Old Jan 05, 2012, 10:46 AM
capt soap is online now
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Steve, How about some numbers??? Are you flying with a higher Amp esc???
capt soap is online now Find More Posts by capt soap
Old Jan 05, 2012, 02:23 PM
stevekott is offline
Find More Posts by stevekott
Born to Live - Live to Fly !
stevekott's Avatar
Southern California
Joined Jul 2009
Ralph, Capt Soap,
I'm using a CC Ice 100 but I wouldn't be surprised if the Stock Freewing 80A esc would do the job.
Max current draw on 6s is 83A whereas the Freewing tops out about 60A.
I had to cut the inlet ring off the Freewing Shroud (the CS fan doesn't come with one) and carefully glue it to the front end of the CS Shroud.
Some minor foam modification as the fan shroud is longer, same diameter though. I also cut some of the CS shroud off in the sides on the rear as it was protruding past the foam walls. Then I drilled the plywood mounts for a single 4-40 T-Nut (one on each side) and jammed it sideways into the foam and up into the wood. Probably an hour and a half of work, not too bad.
stevekott is offline Find More Posts by stevekott
Old Jan 05, 2012, 03:52 PM
Ralph E is offline
Find More Posts by Ralph E
Miami, Florida
Joined Oct 2006
Steve, thanks again for the info. It doesn't sound too bad.
Ralph E is offline Find More Posts by Ralph E
Old Jan 06, 2012, 02:46 PM
washab is offline
Find More Posts by washab
ROLL, PITCH, YAW
washab's Avatar
Joined Jan 2011
Input Please
Just got a FW/HL 90mm F-18 kit and plan to put this in it:
RC Lander 90mm 1900kv metal dps edf fan/motor unit.
http://parkrcmodels.com/product_info...roducts_id=870
HobbyWing Pentium 100A w/SBEC
http://www.hobbypartz.com/07e-flyfun-100a.html
Still looking at servo options but would like to have input on the power system. This will be a 6S setup. Any input is welcome.
BTW - is it OK to extend the leads from ESC -> motor?
This kit is the V3 according to the web site w/ upgraded retracts.
washab is offline Find More Posts by washab
Old Jan 06, 2012, 03:03 PM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
I used Hs-65mg on the ailerons & tailerons fit perfect with no cutting. Lost an airframe due to deans melting crashed & servos survived except the nylon tv. Also added mg servo to steering believe it was a tower pro mg.
As for power system I run stock & upped the esc to a HW100a with cc bec. Good luck on your quest.
v8truckin is online now Find More Posts by v8truckin
Old Jan 06, 2012, 03:29 PM
washab is offline
ROLL, PITCH, YAW
washab's Avatar
Joined Jan 2011
thanks for your input. I'll look into those mg's. I need to get a CC BEC.
Old Jan 06, 2012, 03:44 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
The hs-65mg are a lil pricey, but I've also used the TP-90MG in other planes on the ailerons & elevator and have never had a prob. Think they run $7-8 a servo.
Old Jan 06, 2012, 04:27 PM
kydawg1 is offline
Find More Posts by kydawg1
"Aircraftus Fragmentum"
kydawg1's Avatar
United States, MI, Detroit
Joined Mar 2007
F18s back in stock at HL...........but did anyone else catch the jump of $10 per plane in shipping? It was $39 last year and $49 this year....YIKES! Put in 3 or 4 planes and the price jumps to $225!!!
kydawg1 is offline Find More Posts by kydawg1
Old Jan 07, 2012, 01:31 PM
washab is offline
ROLL, PITCH, YAW
washab's Avatar
Joined Jan 2011
thanks again for the advice/suggestions....I LOVE RC GROUPS!!!!! Plethora of information.
BTW - do you remember where you got the TP-90MG? Found some here http://www.headsuprc.com/servlet/the...-14g-TP/Detail
and here http://www.giantcod.co.uk/towerpro-m...-p-403863.html ... but never shopped there before.
Old Jan 07, 2012, 07:30 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
http://www.toysonics.com/towerpro-mg...cro-servo.html
Someone also sells a digital version of this version I think but can't remember who. Ne how they are great for the price.
Always use this place for most of my electronics, since they r located in Cali & so am I. If I order early enough orders arrive in 1 day & never had 1 problem.
Old Jan 08, 2012, 07:28 PM
buster232 is offline
Find More Posts by buster232
buster232's Avatar
United States, KY, Louisville
Joined May 2010
Questions about air frame only
Hi,
A tree ate my v2 plane today and I am ordering a new one AF only to replace it. Does the airframe only version come with all lights pre-installed? Also with the V3 how is the gear door servo controlled? Is there a board? Thanks
buster232 is offline Find More Posts by buster232
Old Jan 08, 2012, 07:58 PM
firehawkzach is offline
Find More Posts by firehawkzach
firehawkzach's Avatar
United States, TX, Fort Worth
Joined Jan 2011
I own the 9s version of that fan and I never installed it into this airframe because it was way too heavy. Maybe the 6s combo would be more suitable but this airframe lands the best when it is light.
firehawkzach is offline Find More Posts by firehawkzach
Old Jan 08, 2012, 09:35 PM
stevekott's Avatar
Southern California
Joined Jul 2009
Originally Posted by buster232 View Post
Hi,
Yep the lights are installed and wired and ther is a built in sequencer installed for the nosegear door. It also includes the servo leads ready to go. It's a very nice "airframe only" kit. More like an ARF.
Old Jan 09, 2012, 11:02 AM
buster232's Avatar
Joined May 2010
ok thanks!
Sent from my DROID X2 using Tapatalk
Old Jan 10, 2012, 02:48 AM
jdubg23 is offline
Find More Posts by jdubg23
half-ass Astronaut
jdubg23's Avatar
United States, FL, St Petersburg
Joined Jan 2011
this has worked well with the stock fan...
http://www.hobbyking.com/hobbyking/s...90mm_EDF_.html
HL F18 quick flight (2 min 34 sec)
jdubg23 is offline Find More Posts by jdubg23
Build Log CRASHED Hobby Lobby F-35 Lightning II re-build. (YES, it's possible) denial15 Foamy EDFs 53 Dec 04, 2015 05:02 PM
Article Hobby Lobby eRC 90mm F/A 18E Super Hornet EDF Bajora Foamy EDFs 92 Jul 13, 2015 02:57 AM
Article Hobby Lobby F/A-18 Hornet ARF Review dawnron1 Foamy EDFs 2087 Jan 07, 2011 12:54 PM
Discussion My Hobby Lobby F-18 Hornet anyairrc Foamy EDFs 3 Feb 07, 2008 11:24 PM
For Sale Hobby Lobby F/A 18 Hornet Lipo & Electronics itspat Aircraft - Electric - Power Systems (FS/W) 0 Jan 08, 2008 02:33 PM
