Old Nov 28, 2011, 01:44 AM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
They're not open now & I just thought about it.
v8truckin is online now Find More Posts by v8truckin
Old Nov 29, 2011, 06:57 AM
ColoradoHeliNut is offline
Find More Posts by ColoradoHeliNut
United States, CO, Lakewood
Joined Mar 2007
I really doubt they are V2's.
I read that the new stock of Euro Fighters are not V3's which has the new servo sequenced gear doors.
ColoradoHeliNut is offline Find More Posts by ColoradoHeliNut
Old Nov 29, 2011, 11:02 PM
jlarkin123 is offline
Find More Posts by jlarkin123
United States, FL, St Petersburg
Joined Jul 2010
battery connection for a 6s pack
I have a question about how you hook a 6S battery to the esc. I just got this plane in a trade, without an esc, and it says in the manual that you hook a 6s battery up with a jumper plug? Don't you just hook the 6s battery to the esc? I would think that you need a jumper plug with two 3s packs to put them in serial? What is the jumper plug?
Thanks for any help.
jlarkin123 is offline Find More Posts by jlarkin123
Old Nov 29, 2011, 11:05 PM
Joined Jul 2010
I think I see
Looking close at the picture in the manual, does the jumper plug just give you the flexibility to use two 3s packs? I think it looks like the jumper just closes the connection for a second pack when using a 6s pack. Meaning that it plugs the extra opening.
Old Nov 29, 2011, 11:19 PM
fredmdbud is online now
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
The jumper plug probably refers to a connector that allows the BEC to tap into the battery leads.
Here is what you would use to hook two 3S batteries to make a single 6S battery.
fredmdbud is online now Find More Posts by fredmdbud
Old Nov 29, 2011, 11:26 PM
Joined Jul 2010
Thanks for reply. Did the esc with the kit come with a BEC? Looking at the picture, I think the the esc is wired with a series connection for using two 3s packs. Then you would need a jumper when using the 6s pack. I was planning to just use a 6s pack and just solder a single deans connector to the ESC that I have, so I was confused about the recommendation to use a jumper for a 6s pack. I do have two matched 3s 4000mah packs that I could use, but I think it would make sense to just make a series adapter for that case.
Old Nov 29, 2011, 11:28 PM
Joined Jul 2010
Fred, your bottom diagram is exactly what I was thinking! It didn't load originally so I didn't see it before my last post. Thanks again.
Old Nov 29, 2011, 11:40 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
If you are going to use two 3S batteries, I've heard that it is better to connect the BEC across one battery (the one connected to the ground of the single female connector) and set your cut-off accordingly - less stress on the BEC when it steps down the voltage to 4-6V.
Old Dec 04, 2011, 06:03 PM
jdubg23 is offline
Find More Posts by jdubg23
half-ass Astronaut
jdubg23's Avatar
Joined Jan 2011
Originally Posted by ColoradoHeliNut View Post
OK I looked at it again. The green LED I see facing backward on the right rudder is just the green one on the side of the rudder. My Bad. Looks like it's just like all the rest.
I hope my new kit has the sequenced front door. I doubt it though. Plus I'd need to get a sequencer too.
the gear leads have a three way splitter and a sequencer built in
jdubg23 is offline Find More Posts by jdubg23
Old Dec 04, 2011, 06:18 PM
jdubg23 is offline
half-ass Astronaut
jdubg23's Avatar
Joined Jan 2011
so i have had my jet for a couple weeks now. it is showing signs of abuse lol. i busted the nose off twice and folded two sets of landing gear!! this thing is a different animal than my other planes (carbon z yak, parkzone trojan). lands real heavy, gotta have a nice touch on your elevator stick. but the thrust vectoring accounted for my two nose "breaks". trying to go around on an approach i goosed it, well the plane sommersaulted right into the ground!! (i did that twice). so i have disabled the TV and added dual rudders!
Hobby lobby f18. Rudder mod (0 min 31 sec)
Old Dec 04, 2011, 07:05 PM
jdubg23 is offline
half-ass Astronaut
jdubg23's Avatar
Joined Jan 2011
im not sure what it takes to qualify as a "v2". but the airframe only kit i just received a couple weeks ago has a glossy color manual, fancy new gear struts, and sequenced servo driven nose gear doors....
Old Dec 04, 2011, 07:09 PM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
That's gotta be V2. V1 closed the front gear door with a string.
xviper is online now Find More Posts by xviper
Old Dec 04, 2011, 10:49 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Who'd u purchase from? Hopefully hobby lobby I'm waiting for mine to arrive.
Old Dec 05, 2011, 01:58 AM
jdubg23 is offline
half-ass Astronaut
jdubg23's Avatar
Joined Jan 2011
yes HL in Tennessee
Old Dec 05, 2011, 05:54 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Sweet ! Too bad it's my spare airframe & going 2 the closet.
Build Log CRASHED Hobby Lobby F-35 Lightning II re-build. (YES, it's possible) denial15 Foamy EDFs 53 Dec 04, 2015 05:02 PM
Article Hobby Lobby eRC 90mm F/A 18E Super Hornet EDF Bajora Foamy EDFs 92 Jul 13, 2015 02:57 AM
Article Hobby Lobby F/A-18 Hornet ARF Review dawnron1 Foamy EDFs 2087 Jan 07, 2011 12:54 PM
Discussion My Hobby Lobby F-18 Hornet anyairrc Foamy EDFs 3 Feb 07, 2008 11:24 PM
For Sale Hobby Lobby F/A 18 Hornet Lipo & Electronics itspat Aircraft - Electric - Power Systems (FS/W) 0 Jan 08, 2008 02:33 PM
