Old Oct 21, 2010, 08:18 AM
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Good job Neversommer! Looks like you got quite a bit done last night. I guess I was lucky that the plastic hooks for the nose gear doors weren't broken. I'm sure you can fabricate something out of a paper clip or something similar. My nose gear is raked forward as well, guess that's how it's designed. I'm off tomorrow, as our club is putting on a flying demostration for a children's group. I'm tempted to bring the F/A-18 as I simply have to screw in the nose gear, make the connections, and it's ready to fly. I may bring it and wait until everyone leaves around 2:00 PM and try fliying it at that time.
Mike_Then is offline Find More Posts by Mike_Then
Old Oct 21, 2010, 09:26 AM
neversommer is offline
Find More Posts by neversommer
neversommer's Avatar
Luzern/Switzerland
Joined Aug 2008
Originally Posted by kydawg1 View Post
Neversommer - looks like you have less issues than my plane (also from Hobby Lobby)....this means there are some QC issues at the factory (and a wide range of quality variations and problems getting out the door). Looks good - keep us posted of your Maiden.
I did let ready2fly know about quality control issues which they will forward to freewing directly.
I am actually happy that I have not that many issues.
Wait for my videos to come, I am still trying to find the small missing part, if not I have to think of something else.
neversommer is offline Find More Posts by neversommer
Old Oct 21, 2010, 09:32 AM
Luzern/Switzerland
Joined Aug 2008
Cheers Mike
I simply could not resist.
I got home, the package was there...I took my canon hd camera and the big parcel and went down to my hobby room to start making pictures, movies and of course the build.
Bring your F/A-18 Super Hornet with you, surely it will turn the eyes
I have to think of something for the missing small piece.
Problem is since my floor is sort of blueish, I cant find this small thingy.
I had the epoxy ready then my small part vanished from my table....
Then my mum came in and wiped the floor, lol.
Besides I got a bit high cause I forgott to open the window for air circulation and came up with a red face and had a laugh attack for some reason, lol!
Cant wait to get home to finish up my current flagship!
Regards
Neversommer.
Old Oct 21, 2010, 11:12 AM
JGuilty13 is offline
Find More Posts by JGuilty13
JGuilty13's Avatar
United States, MI, Rochester Hills
Joined Nov 2005
I am very curious...would I be able to fly this model with my DX6i if I disabled the VT? I want this model so bad, but I dont want to have to buy the DX7 just yet.
Any advice is greatly appreciated. Thank you.
- Jordan
JGuilty13 is offline Find More Posts by JGuilty13
Old Oct 21, 2010, 12:18 PM
Mike_Then's Avatar
Joined Apr 2001
- Jordan
The DX6i should fly the plane fine... the mixing takes place on the transmitter, correct? The plane comes with plenty of y-harnesses so as long as the DX6i supports the mixing, I would think it would work but I don't know. I don't think either Jason (Flyboone) or Mike (hiflyer) are monitoring this thread so you may want to post that question in the Hobby Lobby forum.
Old Oct 21, 2010, 01:29 PM
BEELZEBOB is offline
Find More Posts by BEELZEBOB
On Drugs
BEELZEBOB's Avatar
A mile high and 30 feet south of the 40th parallel
Joined Dec 2009
Soo w. 6ch you have;
Throttle
Elevator
Ailerons
rudder
so the plane will fly.... Plus channell 5 can be TV via mixing, and channel 6 maybe the flaps?
im just guessing here, but it should be able to work.
BEELZEBOB is offline Find More Posts by BEELZEBOB
Old Oct 21, 2010, 02:59 PM
Roswalt is offline
Find More Posts by Roswalt
Capt, USAF
Roswalt's Avatar
United States, NV, Las Vegas
Joined Feb 2009
- Jordan
I rigged mine up to a DX6i... Works perfectly. No need for the DX7! Here's my breakdown:
1-Throttle
2-Aileron (Y-cable)
3-Elevator
4-Rudder TV/NWS (y-Cable)
5-Landing Gear
6- Elevator TV servos (Y-cable)
The y-cable I used for the vertical TV has a third port if you purchased from HL, so I think you could actually fly this on a DX5 if you dared to be so bold. You could also use that option on the DX6i and use the extra slot for dual aileron control, thus enabling "flaperons". You'd have the TV on all the time though...
I simply used a 100% mix for the elevator TV, tying the "flap" function to the elevator function so that I can disable it using the flap switch if needed.
Roswalt is offline Find More Posts by Roswalt
Old Oct 21, 2010, 05:03 PM
Jason Cole is offline
Find More Posts by Jason Cole
RCG Staff Member
Jason Cole's Avatar
United States, TN, Nashville
Joined Oct 2003
- Jordan
It's already been answered, but yes you can use a 6 channel. Heck, you could even do it with a DX5.
Jason Cole
Jason Cole is offline Find More Posts by Jason Cole
Administrator
Old Oct 22, 2010, 12:24 AM
Mike_Then's Avatar
Joined Apr 2001
Well guys, I had to do it. I had no choice. I installed the nose gear retract tonight and much to my dismay, the gear doors wouldn't close around the new, larger wheels. Not when the gear was retracted, mind you... it fits in the wheel well with plenty of room to spare. The new wheels don't fit while the gear is retracting. I played with a new piece of string and the problem became that the doors wouldn't fully close. With time quickly slipping away, I decided to be done with the gear doors and pulled them off the plane. That was easy but then the plane looked awful stupid from the side view. I then went about gluing the doors in permanently, and carving enough of them away so the wheels and strut pass cleanly through them. It's too bad it came to that, but I remembered what most modelers have told me.... gear doors are a pain in the tuchus and aren't worth messing with. I agree! I mean it's a flying hunk of foam, not a Top Gun-worthy model. So I got over it.
The plane certainly doesn't look as sharp as it did when it was new, but I bet it flies just as good. Gonna give it another shot at the CHARM event we're hosting tomorrow. Wish me luck and a post-flight report to follow tomorrow.
Oh yeah, I also mixed in some flaperons; let's see if this helps me get off the ground.
Old Oct 22, 2010, 08:17 AM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
@Mike Then: Try glassing the doors and dremel the foam away after to allow the door to close behind the tires. But Ya. I finally resorted to a sequences servo to operate the doors on my Euro. That's what they did on the LX models too.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Oct 22, 2010, 10:31 PM
Mike_Then's Avatar
Joined Apr 2001
Too late, I already butchered it up. It looks OK, and I'm alright with that as it flies great.
A quickie post-flight report: I tried to fly it with the flaperons and elevator and it took off but it took a lot of runway to do so. The new wheels/axles really roll smooth. I increased the flaperons and elevators throws just a bit, and the next flight the plane leapt off the ground! It immediately started to nose-down a bit but that was due to the flaperons. The next two flights I was prepared for the dip of the nose and all I did was hold a little more up-elevator until the jet got on-step. The final takeoff was the smoothest of the day, with a quick retraction of the flaperons and pulling the gear up.
I'm very happy, guess I'm keeping the jet after all. I can post my elevator and flaperon numbers if anyone wants them.
Old Oct 22, 2010, 11:27 PM
ColoradoHeliNut is offline
Find More Posts by ColoradoHeliNut
United States, CO, Lakewood
Joined Mar 2007
Well guys I thought I woild post these two posts here. They are in the other thread but since this is a build/mod & tips thread.
10-19-10
OK guys. I hooked up a AR7000 & a couple 3s batteries. Here's what I found.
1: All the LED's work fine. They do seem to be as brite as the B-25 but yes they are different than the B-25 Led's. I'll have to judge them togeter sometime.
2: I realize now that both horizontal TV control rods are bent & are suposed to be. The nozzles are a very tiny bit loose but not bad. About the same as my SU-34. However the control horn was NOT centered when the servo was plugged in. I had to pull the cover off to center it. It was real off. Way too much to just use the sub trim to center it.
One Aileron control was way off & not certerd. However I don't know if it's just the horn or the clevice. I did crew the clevice way down for now.
3: Wings, & fins line up nice & tight.
4: Here's the sad part. left main retract works interminttently.
It some times sticks in the retracted position & sometimes in the down position. If stuck in the retracted position, the motor will wine VERY load. To unstick it it has to be helped by pulling it when hitting the switch.
I pulled it out and it works more often but it did stick a couple of times. I kinda think the overload circuit is way to senstive on it & that's causing the sticking. I did trim the cover just a tad because the the strut was contacting it when it went down. Didn't help. I'll call HL to get a replacement.
4: The fan seems pretty balanced. I don't think I'll pull it for now unless I get some extra time.
Now I just have to glue all together.
OH! Does anyone have the exact DX8 programming yet? I set it up as the intructs say for the DX7 but nothing works the way it's suposed to. I might just copy the SU-34 progamming off my DX7 & see if that works.
10-22-10
I gave up trying to program the DX8. I just programed my DX7 exactly just like my SU-34. A couple channels might be reversed compared to the 34 but It works exlactly the same. The D/R rudder switch turns TV on & the 3 position Flaps/flight mode switch turns on TV. 0 does nothing, 1 turns on vertical only & 2 turns on aileron TV. The SU-34 DX7 proraming is not at all what the F-18 manual says for the DX7.
I got the two extra landing lights installed & I also pulled that one flakey retract & took it apart. Tightened the nut on the worm screw a bit & put it all back togetheer. It's still a bit noisey but it does not hang up or stay put when the gear switch is activated. It goes up & down every time now with no whining when it stops. I guess I'll leave it in now & see how long it lasts & keeps working. The first sign of trouble though HL gets a call. I have a set of E-Flite ele. retracts I can put in now too till HL sends out a new one if it comes to that.
I'm stuck not flying. Can't find any batteries locally. Hobby King sent me the wrong batteries. They sent me two tiny 3s 2200mah 20c's insted of the 2 6s 4000mah 30c batteries I ordered. Stupid people!!!! Not even an invoice with them. Tried calling the US warehouse all day & no answer.
ColoradoHeliNut is offline Find More Posts by ColoradoHeliNut
Old Oct 23, 2010, 08:54 PM
huggett is offline
Find More Posts by huggett
EDF Addict
Wisconsin
Joined Aug 2005
In case anyone is interested on stock power system I am getting just a bit over 1400 watts at 64 amps using 2x Turnigy 3s 3600 30c lipos with just a couple cycles on them.
I have also found that the programming for DX7 described in the manual is not entirely correct. The manual states to reverse channels 2 & 3 and that ALL other channels should be in the "normal" position........ I discovered that I also had to reverse channel 7 to get the aileron vectoring to work right and reverse channel 4 to get the steering and rudder vectoring right. This set-up per manual only seems to allow the elevator vectoring to be turned on/off with the mix switch. The aileron and rudder vectoring is always on...... not sure if I like this, I might want to be able to turn all vectoring off.
huggett is offline Find More Posts by huggett
Old Oct 23, 2010, 09:31 PM
huggett is offline
EDF Addict
Wisconsin
Joined Aug 2005
Anyone come up with a good starting point for the elevator neutral position? This would also be very helpful to put in the manual
Old Oct 24, 2010, 09:13 PM
Mike_Then's Avatar
Joined Apr 2001
I don't know what the actual neutral position is, but I can take a pic of neutral on mine and post it if you like.
Build Log CRASHED Hobby Lobby F-35 Lightning II re-build. (YES, it's possible) denial15 Foamy EDFs 53 Dec 04, 2015 05:02 PM
Article Hobby Lobby eRC 90mm F/A 18E Super Hornet EDF Bajora Foamy EDFs 92 Jul 13, 2015 02:57 AM
Article Hobby Lobby F/A-18 Hornet ARF Review dawnron1 Foamy EDFs 2087 Jan 07, 2011 12:54 PM
Discussion My Hobby Lobby F-18 Hornet anyairrc Foamy EDFs 3 Feb 07, 2008 11:24 PM
For Sale Hobby Lobby F/A 18 Hornet Lipo & Electronics itspat Aircraft - Electric - Power Systems (FS/W) 0 Jan 08, 2008 02:33 PM
