Old Sep 21, 2011, 06:10 AM
RCflyerCT is offline
Find More Posts by RCflyerCT
RCflyerCT's Avatar
United States, CT, Southbury
Joined Aug 2011
ESC replacement
Guys,
Thanks for the recco on the ESC replacement. I got the ICE 100 per your advice. One dumb question I have is when I went to connect it I noticed a second black and red wire coming out of the stock ESC and appearing to go to the lighting circuit board. I have attached a picture. Do you have any advice on how to connect this. I assume I need to get a separate connector that would go from the lighting circuit board to the receiver, but I am out of channels - I guess I could connect to a Y harness. Also, for those that did this what connector did you use...the lighting board uses different connector heads/wires than the normal servo connectors.
Thanks again for your help!
Wes
RCflyerCT is offline Find More Posts by RCflyerCT
Old Sep 21, 2011, 09:56 AM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
My guess is that's coming off the BEC that's built into the stock ESC. I don't remember if the stock BEC is 4.8V or 6V. I would think you could plug a y-harness into the servo lead... one goes to the receiver, the other goes to the light board. Check the voltage first so you don't fry anything.
Mike_Then is online now Find More Posts by Mike_Then
Latest blog entry: Moving on from the F-14
Old Sep 22, 2011, 08:07 AM
RCflyerCT's Avatar
Joined Aug 2011
Thanks...I will give this a shot. I am still struggling with the light board connector...it is a small 2 contact connector with only 2 wires...much smaller than a standard servo wire..it's like I need a servo connector on one end of the wire and this smaller one on the other...can't seem to figure that out.
Old Sep 26, 2011, 06:10 AM
kydawg1 is online now
Find More Posts by kydawg1
"Aircraftus Fragmentum"
kydawg1's Avatar
United States, MI, Detroit
Joined Mar 2007
Here's a flight from the weekend........ sure do like this plane.
Kydawg's 90mm Freewing F18 Dist by Hobby Lobby Stock Power 2011 0924 (4 min 39 sec)
kydawg1 is online now Find More Posts by kydawg1
Old Sep 26, 2011, 07:32 AM
RCflyerCT's Avatar
Joined Aug 2011
Real nice...I love it as well...hope to get a few flights in this week!
http://www.youtube.com/watch?v=_Ni8DjSWDPg
Old Sep 27, 2011, 03:03 AM
ohaussie is offline
Find More Posts by ohaussie
QLDer Living The Dream in PNW
ohaussie's Avatar
United States, WA, Seattle
Joined Oct 2010
Here's Mine...
If anyone has a 4mmm shaft from the retracts they aren't using I sure would appreciate it. I've bent the one from my nose gear and don't really want to buy a whole new retract set...
ohaussie is offline Find More Posts by ohaussie
Old Sep 27, 2011, 05:53 AM
kydawg1's Avatar
Joined Mar 2007
Originally Posted by ohaussie View Post
Here's Mine...
Love that paint scheme.....I wish we could get that those here stateside. Very nice plane. How is she flying for you?
I do not have a 4mm landing gear wire mount..... might check with the hobby shop you bought your plane. They might sell 4mm spring steel rod.
Old Sep 27, 2011, 03:54 PM
ohaussie is offline
ohaussie's Avatar
Joined Oct 2010
She's flying very well.. already asked the hobby shop, they wanted to sell me a new set of retracts for $79....
Old Sep 27, 2011, 06:33 PM
jeta1 is offline
Find More Posts by jeta1
jeta1's Avatar
Australia, WA, Perth
Joined Apr 2011
Hy ohaussie i have the same jet you have ,im running a 6s 5000 mah lipo in mine and i get about 6/7 mins with throttle management i was wondering did you keep the original esc in yours if so how did you find the heat from the esc was it very hot or just warm.
Regards,
Rob............
jeta1 is offline Find More Posts by jeta1
Old Sep 28, 2011, 06:57 AM
ohaussie is offline
ohaussie's Avatar
Joined Oct 2010
Regards,
Rob............
Rob,
I've got the original esc , whilst I'm only currently running 6s3000's , it seems to be only warm after each flight. I do have it sitting in the airflow though.. Statically it's pulling 65-70 Amps at full throttle.
Brett
Old Sep 28, 2011, 10:56 AM
Mike_Then's Avatar
Joined Apr 2001
I flew mine yesterday three times but had a lot of problems on takeoff... had to abort twice and I haven't had to do that since activating flaperons. While it wasn't hot yesterday, it was very humid and I wonder if that had anything to do with it. It seemed down on power and isn't as fast as it usually is. Even my 600-sized electric heli seemed down on power. It was very strange.
I fly a 6s 5000 mAh pack and get 5 minutes with throttle management. That gives me time to go around a time or two if I have to abort landings.
Old Sep 29, 2011, 02:41 AM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
That's weird I had the similar problem the same day. Plane/batteries did not have the same speed n seemed to lack the usual power they have. I use 6s 4000mah 40-50c packs 3 turnigy & 3 Blue lipo. It's been months since I've had a bad landing with this plane & it seemed every landing, but 1 gave me trouble. 1st landing required 3 go arounds n really sweated my battery hitting LVC. 2nd-4th all gave me trouble & 6th broke my main retract mount. Went home really bummed so I charged my packs over night fixed n fab'd a new retract mount n headed out today. She flew great! Must've been some atmospheric phonomenom, lol!
v8truckin is online now Find More Posts by v8truckin
Old Sep 29, 2011, 02:49 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Regards,
Rob............
I found my stock esc was getting hot after a single flight , so I would fly it every other flight as I rotated planes. Didn't used to happen so not sure what caused it. I decided I would disable the bec from the stock esc n add a separate CC bec. This seemed to do the trick, esc is warm after 2 consecutive flights. It's usually the bec that makes n esc get hot. Most built-in bec's are of the linear type. They lower voltage by wasting off the excess as heat, so inturn your esc heats up. Try it out, if it doesn't work upgrade the esc.
Old Sep 29, 2011, 04:44 AM
benjo is offline
Find More Posts by benjo
Pointy end at the front.
benjo's Avatar
Joined Aug 2009
I bought a singular retract for mine. It came from PW-RC, its better than buying a full set. THeyre cheap enough.
I havnt flown mine since i crashed with with gopro camera on board. Shes just about sweet to go. Main thing stopping me is I got no gear doors
benjo is offline Find More Posts by benjo
Old Sep 29, 2011, 10:04 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
How bad was the damage? What/how much did u have to repair?
Build Log CRASHED Hobby Lobby F-35 Lightning II re-build. (YES, it's possible) denial15 Foamy EDFs 53 Dec 04, 2015 04:02 PM
Article Hobby Lobby eRC 90mm F/A 18E Super Hornet EDF Bajora Foamy EDFs 92 Jul 13, 2015 01:57 AM
Article Hobby Lobby F/A-18 Hornet ARF Review dawnron1 Foamy EDFs 2087 Jan 07, 2011 11:54 AM
Discussion My Hobby Lobby F-18 Hornet anyairrc Foamy EDFs 3 Feb 07, 2008 10:24 PM
For Sale Hobby Lobby F/A 18 Hornet Lipo & Electronics itspat Aircraft - Electric - Power Systems (FS/W) 0 Jan 08, 2008 01:33 PM
