Old Oct 20, 2010, 01:35 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by ShawnM4kq View Post
wow, so if you reuse your plastic bits a replacement airframe is about $20.
sweet
With Everything its only about $33... and With DJ's great trick of soaking the parts in Alcohol to remove the paint, they become the greatest scale WWI ARF kit ever... at least it will be when full landing gear sets are available.
UNGN is offline Find More Posts by UNGN
Old Oct 20, 2010, 06:14 PM
BrentP is offline
Find More Posts by BrentP
Closed Account
Joined Apr 2008
She's a beauty DJ !!
Someone mentioned panel line uniformity.
I did my PLH alby lines with a make shift jig spinning the model on it's nose paralell to the firewall. I used a liner pen but I'm sure you could use a scribe to indent the foam.
Not sure if it is relevant or would work at this scale but what the hey.
Again nice model !
BrentP is offline Find More Posts by BrentP
Old Oct 20, 2010, 07:33 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
What is the length of the CF axle? Mine broke and some portion of it is somewhere in the grass in a field.
Thanks!
Old Oct 20, 2010, 09:06 PM
D Johnson is offline
Find More Posts by D Johnson
Just some guy
D Johnson's Avatar
Joined Aug 2006
pretty good idea Brent. Is that the Maxford Albi?
D Johnson is offline Find More Posts by D Johnson
Old Oct 20, 2010, 09:33 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Thanks!
3-3/8" or 80mm, as measured directly from the axle removed from my Albatros.
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Old Oct 20, 2010, 09:57 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
RD
Great, Thanks for the help!
Old Oct 20, 2010, 10:05 PM
Elfi Flyer
Rock Hill, SC
Joined Oct 2002
FWIW: Tower just started shipping land gear assemblies for the Albatros. I have three on the way!
RD
Old Oct 20, 2010, 10:13 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
RD
Let us know if they are more than 2 tires.
Old Oct 21, 2010, 10:41 AM
BrentP is offline
Closed Account
Joined Apr 2008
It's a Powerline Hobbies, manufactured by green models (maxford's stuff is green models too but this one is a different kit 53")
Old Oct 21, 2010, 04:11 PM
pilot40874 is offline
Find More Posts by pilot40874
Los Angeles
Joined Sep 2010
Hi, attached are pictures of my Albatros. I have added paper cowl pieces, top rear, sides, and front ring. I drew panel lines on it. I am not entirely happy with them as I pressed to hard on the foam. I am used to doing that on depron. I also added the flying wires. I still need to make a dash decal and paint my pilot. I didn't want to get to heavy so I removed a whole bunch of foam before I started painting. The Mauve is Testors North Atlantic Purple and the green is Tamiya Green. The grey is Testors Light Ghost Grey and the red piping is Tamiya red. all are acryilics. I will post templates of the paper hatches and cowl pieces shortly. I will also post a dash decal when finished.
DJ
That is really a beautiful rendition, Dave!
Have you given any thought to producing a "Collector Series" of prepainted Flyzone Albatros airplanes? I love the original, but the Albatros planes were so colorful, I think there'd be a market for a new paint scheme being offered every few months. I know I'd buy a few of them! I'd try doing this myself, but there's no way I'd get the kind of results that I'd want. Your plane looks awesome.
pilot40874 is offline Find More Posts by pilot40874
Old Oct 21, 2010, 04:19 PM
speedy01 is online now
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
I broke two, after which I replaced the brittle carbon rod with thin wire. Haven't had a problem since, and the flex helps "dampen" landing bounces.
Gene K
speedy01 is online now Find More Posts by speedy01
Old Oct 21, 2010, 04:51 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Gene K
Great idea. I have both at home.
Old Oct 21, 2010, 04:58 PM
Elfi Flyer
Rock Hill, SC
Joined Oct 2002
I broke two, after which I replaced the brittle carbon rod with thin wire. Haven't had a problem since, and the flex helps "dampen" landing bounces. Gene K
Yes, thanks for the tip.
UNGN: I'll let you now what I get when the landing gear "assemblies" are received.
Dave Johnson: You are an artist extrodinair!
RD
Old Oct 23, 2010, 05:34 PM
enemyace19 is offline
Find More Posts by enemyace19
caveo hun in sol solis
enemyace19's Avatar
USA, NY, Levittown
Joined Jul 2010
Thought I would throw in a video for the heck of it....Doug
[URL="http://http://www.youtube.com/user/enemyace19#p/u/21/yjv3I-PyIkg"]
enemyace19 is offline Find More Posts by enemyace19
Old Oct 23, 2010, 06:58 PM
Elfi Flyer
Rock Hill, SC
Joined Oct 2002
Two tires. The description for the part number associated with the part number HCAA6347 is misleading to say the least. Description is:
"Complete Main Landing Gear Set", but there is no axle or the landing gear supports, just the wheels. So, the recommendation to use a piece of wire for the axle is valid, and other mods will have to be developed to replace other parts of the Land Gear Assembly.
RD
Sold Flyzone Albatros RX brick and Transmitter Tim Wolff Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 05, 2010 08:24 AM
Sold Flyzone Albatros 2.4GHz TX - RX - Motor/Gbox - Battery + hauntfreaks Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Oct 04, 2010 03:35 PM
Sold Flyzone Albatros RX/Servos and TX - $35 Shipped UNGN Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Sep 28, 2010 08:09 AM
Found Trade my Flyzone Playmate for your Flyzone Albatros Flyboy70 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Sep 07, 2010 05:25 PM
