Old Dec 06, 2012, 04:37 PM
sjw985 is offline
Find More Posts by sjw985
It's watts for dinner
United States, GA, Marietta
Joined Oct 2011
Originally Posted by 19000rpm View Post
I've been flying that plane for 2 years without a failure. Where did yours happen?
It was a moderate pullout from a moderately high speed dive, but that was AFTER having some full-throw & TV flipping fun for the better part of a battery. Always possible that my setup was bad or that I weakened something during the acrobatics, I was pretty new to EDFs and TV at the time. But I have been a bit nervious about these foam & pivot mounted control surfaces ever since.
sjw985 is offline Find More Posts by sjw985
Old Dec 06, 2012, 04:56 PM
19000rpm is offline
Find More Posts by 19000rpm
Joined Aug 2009
I guess it pays off to beef up the attachment points with some epoxy. The actual components seem to be strong enough.
The Freewing hinges are worth a look as well. Some are less well glued in than others. The elevator was about to fall off my F-35. I caught it in time.
19000rpm is offline Find More Posts by 19000rpm
Old Dec 07, 2012, 11:22 AM
Evan D is online now
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Is the 3" balance spec good?
Evan D is online now Find More Posts by Evan D
Old Dec 07, 2012, 04:49 PM
19000rpm is offline
Joined Aug 2009
worked for me.
Old Dec 08, 2012, 09:10 PM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Worked for me too, probably should move it back some more, it dives in the turns. Does fly well and has OK thrust and speed. Pretty good for out of the box stock.
Old Dec 09, 2012, 09:46 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
The only thing about the CG is that on grass, you'll burn up a lot of runway getting to rotation speed. I've moved back my 6S 4000 battery some but I'll probably move it back some more.
I've got a couple of other ideas too.
feathermerchant is offline Find More Posts by feathermerchant
Old Dec 09, 2012, 10:08 PM
PAPE is online now
Find More Posts by PAPE
Joined Jun 2012
I got my f18 some time ago, buts its still in the box. Before its a kit and before I build it I wanted to ask if any one has made any reinforcements to the wings. I have seen on videos some flex from the wings and I think some one here had a wing failure.
PAPE is online now Find More Posts by PAPE
Old Dec 09, 2012, 11:45 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
I did. add fiberglass top and bottom off fuse wing joint... that will do!!
capt soap is offline Find More Posts by capt soap
Old Dec 10, 2012, 12:04 AM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Think I added and extra carbon strip/rod forward of the existing carbon tube. However I didn't do it to my current FA18E.
v8truckin is offline Find More Posts by v8truckin
Old Dec 13, 2012, 10:02 PM
foom_xiong is offline
Find More Posts by foom_xiong
Joined Apr 2012
NEED HELP...
Hi Ya, I recieved my freewing f-18 yesterday. After assembling, uprading the landing gears, and putting in a 5300 mah Gen Ace battery, this plane turns out to be a race car. Is my bird too heavy to fly? Will a 12 blade Changsun EDF unit with the stock freewing motor and a 100amp Turnigy ESC solve my issue? Should I go back to stock freewing landing gears? Before I put back the stock freewing landing gears, I would like to hear your comments. Here are my stats.
2100g f-18
752g Battery 5300mah Gen Ace
420g Oleo f-18 Landing Gears
3272g
186g - freewing landing gear
3086g F-18 Gross Weight
2395.5g thrust
foom_xiong is offline Find More Posts by foom_xiong
Old Dec 13, 2012, 10:08 PM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Is it balance right? 3" behind the wing L.E. If that's right is the attitude right? Is the wing at a positive incidence to the runway?
Old Dec 13, 2012, 10:46 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Since the jet is rated for a 3700 mAh battery, it is probably too nose heavy to rotate. Be sure you have plenty of elevator throw and use the thrust hectoring to maximize your pitch rotation.
Old Dec 13, 2012, 11:10 PM
sjw985 is offline
Joined Oct 2011
I think the 5300 will be WAY noseheavy (measure of course). Mine was nose-heavy with the x-flight CS12 / 1600 KV combo and just a 3700 mAH Gensace 35C. My maiden didn't have enough elevator with stock throws.
Check the balance and don't let it be too nose heavy. Set the stabs for maybe a 1/3 inch nose up trim. And give yourself plenty of throw on high rates in case you need it. The plane will land fast anyway, being noseheavy will exacerbate it.
Risk of relying on TV is that when you land if you chop the throttle your nose will pitch down and best case you'll smack hard.
Old Dec 13, 2012, 11:37 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
sjw - You are correct about TV on landing. I just switch the mix off. I find is is much easier to fly at a high angle of attack without it. I am flying with a 4,000 pack and after moving the battery back about 1/4" it still barely rotates from grass. I'm going to move it back more. Also if new gear has been installed, it can affect the CG as well as the main wheel position which can affect takeoff rotation.
Old Dec 13, 2012, 11:59 PM
genghiskt is offline
Find More Posts by genghiskt
genghiskt's Avatar
Joined Sep 2011
Originally Posted by foom_xiong View Post
NEED HELP...
2100g f-18
3272g
2395.5g thrust
5300mah is too heavy. Evan i m on 4500mah push all the way back still nose heavy. Freewing landing gear will work well. You just need to upgrade to the Freewing new metal trunnion.
It will be alright. I fly stock for 60 flights, no problem.
Cheers..
genghiskt is offline Find More Posts by genghiskt
Build Log CRASHED Hobby Lobby F-35 Lightning II re-build. (YES, it's possible) denial15 Foamy EDFs 53 Dec 04, 2015 05:02 PM
Article Hobby Lobby eRC 90mm F/A 18E Super Hornet EDF Bajora Foamy EDFs 92 Jul 13, 2015 02:57 AM
Article Hobby Lobby F/A-18 Hornet ARF Review dawnron1 Foamy EDFs 2087 Jan 07, 2011 12:54 PM
Discussion My Hobby Lobby F-18 Hornet anyairrc Foamy EDFs 3 Feb 07, 2008 11:24 PM
For Sale Hobby Lobby F/A 18 Hornet Lipo & Electronics itspat Aircraft - Electric - Power Systems (FS/W) 0 Jan 08, 2008 02:33 PM
