The woodgrain prop look is so Easy, even I can do it.
Base coat of Tan (I used Tamiya XF-59 Desert Yellow) with a course brush, then grain with a file brush and a brown (I used $1 Craft Acrylic "real brown") Then Clearcoated with Krylon... the clear coating may make the tips brittle, though, as I have chunked a few prop tips... The plane doesn't seem to notice too much. |
Latest blog entry: AR6400 guillows Space Shuttle
I'm not all that artistic, so I don't know my brushes very well! Thanks for sharing. BTW, any special prep to the stock black prop prior to painting, such as light sanding to get the paint to adhear better to the plastic surface? Thanks RD |
Latest blog entry: Big Red Cadillac
Light sanding helps the paint stick and light sanding after clear coat smooths it out. I use 320 grit wet/dry. I use a fine brush to free hand the brown. Here's the look I was going for from one of the Scale Electric planes forum's DVa Threads:
| Thread Tools | |
| Sold Flyzone Albatros RX brick and Transmitter | Tim Wolff | Aircraft - Electric - Micro & Indoor Airplanes | 1 | Oct 05, 2010 08:24 AM |
| Sold Flyzone Albatros 2.4GHz TX - RX - Motor/Gbox - Battery + | hauntfreaks | Aircraft - Electric - Micro & Indoor Airplanes | 6 | Oct 04, 2010 03:35 PM |
| Sold Flyzone Albatros RX/Servos and TX - $35 Shipped | UNGN | Aircraft - Electric - Micro & Indoor Airplanes | 1 | Sep 28, 2010 08:09 AM |
| Found Trade my Flyzone Playmate for your Flyzone Albatros | Flyboy70 | Aircraft - Electric - Micro & Indoor Airplanes | 0 | Sep 07, 2010 05:25 PM |
