Old Jan 27, 2013, 11:17 AM
United States, OH, Dresden
Joined Mar 2004
F-18
I remember reading that there was one or two that was hard to install if you had to.
I hope them ones are installed.
joe1 is offline Find More Posts by joe1
Old Jan 27, 2013, 11:19 AM
Shameful Warbirdaholic.
Aros's Avatar
Maple Valley, WA
Joined Apr 2006
v8, didn't you have a comparison/breakdown between the CS12/1500 and CS12/1600?
Aros is offline Find More Posts by Aros
Old Jan 27, 2013, 11:31 AM
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Aros,
Thought I did but couldn't find it, but here's my 1600kv specs
http://www.rcgroups.com/forums/showp...postcount=5308
v8truckin is offline Find More Posts by v8truckin
Old Jan 27, 2013, 11:56 AM
scunna
scunna's Avatar
United Kingdom, England, South Shields
Joined May 2007
V8 what was your all up weight of hornet ready to go
scunna is offline Find More Posts by scunna
Old Jan 27, 2013, 12:13 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Scuna,
I posted it in post #2578
AUW - 2347g
Old Jan 27, 2013, 12:21 PM
Aros's Avatar
Maple Valley, WA
Joined Apr 2006
Cool thanks...So what was your assessment again? The 1600 is a little faster?
Old Jan 27, 2013, 12:30 PM
scunna
scunna's Avatar
Joined May 2007
Originally Posted by v8truckin View Post
Scuna,
AUW - 2347g
Thanks v8
Old Jan 27, 2013, 12:33 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
quite a bit faster, id say 10-15mph faster
Old Jan 27, 2013, 01:57 PM
firehawkzach's Avatar
United States, TX, Fort Worth
Joined Jan 2011
These combos run on 6s at a higher mah battery? If I use a 4000 do I need to upgrade to bigger batts?
firehawkzach is offline Find More Posts by firehawkzach
Old Jan 27, 2013, 02:15 PM
It's watts for dinner
United States, GA, Marietta
Joined Oct 2011
I'm using a GensAce 35C 3700mAh with the x-flight combo (100A Hobbywing Platinum Pro ESC & HW 7.5A BEC). I had to add some tail weight with this battery and there's a little room left in the batt compartment lengthwise, but I think I'm maxed out on batt height and width. So a slightly longer, heavier battery would probably be OK but watch the other dimensions.
sjw985 is offline Find More Posts by sjw985
Old Jan 27, 2013, 02:17 PM
Joined Jan 2011
Cool and what kind of flight times can be expected on 3700mah using throttle management?
Old Jan 27, 2013, 02:22 PM
Joined Oct 2011
Probably 3-4 minutes. I set my timer for 3 minutes. I was flying pretty scale yesterday and I landed with alot of mAH left in the tank (>50%) but I've also had flights with high alpha, vertical, and go-arounds where I landed with 27%.
Old Jan 27, 2013, 02:25 PM
Joined Oct 2011
Oh and it's important to note that I put the x-flight motor and fan in the Freewing shroud. I didn't want to have to cut foam. I don't recall exactly but I think the ChangeSun shroud would be a little heavier.
Old Jan 27, 2013, 02:26 PM
Joined Jan 2011
Cool thanks for all the info. Does the rotor come balanced?
Old Jan 27, 2013, 02:39 PM
Joined Oct 2011
That's why I was asking a few posts up - since I disassembled mine to re-mount it in the Freewing shroud, I rebalanced it and I didn't know first hand. It sounds like it does come pre-balanced. In retrospect, had I know that, I probably would have kept it in the CS shroud and just cut the foam anyway.
Article Hobby Lobby eRC 90mm F/A 18E Super Hornet EDF Bajora Foamy EDFs 89 Apr 11, 2013 09:59 PM
Build Log CRASHED Hobby Lobby F-35 Lightning II re-build. (YES, it's possible) denial15 Foamy EDFs 49 Dec 21, 2011 01:24 PM
Article Hobby Lobby F/A-18 Hornet ARF Review dawnron1 Foamy EDFs 2087 Jan 07, 2011 11:54 AM
Discussion My Hobby Lobby F-18 Hornet anyairrc Foamy EDFs 3 Feb 07, 2008 10:24 PM
For Sale Hobby Lobby F/A 18 Hornet Lipo & Electronics itspat Aircraft - Electric - Power Systems (FS/W) 0 Jan 08, 2008 01:33 PM
