Old Feb 11, 2012, 07:01 PM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
When I get my FMS P-38, I expect the same help! Lol
v8truckin is online now Find More Posts by v8truckin
Old Feb 11, 2012, 07:10 PM
Aros.MotionRC is offline
Find More Posts by Aros.MotionRC
Shameful Warbirdaholic.
Aros.MotionRC's Avatar
Maple Valley, WA
Joined Apr 2006
You got it!
Looks like I have V1. Not sure if that's good or bad...
Aros.MotionRC is offline Find More Posts by Aros.MotionRC
Site Sponsor
Old Feb 11, 2012, 07:18 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Its exactly neither. Its all for looks. I had both versions and only had a problem with the V2 sequencer or servo not opening the door and had to belly land in a field. Never had a problem with v1.
Old Feb 12, 2012, 02:24 AM
Maple Valley, WA
Joined Apr 2006
Thank you for the help...It's what makes this place so invaluable.
Site Sponsor
Old Feb 12, 2012, 02:56 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
if or when you get a chance swap out the nose steering servo with a MG servo. Also on v1 add 4mm collars on the main gear struts @ the base of trunnion. This helps keep the strut from sliding down into the gear if the trunnion sets screws become loose.
Old Feb 12, 2012, 03:23 AM
Maple Valley, WA
Joined Apr 2006
Valuable advice! Thank you!
Site Sponsor
Old Feb 12, 2012, 04:52 AM
jdubg23 is offline
Find More Posts by jdubg23
half-ass Astronaut
jdubg23's Avatar
United States, FL, St Petersburg
Joined Jan 2011
and i would leave TV (thrust vectoring) off for the first few flights... until you become acquainted with the aircrafts nuances
jdubg23 is offline Find More Posts by jdubg23
Old Feb 12, 2012, 05:33 AM
Maple Valley, WA
Joined Apr 2006
I agree...I just don't have the reference or knowledge point to know what to expect. I know High Alpha is one benefit, flat spins, etc...But until I know what to expect with each movement of the stick I think I will wait it out.
Site Sponsor
Old Feb 12, 2012, 03:21 PM
Maple Valley, WA
Joined Apr 2006
Maidened today...Went fantastic! She scoots! I need some larger 3S batts...Mine are 3000 and I really sucked every last voltage out of them to get 5 minutes. I turned off the TV on the elevators and ailerons, just rudder. I'm not that into TV and I certainly didn't want to try it out on the maiden. In the paint shop she goes. I know it's tired and used up but dangit I love the Blue Angel livery even though there is no E variant.
Great jet!
Site Sponsor
Old Feb 12, 2012, 03:40 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Congrats Aros! I was patiently waiting for a maiden update. After all the info I gave you I didn't want to be the cause of a maiden gone bad. If you want more flight time you might want to invest in some 4000mah 6s setup. Not sure if you like 3sx2 or 1x6s but 4000mah gives you good flight time without having to cut up foam for it to fit. That's all I use in mine & euro. Like I said you can go bigger 4500 or up but you'll have to do some trimming. Either way she a great jet and I learned a lot about flying from her.
Old Feb 12, 2012, 04:09 PM
Maple Valley, WA
Joined Apr 2006
Thanks! I do have a 6S 4000 but it wouldn't fit without cutting that little foam barrier by the battery compartment. If that's all I need to do to get it to fit I will do that!
Blue Angel blue coat #2 coming up!
Site Sponsor
Old Feb 12, 2012, 04:24 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Yup thats what i did. I also added some packaging bubble wrap at the nose of the battery bay to keep the battery from sliding forward. A foam block or tissue, etc. will work fine...whatevers lighter.
Old Feb 12, 2012, 04:27 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Don't think any1 on here has done a blue angles scheme in this bird. So it'll look nice and stand out in the sky.
Also do a check with a wattmeter, just to make sure. These stock setups are pushing close to the esc rated amps. I swapped mine out to a hw100a and cc bec. Not trying to scare you, but i swap out the esc and bec on every plane/jet, but just for your reference depending on flying style, cruiser or WOT.
Old Feb 12, 2012, 04:30 PM
Maple Valley, WA
Joined Apr 2006
Thanks for the tip! I'll take some photos of the progress. I love repainting my birds.
Site Sponsor
Old Feb 12, 2012, 04:37 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Did you repaint the p-38?
Build Log CRASHED Hobby Lobby F-35 Lightning II re-build. (YES, it's possible) denial15 Foamy EDFs 53 Dec 04, 2015 04:02 PM
Article Hobby Lobby eRC 90mm F/A 18E Super Hornet EDF Bajora Foamy EDFs 92 Jul 13, 2015 01:57 AM
Article Hobby Lobby F/A-18 Hornet ARF Review dawnron1 Foamy EDFs 2087 Jan 07, 2011 11:54 AM
Discussion My Hobby Lobby F-18 Hornet anyairrc Foamy EDFs 3 Feb 07, 2008 10:24 PM
For Sale Hobby Lobby F/A 18 Hornet Lipo & Electronics itspat Aircraft - Electric - Power Systems (FS/W) 0 Jan 08, 2008 01:33 PM
