High Orbit.....
Joined Jun 2009
Does the stabilator hit servo arm linkage? I'd put the clevis on the servo arm and the Z bend on the control horn so that the wire doesn't touch or get hung up against the stabilator. Either way try putting the link in the inner most hole of the servo arm and then starting from the outer most hole of the control horn move in to reach your maximum servo resolution and surface travel. You can set travel on the TX to 125% also. I found if done right you don't need a high low setup. I found especially on take off or flying slow you want a lot of throw but very fine movement. This can be optimized mechanically first before adding expo. It less stress on the servo too. |
I know the fuse is lower than it seems as there's grass stains on the bottom of the plane that did not come from my belly landing. Bigger wheels will help but it will be a challenge to mount them due to the unique axles. |
Latest blog entry: Chaos 600 ESP build
The main wheels are 2" and the nose wheels are just a hair under 1.5". Sorry for the video quality, I edited out the worst parts. Got to remember to take the camera off continuous auto-focus in video mode.
Great news!!
I was in the shop tonight looking at my F/A-18. I was talking with a friend and club member (who wasn't there for the maiden flight yesterday) about my wheel and landing gear dilemma. I really don't have a whole lot of options due to the way the axles are bent to make the wheels sit straight. He had a quick and simple suggesion... simply solder some brass tubing to the existing axle and I can fit any wheel on there that I want! What a fan-flippin'-tastic idea! I'm going to his place tomorrow to pick up some tubing that will fit the wheels I am thinking of using. I'm going to start with 2" in the front (up from just under 1.5") and 2.5" wheels in the back (up from 2"). The plane should roll smoother and faster on the runway, which may help alleviate my takeoff issues. I've already checked and the bigger wheels will fit up front with no mods necessary (with room for even bigger wheels), and the rear wheel wells will only have to be slightly modified to fit the 2.5" wheels.
I'm also going to mix in flaperons, as that may help as well. I measured my elevators and I have exactly 2" of throw on high rates. I have room for more if I need it. I'm VERY excited about what seems to be a simple solution to my problem. I'll be sure to post pics of my progress. |
@Mike
Since the Elevators are 1 big surface to move, one thing I am always concerned of is how tight the elevators are? If you move them are they flimsy? Like do you have a lot of play? In Neutral Position can you move the elevator up and wiggle it? Is it kinda loose? Reason me asking is that in case you may upgrade to an 8s setup like which I intend to, I am curious to have tight or loose they are. I hope you get what I mean. You have a very large moving surface, connected to a rather small connection to hold the elevator in place. Let me know Mike please if that is the case..I will find out about it tonight hopefully anyway. Regards Neversommer. |
High Orbit.....
Joined Jun 2009
Be very careful removing the servos though. Use some spirits or oil to free it up first. The ones on my Euro would not let go like the others and took a chunk of foam with it. |
| Thread Tools | |
| Article Hobby Lobby eRC 90mm F/A 18E Super Hornet EDF | Bajora | Foamy EDFs | 89 | Apr 11, 2013 09:59 PM |
| Build Log CRASHED Hobby Lobby F-35 Lightning II re-build. (YES, it's possible) | denial15 | Foamy EDFs | 49 | Dec 21, 2011 01:24 PM |
| Article Hobby Lobby F/A-18 Hornet ARF Review | dawnron1 | Foamy EDFs | 2087 | Jan 07, 2011 11:54 AM |
| Discussion My Hobby Lobby F-18 Hornet | anyairrc | Foamy EDFs | 3 | Feb 07, 2008 10:24 PM |
| For Sale Hobby Lobby F/A 18 Hornet Lipo & Electronics | itspat | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 08, 2008 01:33 PM |
