LX Fan/motor 6S, LX motor mini rotor
Hello all,
Here is what I have tested since all this LX model twin 70mm coming out. I know some people would like to know even knowing that stock is sucks. Here I did two test :1) LX 6S fan/motor =43.3amps 985 watts=3.3lb of thrust 2) LX housing/motor with a mini rotor=40 amps 927watts=2.3lb of thrust Using a plush 80 amp ESC and a set of old 25c rhinos. I ran the mini rotor first and got 2.3lbs. Then plugged up the LX fan up and I was shocked how much of a diffenrence the LX rotor could push! 1lb diffenece! HOLY!!!!Danny mini
LX rotor
I am running into a problem and maybe you can help. I am running LX shrouds with wemo mini rotors and ARC motors. I too would like to try the LX rotors but when I tried to install them I noticed the shafts on the ARC motors are 3.17mm and the shaft adapter for the LX rotors are 4mm ? Does Lx make a 3.17mm adapter ? Any suggestions ?? thanks |
| Thread Tools | |
| For Sale Exceed RC Mini 50MM 2.4Ghz MIG-15 High Performance Ducted Fan Jet w/ Brushless Motor/ | Mikemynameis | Aircraft - Electric - Jets (FS/W) | 14 | Mar 26, 2012 07:49 PM |
| Sold WeMotec Mini 480 EDF Fan unit | die4good | Aircraft - Electric - Power Systems (FS/W) | 1 | Oct 12, 2010 02:14 PM |
| Sold TamJets TJ90MM Fan With Midi Rotor & Motor Setup $400 Shipped | FlyBoyTha1 | Aircraft - Electric - Jets (FS/W) | 3 | Sep 12, 2010 12:50 PM |
| Sold BH/LX 70mm fan 2400KV motor 50A esc & bec | truevine77 | Aircraft - Electric - Jets (FS/W) | 3 | Jun 02, 2010 08:44 AM |
| Discussion Mini Fan 480...where to get rotor/fan only? | Skarn | Foamy EDFs | 3 | May 04, 2009 05:06 PM |
