk is online now
Find More Posts by kostuk
Joined Nov 2003
Thanks Rolf and Tim!
The descriptions helps a lot.
One final(?) question where is a good place to get the UHO POR glue?
Ray
kostuk is online now Find More Posts by kostuk
Old Dec 30, 2012, 05:10 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
I use a little drop of 5 minute epoxy on the lower wing strut pocket area.
As the epoxy sets up, I press the strut into the epoxy to form a glue pocket, then pull the strut out and wipe off an epoxy that sticks to the plastic.
One the Epoxy is fully hard, i use UHU por to attach the lower strut to this pocket. It can be pulled apart hundreds of times with no damage to the wings, and there is only one glue joint per wing, instead of 2 if you make the uppers removable.
The pocket ensures the wing stuts are properly aligned, every time.
Old Dec 30, 2012, 09:58 PM
Joined Nov 2003
thanks UNGN!
I will use the epoxy mold idea - really nice!
How do you make the upper attachments removable? It looks like Rolf pulled his apart.
Also where is a good place to buy the UHU por glue or is it similar or just as good as the canopy glue?
Ray
Old Dec 30, 2012, 11:13 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
thanks UNGN!
Ray
I keep the upper joints attached to the upper wing.
I buy UHU when I visit Germany. Some European sellers may ship to the US.
You Can also buy a similar glue like Beacon's foam tack
Old Dec 31, 2012, 01:40 PM
Joined Nov 2003
Thanks UNGN.
What lubricant should be used on the gearbox?
Ray
Old Dec 31, 2012, 04:33 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Thanks UNGN.
Ray
None is fine. lubricant isn't the problem... its bad geear mesh from an 8 tooth pinion. The Best thing to do when the originals go bad is to swap in an SE5a motor/Gearbox (4th gen):
Gearbox: FLZA6319
Motor/Pinion: FLZA6318
Old Dec 31, 2012, 06:49 PM
Joined Nov 2003
Thanks UNGN,
I just got one in the mail!
Ray
Old Jan 02, 2013, 04:22 PM
IfIHadWings is online now
Find More Posts by IfIHadWings
Eat, Fly, Dream, Repeat...
IfIHadWings's Avatar
United States, GA, Jefferson
Joined Jun 2012
Gearbox: FLZA6319
The gearbox on mine failed. I'll order a couple of the SE5a combos and be set for a long time. Thanks for the tip!
IfIHadWings is online now Find More Posts by IfIHadWings
Old Jan 03, 2013, 02:00 PM
DeadTom is offline
Find More Posts by DeadTom
Team of ONE....or...Team Me
DeadTom's Avatar
Reno, Nevada
Joined Oct 2006
Well over the New Year's holiday I used my Tower Hobbies gift card and one of the items I ordered was one of these little Albatross'. I should have read this thread first as I also had them ship me 2 more gearboxes for the Albatross and a couple more props. Oh well I guess I can always order the other gearbox and motor/pinion setup.
PS - I really like to paint schemes that some of you have done on your Albatross'
DeadTom is offline Find More Posts by DeadTom
Old Jan 03, 2013, 03:17 PM
Tim Wolff's Avatar
Joined Sep 2002
Just fill out the return form and return them. Tower has hassle free returns. I think you can even order the SE5 gear boxes you want on the same form. Or just give 'em a call.
Old Jan 03, 2013, 04:14 PM
DeadTom is offline
DeadTom's Avatar
Reno, Nevada
Joined Oct 2006
Thanks Tim for the information, I shall give them a call.
Old Jan 04, 2013, 02:42 PM
kevin finn is online now
Find More Posts by kevin finn
United States
Joined Oct 2008
Servos
Originally Posted by beetyii View Post
After reading this thread for a while I couldn't resist - Albatros came today and the Fokker Dr1 is on its way ...
After a short running of the gearbox I disassambled the fuselage in order to make it quiet.
Some grease, 15 min break in running and a reassembly with UHU POR did the trick.
Now it is smooth and quiet.
When reassembling the gearbox I corrected the alignment because the camber was a little too much for my taste. Hi is this the new servo brick standard for the plane
Hi is this the new servo brick for the plane
After I heard of some quickly dying motors and saw that there was no cooling for it, I decided to change this.
I drilled some holes in the motor dummy and the fuselage to bring some fresh air onto the motor to cool him down.
I'll open the cockpit in front of the pilot, so the air can pass here.
I was very surprised to see that there are "real" servos on the board - was able to set 125% to improve the deflection of elevator and ruder.
To be continued ...
Rolf
hi is this the new standard brick for the plane in this pic
kevin finn is online now Find More Posts by kevin finn
Sold Flyzone Albatros RX brick and Transmitter Tim Wolff Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 05, 2010 09:24 AM
Sold Flyzone Albatros 2.4GHz TX - RX - Motor/Gbox - Battery + hauntfreaks Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Oct 04, 2010 04:35 PM
Sold Flyzone Albatros RX/Servos and TX - $35 Shipped UNGN Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Sep 28, 2010 09:09 AM
Found Trade my Flyzone Playmate for your Flyzone Albatros Flyboy70 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Sep 07, 2010 06:25 PM
