Old Feb 07, 2013, 06:54 PM
firehawkzach is offline
Find More Posts by firehawkzach
firehawkzach's Avatar
United States, TX, Fort Worth
Joined Jan 2011
CS12 combo link
http://www.x-flight.com.hk/index.php...&more=&lang=en
firehawkzach is offline Find More Posts by firehawkzach
Old Feb 07, 2013, 07:07 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Originally Posted by firehawkzach View Post
Hey V8 you running a 1500kv motor instead of the 1600kv? I ordered the combo from x-flight. Does it come assembled and balanced?
mmflytie,
If you watch his video on page 169 you will see the differences of the CS12 combo. The stock unit is not bad but there is a noticeable difference in V8's video.
yes im running a lower kv motor 1500kv flyfly outrunner which is balanced myself. It provides similar amp draw as the stock setup but 1:1 thrust. 1600kv xflight combo is a more powerful setup but at a higher amp draw. So I was happy with my 1500kv setup. I've heard the xflight combo is balanced but not sure how good, make sure you check it 1st.
v8truckin is offline Find More Posts by v8truckin
Old Feb 07, 2013, 07:09 PM
Joined Jan 2011
Cool thanks for the heads up. What is the amp draw on the 1600? Looking forward to the remaiden.
Old Feb 07, 2013, 07:54 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
1600kv hobbytopgun inrunner im using with cs12 (not the xflight combo) is 92a static vs 76-78a static on the 1500kv.
Old Feb 07, 2013, 08:00 PM
Joined Jan 2011
Hopefully my ice 100 is up to the task. I changed my mind because I didn't want the extra weight of the receiver battery and want to keep my 120hv with my 8s set up.
Old Feb 07, 2013, 08:08 PM
sjw985 is offline
Find More Posts by sjw985
It's watts for dinner
United States, GA, Marietta
Joined Oct 2011
My x-flight settles in the low to mid 90s on a fresh batt, but either the setup or my meter shows a spike if you goose it on a fresh bat (it has recorded a 102A peak). Hobbywing Platinum Pro 100A ESC and I fly with throttle management. I've never been a full-time full-throttle type.
sjw985 is offline Find More Posts by sjw985
Old Feb 07, 2013, 08:36 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
ya use the same HW platinum pro 100a esc on my 1600kv on my euro and its fine. Inflight those static 90a reads drop.
Old Feb 08, 2013, 10:46 PM
mmflytie is offline
Find More Posts by mmflytie
mmflytie
mmflytie's Avatar
United States, FL, Clermont
Joined Oct 2011
Okay: Thanks guys for all your help. I did the inverted test flight and ended up moving the battery back towards CG by about 1 3/4". Seemed to help with the rotation on takeoff. I will adjust the elevator to be 1/4" below fuse seam line tomorrow at the field.
Thank you for the link to xflight. I ordered the 1600kv 12 blade fan. I am assuming I cannot use my 85amp ESC that came in the jet? What should I get...100Amp? ( I'm running 6s 3700 and 4200mAh 65C and 35C respectively.)
Marc
mmflytie is offline Find More Posts by mmflytie
Old Feb 08, 2013, 11:25 PM
Joined Jan 2011
I bought a castle ice 100 and I think it will be fine. I was shocked at how fast my fan/motor shipped. One hour after ordering and I already had a tracking number.
Old Feb 09, 2013, 12:44 AM
Aros.MotionRC is offline
Find More Posts by Aros.MotionRC
Shameful Warbirdaholic.
Aros.MotionRC's Avatar
Maple Valley, WA
Joined Apr 2006
I can't think of a better combo of plane and power plant in all my years of flying. The Freewing F/A-18 and the CS12 Blade/1600. A match made in heaven at a fantastic price.
Yes indeed, a Castle 100A is the final touch.
Aros.MotionRC is offline Find More Posts by Aros.MotionRC
Site Sponsor
Old Feb 09, 2013, 08:14 AM
sjw985 is offline
Joined Oct 2011
The Hobbywing Platinum Pro 100 is a good match too, and a little cheaper. 150A burst so you have plenty of headroom. I have almost all Hobbywing stuff in my planes (Platinum Pro ESCs and HV UBECs) at this point and haven't had a single failure.
Falcon Sekido is the official US distributor. Fast shipping & decent pricing, plus you know they aren't clones.
http://www.falconsekido.com/products...100a-pro-esc-1
Old Feb 09, 2013, 09:57 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Sjw,
+1 on that love HW & their platinum pro series
Old Feb 09, 2013, 12:42 PM
scunna is online now
Find More Posts by scunna
scunna
scunna's Avatar
United Kingdom, England, South Shields
Joined May 2007
Originally Posted by foom_xiong View Post
NEED HELP...
Hi Ya, I recieved my freewing f-18 yesterday. After assembling, uprading the landing gears, and putting in a 5300 mah Gen Ace battery, this plane turns out to be a race car. Is my bird too heavy to fly? Will a 12 blade Changsun EDF unit with the stock freewing motor and a 100amp Turnigy ESC solve my issue? Should I go back to stock freewing landing gears? Before I put back the stock freewing landing gears, I would like to hear your comments. Here are my stats.
2100g f-18
752g Battery 5300mah Gen Ace
420g Oleo f-18 Landing Gears
Did you fly your f-18 as i have the same landing gear. mine is 7 pounds pulling 3200 watts with cs12 on 8s
3272g
186g - freewing landing gear
3086g F-18 Gross Weight
2395.5g thrust
Did you fly your f-18 as i have the same landing gear. mine is 7 pounds auw pulling 3200 watts with cs12 on 8s thrust 7 pounds ish
scunna is online now Find More Posts by scunna
Old Feb 09, 2013, 04:35 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
I have the castle 100 lite, how does the hobby wing compare? Is there really any difference? The Hw looks alot bigger. Is it reliable?
capt soap is offline Find More Posts by capt soap
Old Feb 09, 2013, 04:47 PM
Joined Jan 2011
Performed ESC surgery today and they tried to deliver my fan but I failed to hear the doorbell lol. I did get the esc so I got everything soldered and tested it on the stock unit. Redelivery on Monday and I will be set. Weather tomorrow is supposed to suck so at least I'll never have to fly it on stock again
Build Log CRASHED Hobby Lobby F-35 Lightning II re-build. (YES, it's possible) denial15 Foamy EDFs 53 Dec 04, 2015 04:02 PM
Article Hobby Lobby eRC 90mm F/A 18E Super Hornet EDF Bajora Foamy EDFs 92 Jul 13, 2015 01:57 AM
Article Hobby Lobby F/A-18 Hornet ARF Review dawnron1 Foamy EDFs 2087 Jan 07, 2011 11:54 AM
Discussion My Hobby Lobby F-18 Hornet anyairrc Foamy EDFs 3 Feb 07, 2008 10:24 PM
For Sale Hobby Lobby F/A 18 Hornet Lipo & Electronics itspat Aircraft - Electric - Power Systems (FS/W) 0 Jan 08, 2008 01:33 PM
