Old Oct 23, 2010, 09:22 PM
Brent Slensker is offline
Find More Posts by Brent Slensker
Weni, wedi, Java...
Brent Slensker's Avatar
Casper, Wyoming
Joined Nov 2009
"Complete Main Landing Gear Set" = 2 wheels ONLY!....Not even the retainer hubs...
Brent Slensker is offline Find More Posts by Brent Slensker
Old Oct 24, 2010, 11:45 PM
baldy is offline
Find More Posts by baldy
United States, NJ, Chatham
Joined Mar 2003
A couple coats of Testors Model Master #1960 flat spray will make the decals look like they are painted on. Don't be afraid to apply wet coats it will not attack either the paint or foam. If you are thinking of doing a different scale paint job take a look at callie graphics.com She has two neat markings sets for the Albatros and will make any other markings you want.
baldy is offline Find More Posts by baldy
Old Oct 25, 2010, 11:26 AM
eli5539 is offline
Find More Posts by eli5539
eli5539's Avatar
Western New York
Joined Dec 2007
I had sent in pictures of markings from Callie, had them in my hands in about a week. Just be careful how you place them, they really stick. I place them on a gloss paint, then once they are on I place a clear gloss over the decals, let dry and then apply a clear flat, seems to work well
eli5539 is offline Find More Posts by eli5539
Old Oct 28, 2010, 04:52 PM
Weni, wedi, Java...
Casper, Wyoming
Joined Nov 2009
I ordered both sets... I hope I have a steady enough hand to get them on!..
I'll take pics of what I get sent to me.
Old Oct 29, 2010, 09:55 PM
baldy is offline
Joined Mar 2003
Dave Johnson, I want to build a copy of your TOP GUN Albatros.Could you please post some photos of it,particularly a good shot of the crescent on the fuselage side. Thanks,Baldy
Old Nov 01, 2010, 12:49 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Here's a New, more detailed version of the Under wing Lozenge that should make a good decal for the lower wing. The rib scallops/spacing are correct for a DVa, but they don't fit the model as close as the previous one that was based on a much less detailed 3-view.
I still need to cut them out and see how they fit the wing.
I also have upper wing masks done and have a top surface 5 color lozenge pattern.
I wave to work on this file. The two wings were different scales and the B/P outline tips are much different from the models.
UNGN is offline Find More Posts by UNGN
Old Nov 01, 2010, 01:36 PM
BlazingStar is offline
Find More Posts by BlazingStar
-=BS=-
BlazingStar's Avatar
Thousand Oaks, CA
Joined Jul 2009
Originally Posted by UNGN View Post
Since my Albatros has a Sukhoi motor....
Did you use the FZ grearbox with this motor?
Does the plane sound different without the stock motor?
I have a motor from the old PZ Cessna or a vapor that I can use.
What do you think?
BlazingStar is offline Find More Posts by BlazingStar
Old Nov 01, 2010, 04:22 PM
pattypilot is offline
Find More Posts by pattypilot
No dear, That isn't New!
pattypilot's Avatar
United States, IL, Urbana
Joined Nov 2006
Blaze from what I understand it’s the ESC not the gearbox making that noise. I know its hard to believe. We will soon find out because I plan on changing out the FZ with a PZ so I can use my radio. As for your motor choice, I would get a second and maybe a third opinion. I really think personally that both of those motors will be to small? Just my two cents worth. Jim
pattypilot is offline Find More Posts by pattypilot
Old Nov 01, 2010, 05:14 PM
eli5539 is offline
eli5539's Avatar
Western New York
Joined Dec 2007
Thought I would post these here
Description:
Old Nov 01, 2010, 05:27 PM
pattypilot's Avatar
Joined Nov 2006
Nice Eli, what paint did you use? Did you air brush it? It really looks good. Are those dragons from Callie graphics? I have one coming, still can't decide what color scheme to use?? Questions, I'm always full of questions. Jim
Old Nov 01, 2010, 06:18 PM
Weni, wedi, Java...
Casper, Wyoming
Joined Nov 2009
Originally Posted by BlazingStar View Post
Did you use the FlyzoneZ grearbox with this motor?
No, he used the 8.4mm Sukhoi/Champ motor. The Alby uses a 7mm motor. The gearboxes are not the same size
The gearbox provides the noise and is amplified by the fuselage. LOVE the noise, at low throttle it sounds like a WW1 plane
What do you think?
No, that is a 6mm motor, it won't fit the gearbox OR be powerful enough
All of these questions are also answered on the other Alby threads
Old Nov 01, 2010, 06:48 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
What do you think?
My Albatros had a Sukhoi motor/gearbox, but I switched back to stock Motor/gearbox. I still need to fly this new old Combo. I mover the brick back to balance the heavier motor, so I might be able to run a heavier battery like a 180... or it might be more aerobatic with a light battery, but the wind needs to die down to test it.
It was a little quieter with the Sukhoi gearbox, but not much. The Prop noise was louder.
Cessna/Vapor motors won't work. They won't fit in the gearbox and if they did, they wouldn't have enough power.
The Cub motor/Gearbox would make for a nice lightweight combo for an indoor flier with an old Vapor Brick. This would weigh about 2g less than stock.
Old Nov 01, 2010, 07:31 PM
eli5539 is offline
eli5539's Avatar
Western New York
Joined Dec 2007
Patty Pilot,
Thank you, still not finished but to answer your questions, the decals came from Callie. I did a search, sent them a few pictures and in about 2 weeks I had them at my door. I did use an air brush and Tamiya paints. I have used them for a long time so it is easy for me to mix properly and they cover very well here is my first try
Name: First attempt.jpg
Description:
Old Nov 01, 2010, 07:44 PM
-=BS=-
Thousand Oaks, CA
Joined Jul 2009
Thanks UnGN
the whole thing is on hold until I see what happens with the LG struts anyway...
Old Nov 01, 2010, 07:50 PM
pattypilot's Avatar
Joined Nov 2006
Well that oneís not shabby either. Iím going to try my hand at it. You guys are really turning out some great looking ships. Iím interested in this Lozenge pattern printing that UNGN has been talking about. So many models So little time. Jim
Sold Flyzone Albatros RX brick and Transmitter Tim Wolff Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 05, 2010 08:24 AM
Sold Flyzone Albatros 2.4GHz TX - RX - Motor/Gbox - Battery + hauntfreaks Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Oct 04, 2010 03:35 PM
Sold Flyzone Albatros RX/Servos and TX - $35 Shipped UNGN Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Sep 28, 2010 08:09 AM
Found Trade my Flyzone Playmate for your Flyzone Albatros Flyboy70 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Sep 07, 2010 05:25 PM
