Old Apr 13, 2011, 02:08 AM
jb0005 is offline
Find More Posts by jb0005
FLY HARD OR FLY HOME TO MUMMY
jb0005's Avatar
Joined Jan 2011
real sorry to hear that, i almost had to dead stick my t45 this morning because i pushed it too far, i'd hate to do it with the hornet. what sort of flight times were you getting out of the hornet while still leaving a bit in reserve?
jb0005 is offline Find More Posts by jb0005
Old Apr 13, 2011, 03:21 AM
firehawkzach is offline
Find More Posts by firehawkzach
firehawkzach's Avatar
United States, TX, Fort Worth
Joined Jan 2011
Well I could consistently get 4 minutes+ before the fiberglass. Now that I have added more weight it seems that I hit Low Voltage cutoff just over 4 minutes. I tried to repair the nose but it just is not working lol. Guess I'll have to order a new airframe and lay down some glass during assembly.
firehawkzach is offline Find More Posts by firehawkzach
Old Apr 13, 2011, 03:40 AM
jb0005 is offline
jb0005's Avatar
Joined Jan 2011
was wondering also where you got your replacement tyres/wheels, are they the same as stock or different size.when i had a look at my local hobby shop today all the wheels seemed fatter with smaller hubs and the hole for the axel was too large
Old Apr 13, 2011, 03:42 AM
Joined Jan 2011
I got a new set of tires with another set of freewing retracts that were given to me.
Old Apr 13, 2011, 07:24 AM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Sorry to hear about your mishap. I did away with the gear doors on mine from the very beginning as they proved to be more trouble than they are worth.
Mike_Then is online now Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Apr 16, 2011, 09:55 AM
Wideopen is offline
Find More Posts by Wideopen
Bermuda
Joined Dec 2004
Hey guys, does someone have the programming for a futaba 10c radio for this jet, I need some help, I would like to use the thrust vectoring.
Wideopen is offline Find More Posts by Wideopen
Old Apr 16, 2011, 02:46 PM
Jagzilla is offline
Find More Posts by Jagzilla
I fly for Beer
Jagzilla's Avatar
Chilliwack, B.C. Canada
Joined Sep 2004
I'm thinking about getting this one, or the Eurofighter. Not sure which, any comparisons between the two you guys can offer?
I wanted to ask what type of foam this is? I don't see any mention in the ads of what the foam is.
Also, is the wing sparring sufficient? I haven't had time to read all this thread, but from what I've read so far I haven't seen any mention of people needing to mod the wings to prevent them from folding up.
The freewing fan, is it decent? I have a het motor I was thinking of just chucking into the stock fan. I would of course balance the fan first. Hope this isn't too many questions all at once, but I am curious about this one and the Eurofighter.
Jag
Jagzilla is offline Find More Posts by Jagzilla
Old Apr 16, 2011, 07:44 PM
Geurin is offline
Find More Posts by Geurin
United States, AL, Southside
Joined Jun 2006
Hand launching and belly landing, anybody fly this way? If so did you remove the landing gear? Where I fly is kind of ruff grass and I don't think the landing gear would hold up. Thanks. Drue
Geurin is offline Find More Posts by Geurin
Old Apr 16, 2011, 10:58 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Firehawk , could you post some pic's of your mishap?? Where do you fly at??
capt soap is offline Find More Posts by capt soap
Old Apr 17, 2011, 06:12 PM
jb0005 is offline
jb0005's Avatar
Joined Jan 2011
Jag
i've been flying mine for a couple of weeks now and i do quite a bit of aerobatics, with and without thrust vectoring on, and i've seen no structural problems at all. having said that i don't go throwing the sticks around with the vectoring on until i've let it slow down a lot first to reduce the g and strain on the airframe.i don't think anything would be bulletproof if you don't exercise a little restraint. as for the fan, this is only my second edf and my other edf is stock too, but i can tell you it's plenty fast enough as it is stock
Old Apr 18, 2011, 12:18 AM
Joined Jan 2011
I fly at thunderbird field at benbrook lake and I'll take pics tomorrow. I'm exhausted from the air show today.
I am going to order a new airframe very soon.
Old Apr 18, 2011, 05:29 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Not sure if you want similar or exact wheels...but I had the same prob when I tried to find tires. ne how I used dubro sport 145 up front & dubro sport 186 on the rear. The stock front wheels have a nut on the backside between the wheels & strut so I had to add another on the front side between the wheel & plastic cap. Rear didn't have the nut so I just added 1 on backside & front. They've held up fine after 12 flights & show lil wear. I add a lil foam safe CA along the the edge of the tire & rim just incase. I like the look 2. If not let me know what tires u find.
v8truckin is offline Find More Posts by v8truckin
Old Apr 18, 2011, 08:29 PM
jb0005 is offline
jb0005's Avatar
Joined Jan 2011
thanks for the heads up on the tyres, i'll see if i can get them somewhere local and i'll let you know how i go. i had a think about the problem you have had with your front strut. maybe you could drill a holethrough the collar as you have already done, but then continue it into the strut itself. then just insert a screw which will bind the strut and plastic collar together. if your going to buy a whole new set of retracts it wont hurt to experiment on your existing ones. mine is still solid with the glue i applied but if it comes loose again this is what i'll try next.
Old Apr 19, 2011, 12:18 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Ya that's exactly what I did, after the 1st try was unsuccessful. It seems to have done the job. My new retracts will be arriving tmrw, so now I'll have spare everything.
Old Apr 19, 2011, 09:14 AM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
Flight report, two flights on the stock setup, vectors working.
Paved runway only. Would not fly this or the Euro on anything but a paved runway, no deep cracks or damage to the surface.
87MPH max speed by radar, even in a dive. (armament was all attached)
tumbles, stalls, erratic flight did not damage anything.
More up elevator helps, added this after the first flight.
No issues with the factory retracts or nose gear doors
Lands slow
After the flight, two guys went to order one....contact the sales manager at Hobby Lobby or the manager at local store....I negotiated 370 out the door, a non sale price. This is 50 bucks off, or better than a 10% discount. If you have the balls it will work. Otherwise, hope for a flash sale on Wednesdays. Got the Euro on Flash Sale for 289 plus shipping.
SCALEFAN is offline Find More Posts by SCALEFAN
Build Log CRASHED Hobby Lobby F-35 Lightning II re-build. (YES, it's possible) denial15 Foamy EDFs 53 Dec 04, 2015 04:02 PM
Article Hobby Lobby eRC 90mm F/A 18E Super Hornet EDF Bajora Foamy EDFs 92 Jul 13, 2015 01:57 AM
Article Hobby Lobby F/A-18 Hornet ARF Review dawnron1 Foamy EDFs 2087 Jan 07, 2011 11:54 AM
Discussion My Hobby Lobby F-18 Hornet anyairrc Foamy EDFs 3 Feb 07, 2008 10:24 PM
For Sale Hobby Lobby F/A 18 Hornet Lipo & Electronics itspat Aircraft - Electric - Power Systems (FS/W) 0 Jan 08, 2008 01:33 PM
