Old Nov 23, 2012, 11:53 AM
Angelo is online now
Find More Posts by Angelo
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Can you add another servo to the Albatros brick? I was just looking at the photo that cmdl posted and it looks like it has a socket for another servo - or is that something else? I'm thinking of buying the Albatros on sale and using the guts for another micro WWI project, but would like to add ailerons.
Angelo is online now Find More Posts by Angelo
Old Nov 23, 2012, 01:06 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Yes. The Currently $40 Albatros Bricks are 4 Channel and can also run an external brushless esc.
UNGN is offline Find More Posts by UNGN
Old Nov 23, 2012, 03:12 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
they look to fit hk5320 servo plugs. ill test that later.
nemoskull is offline Find More Posts by nemoskull
Old Nov 24, 2012, 04:45 PM
nemoskull's Avatar
Joined Sep 2009
me at nite, dsm2 32grams AUW aileron on the bottom.
the lights are my lights, 20 inches, so a little excessive. 0805 leds and resistors, 1 gram.
DSM2 Albatross at night (2 min 17 sec)
Old Nov 25, 2012, 09:16 AM
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Cool! Do you know if the Spektrum/E-Flite micro servos would work with it?
Old Nov 25, 2012, 09:19 AM
Angelo's Avatar
Chicago, IL
Joined Nov 1999
I was flying the Albatros last night at the local golf dome, I just love this plane, a very stable, solid flyer. Touch and goes are big fun with it. My only compliant is that it tends to snap out of loops. It's a bargain at the regular price, this is an absolute steal!
Old Nov 25, 2012, 09:31 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
I don't have one of the Flyzone boards, yet, but Nemo should have all of the stuff to test it.
Old Nov 25, 2012, 08:56 PM
nemoskull's Avatar
Joined Sep 2009
no spektrum servo do not fit, tho the hk5320 syle plug fits real nice, 1.25mm pitch. i have not checked the polarity, but i would guess center power.
Old Nov 26, 2012, 09:41 AM
Tommy D is offline
Find More Posts by Tommy D
Hooper, full throttle!
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
For $39 bucks I'm in! Ill be busy reading this for a while now.
Tommy D is offline Find More Posts by Tommy D
Old Nov 27, 2012, 10:28 AM
Angelo's Avatar
Chicago, IL
Joined Nov 1999
That's too bad. What's your experience with the hk5320?
Old Nov 28, 2012, 12:39 PM
nemoskull's Avatar
Joined Sep 2009
very good. if i dont solder the PCB much they last. i like them better than as2000l servos. super quiet.
Old Dec 04, 2012, 08:43 PM
beetyii is offline
Find More Posts by beetyii
Make the best of all you have
beetyii's Avatar
Essen/Germany
Joined Dec 2006
After reading this thread for a while I couldn't resist - Albatros came today and the Fokker Dr1 is on its way ...
After a short running of the gearbox I disassambled the fuselage in order to make it quiet.
Some grease, 15 min break in running and a reassembly with UHU POR did the trick.
Now it is smooth and quiet.
When reassembling the gearbox I corrected the alignment because the camber was a little too much for my taste.
After I heard of some quickly dying motors and saw that there was no cooling for it, I decided to change this.
I drilled some holes in the motor dummy and the fuselage to bring some fresh air onto the motor to cool him down.
I'll open the cockpit in front of the pilot, so the air can pass here.
I was very surprised to see that there are "real" servos on the board - was able to set 125% to improve the deflection of elevator and ruder.
To be continued ...
Rolf
beetyii is offline Find More Posts by beetyii
Old Dec 06, 2012, 09:17 AM
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Or, you can carefully remove the servo arms, move the push rods to the outer holes, then reattach. Stock servo travel works ok for me.
Good idea for the motor cooling.
Old Dec 06, 2012, 12:06 PM
beetyii is offline
beetyii's Avatar
Essen/Germany
Joined Dec 2006
I have moved the linkages to the outer holes on the servo arm, the inner holes of ruder and elevator and rised the travelling to 125%.
125% travelling gives you a better resolution - more steps make it smoother.
Rolf
Old Dec 06, 2012, 06:24 PM
Angelo's Avatar
Chicago, IL
Joined Nov 1999
You did all that? Must have lots of travel now! Funny, I'm pretty happy with the stock throws.
Sold Flyzone Albatros RX brick and Transmitter Tim Wolff Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 05, 2010 08:24 AM
Sold Flyzone Albatros 2.4GHz TX - RX - Motor/Gbox - Battery + hauntfreaks Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Oct 04, 2010 03:35 PM
Sold Flyzone Albatros RX/Servos and TX - $35 Shipped UNGN Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Sep 28, 2010 08:09 AM
Found Trade my Flyzone Playmate for your Flyzone Albatros Flyboy70 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Sep 07, 2010 05:25 PM
