Old Oct 13, 2010, 11:46 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Here's a revised lower wing Lozenge pattern that can be used to make decals.
I need to make an upper wing pattern, but haven't gotten around to it, yet... plus you'd need to disassemble the plane to install that one.
UNGN is offline Find More Posts by UNGN
Old Oct 15, 2010, 10:54 AM
D Johnson is offline
Find More Posts by D Johnson
Just some guy
D Johnson's Avatar
Joined Aug 2006
Very nice decals! Posted are the cowl panels, hatches and some other little fittings. I installed the cowl panels in the following order with ZAP canopy glue. 1st, the big section with the strut cut outs. 2nd, the front band, put the seam at the top and trim it so there is no overlap. 3rd, the front side pieces. they will overlap the other two and each other at the front top. Give it a try!
DJ
D Johnson is offline Find More Posts by D Johnson
Old Oct 15, 2010, 12:08 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Those are great. Thanks, DJ.
Does anyone have any detail on a windscreen? Is there one?
I want to try to make LED flashing Machine guns and work on the cockpit area.
Old Oct 15, 2010, 12:17 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by D Johnson View Post
Very nice decals! DJ
The Decals use a low resolution wing mask over a high resolution Lozenge pattern, put together in Word. I need to make Higher resolution Wing masks for the Upper and Lower wings, then I can easily swap in different lozenge patterns / change the rib welting colors on the wing masks, etc.
The lower wing mask was made from blowing up and tracing a tiny 3-view. I think I've found some higher resolution 3 views to use.
Then we just need someone to make decals.
Old Oct 15, 2010, 12:43 PM
Thayer is offline
Find More Posts by Thayer
Owner - Flying Models
United States, CT
Joined Aug 2003
If it pushes anyone over the edge for KIEF, I have Dave's model in my office and am driving over to the show tonight. It will be there all day tomorrow.
Oh yeah, and it is GORGEOUS in person!
Thayer
Thayer is offline Find More Posts by Thayer
Old Oct 15, 2010, 09:59 PM
matthew954 is offline
Find More Posts by matthew954
matthew954's Avatar
Joined Oct 2005
I'm at KIEF, at can't wait to see it!! I bought a damaged one from strouse here at RCGroups. I want to do a custom color scheme for it when I get the replacement parts. I'm sure his will give me some inspiration.
matthew954 is offline Find More Posts by matthew954
Old Oct 17, 2010, 09:35 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Since my Albatros has a Sukhoi motor, its a Tank compared to everyone elses Albatros, so i figure that I'll be breaking stuff before everyone else.
Here is the latest weak point we discovered and the fix we are trying. When Landing gear are available and i build one from pieces, I'm going to incorporate carbon strip across the whole flat of th top wing (by Notching the Cabane Struts at the top to let the carbon strip pass through)... since the next weak point is the wing just outside the cabane strut.
The top wing creased and tore along the centerline. No Crashes caused this. Just high G flying and one of the V wing struts coming unglued in flight, resulting in the upper wing folding up.
The Joint was UHU'd and a .040" CF rod was epoxied between the cabanes to the wing.
Old Oct 19, 2010, 04:21 PM
Thayer is offline
United States, CT
Joined Aug 2003
The Last Flight
Dave Johnson was kind enough to send me his custom Albatros to fly at KIEF this last weekend, and somehow I resisted the temptation to keep it. Before handing it off to Mr. UPS this afternoon though, I needed one more fix.
It was nearly flat calm when I got to the office this morning, so I rounded up Walter and Erick for documentation and ventured out to a local park with a charged battery for my last dance. This was the first time this beauty has soared in the sunlight.
Thayer
Old Oct 19, 2010, 06:13 PM
enemyace19 is offline
Find More Posts by enemyace19
caveo hun in sol solis
enemyace19's Avatar
USA, NY, Levittown
Joined Jul 2010
Originally Posted by Thayer View Post
Dave Johnson was kind enough to send me his custom Albatros to fly at KIEF this last weekend, and somehow I resisted the temptation to keep it. Before handing it off to Mr. UPS this afternoon though, I needed on last fix.
It was nearly flat calm when I got to the office this morning, so I rounded up Walter and Erick for documentation and ventured out to a local park with a charged battery for one last dance. This was the first time this beauty has soared in the sunlight.
Thayer
Very nice work!!!
enemyace19 is offline Find More Posts by enemyace19
Old Oct 20, 2010, 09:31 AM
ShawnM4kq is offline
Find More Posts by ShawnM4kq
Still AWD, Subaru
St.Louis
Joined Nov 2006
are replacement parts available yet?
My brick popped loose in flight last night and destroyed my recently repaired lower wing...now I need a new one.
Swapping in the PZ guts while Im at it.
ShawnM4kq is offline Find More Posts by ShawnM4kq
Old Oct 20, 2010, 09:37 AM
WRXpilot is offline
Find More Posts by WRXpilot
WRXpilot's Avatar
Bethesda, MD
Joined Jul 2006
Shawn: Yes, most parts are available @ Tower.
Wing set:
http://www3.towerhobbies.com/cgi-bin...?&I=LXZXJ6&P=M
One thing that they don't seem to sell is a replacement decal set, but if your upper wing is still okay you don't need to worry about that.
WRXpilot is offline Find More Posts by WRXpilot
Old Oct 20, 2010, 09:53 AM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Wing set:
This just in.....
http://www3.towerhobbies.com:80/cgi-...&P=IA&I=LXZXN7
Also possibly available from Hobbico or FlyZone direct, under part number HCA6353.
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Old Oct 20, 2010, 10:16 AM
Just some guy
D Johnson's Avatar
Joined Aug 2006
Maltese cross decal file attached
Old Oct 20, 2010, 10:23 AM
Still AWD, Subaru
St.Louis
Joined Nov 2006
wow, so if you reuse your plastic bits a replacement airframe is about $20.
sweet
Old Oct 20, 2010, 12:10 PM
hauntfreaks is offline
Find More Posts by hauntfreaks
hauntfreaks's Avatar
Cherry Hill, NJ
Joined May 2005
the is the graphic I have on my vert-stab... (my wife)
hauntfreaks is offline Find More Posts by hauntfreaks
Sold Flyzone Albatros RX brick and Transmitter Tim Wolff Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 05, 2010 08:24 AM
Sold Flyzone Albatros 2.4GHz TX - RX - Motor/Gbox - Battery + hauntfreaks Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Oct 04, 2010 03:35 PM
Sold Flyzone Albatros RX/Servos and TX - $35 Shipped UNGN Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Sep 28, 2010 08:09 AM
Found Trade my Flyzone Playmate for your Flyzone Albatros Flyboy70 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Sep 07, 2010 05:25 PM
