Old Jul 23, 2011, 06:48 AM
benjo is offline
Find More Posts by benjo
Pointy end at the front.
benjo's Avatar
Joined Aug 2009
Originally Posted by Mike_Then View Post
Yup, check out Post #128. Just had to mod the battery compartment slightly (read: hog out foam) and it fits fine.
CooL! I take it that its just going to need a large amount more up trim
benjo is offline Find More Posts by benjo
Old Jul 26, 2011, 01:07 PM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Does anyone know the scale of this plane, ie 1:5, 1:10, etc? I'm looking to repainted mine and replace the decals possibly a different fighter group but don't what size scale decals. Thanks!
v8truckin is online now Find More Posts by v8truckin
Old Jul 27, 2011, 12:39 PM
F-86FLIER4LIFE is offline
Find More Posts by F-86FLIER4LIFE
Landin' On The Canopy BAD
F-86FLIER4LIFE's Avatar
Lee's Summit, MO
hey guys, quick question. I had a not to great landing with my jet, and from now on, every time i land, the wheels get flipped up, its kind of hard to explain, but there is a screw on the retracts you tighten down to keep them held into place, but thats screw isn't holding it, any suggestions?
F-86FLIER4LIFE is offline Find More Posts by F-86FLIER4LIFE
Old Jul 27, 2011, 11:10 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Believe your talking bout the axle... Correct? If so, I had that problem, but it was only on a hard landing. The only thing I can suggest is to turn the bent part of the axle to 12 o'clk. By looking @ mine it is @ about 4 or 5 o'clk. This should stop the axle from rotating. Make sure the wheels can still retract n the retracts don't bind, if all is good take it for a taxi n then a flight/landing. If that doesn't work chill on your landings. lol!
Old Jul 28, 2011, 07:59 AM
benjo is offline
benjo's Avatar
Joined Aug 2009
Yeah, turn it so its always up and put bigger wheels on it if the nose up look bothers you, it needs bigger wheels anyway so it looks more scale.
Old Jul 28, 2011, 11:16 AM
jlorenco is online now
Find More Posts by jlorenco
United States, CA, Shingle Springs
Joined Jul 2007
I had a problem with the axles holding and it affects the wheel alignment. If the axles rotate, the wheels no longer track straight. What worked for me was to remove the axle and set screw that holds it, apply locite to them and re assemble everything making sure the axle is rotated so the wheel is aligned with the fuse centerline. Mine have never moved since.
jlorenco is online now Find More Posts by jlorenco
Old Jul 28, 2011, 08:47 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Oops! Forgot to mention that. Mine also didn't track straight n almost led to a few head ons with a tree. Thats how i figuered out the axles had rotated on me. I kept adjusting the nose wheel n it seemed take offs were a horror. Finally figured it out. So u wanna make sure those rear wheels have the same alignment. Once I retightened they haven't moved since, hope u have luck.
Old Aug 13, 2011, 02:30 PM
AJ5000 is offline
Find More Posts by AJ5000
Foamy Pilot
AJ5000's Avatar
United States, CA
Joined Jun 2011
Have any imporments been made to the ARF or kit version? In other words has a V2 model been released?
AJ5000 is offline Find More Posts by AJ5000
Old Aug 30, 2011, 08:45 AM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Not that I'm aware of... Hobby Lobby shows October as the next "expected in stock" date and doesn't mention anything about a V2 version. I seem to remember that the Eurofighter was out for quite some time before a V2 was released. Unless the F/A-18E was a hot seller, I doubt V2 version will be developed and/or released. The wait for October is probably just another production run, and unless they fly off the shelves, look for this run to be the last. That's just my opinion of course.
Mike_Then is online now Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Sep 02, 2011, 06:33 AM
kydawg1 is online now
Find More Posts by kydawg1
"Aircraftus Fragmentum"
kydawg1's Avatar
United States, MI, Detroit
Joined Mar 2007
Boy I hope not...I sure do like this bird. I was hoping for another color scheme or 2. If you are right, I will need to find a couple current scheme spares for the hangar.
kydawg1 is online now Find More Posts by kydawg1
Old Sep 02, 2011, 10:00 AM
Mike_Then's Avatar
Joined Apr 2001
I hope not as well, but unless demand is high they won't do anther run and/or another version. It's the same for me... if they ever get the airframe-only in stock, I'll certainly pick one up as I sure love mine.
Old Sep 02, 2011, 12:03 PM
neversommer is offline
Find More Posts by neversommer
neversommer's Avatar
Luzern/Switzerland
Joined Aug 2008
Freewing won't be producing another Version 2 of the F-18 Super Hornet.
Freewing as of now stopped production on future new Jet releases as of such, they are focusing now mostly on propeller driven planes, but we may get a surprise.
My V.2 Reloaded F-18 is getting ready for build very soon.
All it is, is a airframe only kit with a powerful 8S Power Fan with a 5000 or 5400mah hyperion 35c battery pack.
I realized that due to my high power setup..the wings are starting to crack quite a bit when moving them, there is a lot more wing movement over time and due to the sun you can see that the epoxy turned kinda yellowish color.
I was absent for a good 3 months now..3 months without flying..but my new F-18 airframe still sitting in the box for now 2 months is getting ready for take-off..
I will glue the elevator onto the fuselage because I don't think it may handle 4.7 kg worth of thrust.
NS.
neversommer is offline Find More Posts by neversommer
Old Sep 07, 2011, 11:21 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
pics
I love the way this plane flies & lands. Finally got my wife to take some shots. hope you guys like!
Old Sep 08, 2011, 12:26 AM
Mike_Then's Avatar
Joined Apr 2001
Great pics! Thanks for sharing!
Old Sep 08, 2011, 01:01 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Thanks Mike!
I hope they don't stop making this plane also, but I got me a spare kit in the closet just incase. Shoot, thinking about keeping 2 spares in the closet now.
Build Log CRASHED Hobby Lobby F-35 Lightning II re-build. (YES, it's possible) denial15 Foamy EDFs 53 Dec 04, 2015 04:02 PM
Article Hobby Lobby eRC 90mm F/A 18E Super Hornet EDF Bajora Foamy EDFs 92 Jul 13, 2015 01:57 AM
Article Hobby Lobby F/A-18 Hornet ARF Review dawnron1 Foamy EDFs 2087 Jan 07, 2011 11:54 AM
Discussion My Hobby Lobby F-18 Hornet anyairrc Foamy EDFs 3 Feb 07, 2008 10:24 PM
For Sale Hobby Lobby F/A 18 Hornet Lipo & Electronics itspat Aircraft - Electric - Power Systems (FS/W) 0 Jan 08, 2008 01:33 PM
