Old Jan 27, 2013, 06:04 PM
voxel is offline
Find More Posts by voxel
United States, FL, Altamonte Springs
Joined Jun 2012
I have the xflight 1600kv combo. I'm thinking of using the new CC 90A talon and saving the 100A I have for some wing else. Xflight says 86A max but what is the real world amp draw?
voxel is offline Find More Posts by voxel
Old Jan 27, 2013, 06:44 PM
sjw985 is offline
Find More Posts by sjw985
It's watts for dinner
United States, GA, Marietta
Joined Oct 2011
On a fresh batt I've seen peak 102, mid 90s sustained with my GensAce 3700 35C. Again it's in the Freewing shroud so I'm not sure if that makes any material difference.
sjw985 is offline Find More Posts by sjw985
Old Jan 27, 2013, 06:52 PM
firehawkzach is offline
Find More Posts by firehawkzach
firehawkzach's Avatar
United States, TX, Fort Worth
Joined Jan 2011
So it would seem maybe a hobby wing 150 or a CC 120 would be good then? I like to have some headroom on the esc if possible.
firehawkzach is offline Find More Posts by firehawkzach
Old Jan 27, 2013, 08:48 PM
sjw985 is offline
Joined Oct 2011
I think you'll be fine with a Hobbywing Platinum Pro 100. It's rated for 10 second bursts at 150. I mounted mine where it gets good airflow and I have no worries whatsoever. I get mine from falconsekido.com.
Old Jan 27, 2013, 09:03 PM
sjw985 is offline
Joined Oct 2011
Here's how I mounted mine so it would be secure, but have good cooling:
Old Jan 28, 2013, 12:01 AM
voxel is offline
Joined Jun 2012
Just installed the xflight cs12 1600kv combo with a Turnigy K Force 100A ESC. Very little cutting of foam. The cs12 shroud is slightly longer than stock and has triangular side mounts (with one screw on each side) instead of flat ones (3 screws per side). Could be a 15-30 minute job at worst.
I could also epoxy the shroud to the fuselage but decide on something less permanent. I'm sure the single screw is fine but I tend to overdo everything
EDIT: other differences
Stock motor and fan - 334g
CS12 1600kv - 352g
Both use 4mm bullets. Unfortunately I put 3.5mm bullets on my ESC and temporarily used adapters. Will fix later.
Old Jan 28, 2013, 12:37 PM
joe1 is offline
Find More Posts by joe1
United States, OH, Dresden
Joined Mar 2004
Color
Hi Everyone :=}
Got a stupid question, I don't see like I use too by no means .
I have been painting my Strykers and some others fluorescent orange on top and fluorescent yellow on bottom in order to see them at some distance .
Has anyone had trouble seeing this out say 4 to 500 yards away, as I do not really want to take the miltary look away from this nice looking jet.
joe1 is offline Find More Posts by joe1
Old Jan 28, 2013, 01:04 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
My old eyes are struggling to see 30 inch jets at 1500 ft. I lost orientation, at least I was able to land/crash at a flat aditude. Flying in the last 5 minites of daylight got me again. No orange on my f-18. Just got to fly closer.
capt soap is offline Find More Posts by capt soap
Old Jan 28, 2013, 01:43 PM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
1500 feet distance is a very long ways off for a small plane like this. The only planes I fly that far away are my powered sailplanes because I know that they can be powered off and glide for a while. And those are accented with bright red tape. Even then, they can easily disappear if you take your eyes off it for even a second. An EDF like this is not what one would consider a good glider. 500 feet is already too far even though I can still see it.
A sailplane is flown far away because that's the nature of the philosophy of flying such aircraft. When I fly my scale jets, I want them close enough to see their details. I can't imagine flying them so far away that I can't even tell what it is, let alone taking away from the military look.
xviper is online now Find More Posts by xviper
Old Jan 28, 2013, 02:24 PM
joe1 is offline
Joined Mar 2004
F-18
OK , just wanted to see how far most are flying this, and the distance I gave was just as a reference point.
I thank everyone for their input .
I do fly very high and far away :=}}
Old Jan 28, 2013, 03:21 PM
Joined Jan 2011
Hope to order my jet tonight or tomorrow if no other unexpected expenses pop up between now and then. Probably going to fly on the stock power at first then upgrade later! Looking forward to getting this jet back in the air as I have missed it bad.
Old Jan 28, 2013, 03:35 PM
Aros.MotionRC is offline
Find More Posts by Aros.MotionRC
Shameful Warbirdaholic.
Aros.MotionRC's Avatar
Maple Valley, WA
Joined Apr 2006
I have what I consider excellent vision but I won't fly a jet too far away. At a certain point, you're going to have a hard time with orientation regardless of quality of vision. I always keep my planes within reasonable distance not just for orientation purposes but in case of emergency and I need to get her back to the runway in a hurry.
Aros.MotionRC is offline Find More Posts by Aros.MotionRC
Site Sponsor
Old Jan 28, 2013, 04:39 PM
Joined Jan 2011
I have lasik corrected 20/20 and my squall is difficult to see. I never had any issues with my F-18 but I also flew the pattern a lot.
Old Jan 28, 2013, 04:46 PM
joe1 is offline
Joined Mar 2004
Distance
I quess I should fly closer but I find that with height and a little nose heavy .
That I have been able to glide even a flat piece of foam with a couple of stabs and elevons along ways.
I have had to set a few down out at some distance, but I have been lucky.
Also they did not cost the kind of money as the F-18 & all the cost of upgrades and expensive lipo packs cost.
So I will be flying allot closer :=}
Old Jan 28, 2013, 05:35 PM
Maple Valley, WA
Joined Apr 2006
Closer is good. Safe flights make for happy pilots and planes.
Site Sponsor
Build Log CRASHED Hobby Lobby F-35 Lightning II re-build. (YES, it's possible) denial15 Foamy EDFs 53 Dec 04, 2015 04:02 PM
Article Hobby Lobby eRC 90mm F/A 18E Super Hornet EDF Bajora Foamy EDFs 92 Jul 13, 2015 01:57 AM
Article Hobby Lobby F/A-18 Hornet ARF Review dawnron1 Foamy EDFs 2087 Jan 07, 2011 11:54 AM
Discussion My Hobby Lobby F-18 Hornet anyairrc Foamy EDFs 3 Feb 07, 2008 10:24 PM
For Sale Hobby Lobby F/A 18 Hornet Lipo & Electronics itspat Aircraft - Electric - Power Systems (FS/W) 0 Jan 08, 2008 01:33 PM
