Old Oct 13, 2010, 03:05 AM
deanz406 is offline
Find More Posts by deanz406
deanz406
deanz406's Avatar
Latrobe, Pa.
Joined Oct 2010
Question
HELP-Mr. Mulligan kit, or plans
Does anyone know who may have a set of plans for a 60 size Mr Mulligan?? I do have a 1/4 scale Nosen already framed up, but really want a 60 sized plane, preferably, something with a 60" wingspan or close. I do remember seeing an ad somewhere years ago, that Jim Pepino could draft up scale plans for almost any size. I don't know if he is still in business. It has been a while since I've flown, and am retired now, and want to get back to flying again. Any info, or ideas would be most welcomed. I've thought about trying to do a scratch one, using a foam core, and adding the stringers, and other structures to the foam base, building a standard ribbed wing, and tail, to keep it in the 6-10 lb range. Thanks for any suggestions.
deanz406 is offline Find More Posts by deanz406
Old Oct 13, 2010, 11:01 PM
markb0127 is offline
Find More Posts by markb0127
Celebrating 300 posts!
markb0127's Avatar
Kirtland, OH
Joined Mar 2010
I may have found something for you. I did a search on Google. I found something on a website called Aviation Trivia.
http://www.aviationtrivia.info/Howar...--Mulligan.php
It mentioned this...
Uncle Willies has plans for sale for a C/L Mr. Mulligan that can be converted to a radio control airplane. Wingspan is 52" and length is 40". It needs a .60 2C engine for power.
Here is the link to Uncle Willie's Mr. Mulligan plans...
http://myunclewilliestoo.com/about58.html
markb0127 is offline Find More Posts by markb0127
Old Oct 14, 2010, 07:44 PM
avaiojet is offline
Find More Posts by avaiojet
Owner of CFC Graphics
Florida
Joined Aug 2008
Do you really need plans or is a good 3-view enough?
Charles
avaiojet is offline Find More Posts by avaiojet
Old Oct 14, 2010, 08:06 PM
piperjoe is offline
Find More Posts by piperjoe
piperjoe's Avatar
United States, MI, Interlochen
Joined Dec 2009
Flying Models magazine offers a .60 size stand-off RC scale Mr. Mulligan plan (CF510 Mr. Mulligan). This plan was by Tony Lombardo, some time back, and should produce a nice model. Check it out at Flying Models/Carstens Flying Plans. You should be able to get the plan and a copy of the original article. Good luck on your build!
Soft landings,
Joe
piperjoe is offline Find More Posts by piperjoe
Old Oct 28, 2010, 10:43 PM
deanz406 is offline
deanz406
deanz406's Avatar
Latrobe, Pa.
Joined Oct 2010
Help- Mr Mulligan
Thank you all for your tips, and hints. I checked out all of the websites that u posted, except the Thunder Tiger website. There are enough pics in them, to get an idea of how I may be able to scratch build my own version, and for me, that would be a really rewarding experience. I do have several 3 view drawings, and still have my original Nosen plans, so I'm going to work on scaling the wing to 1/6 scale, which would give me the 60 " span that i want. I thought about taking the Nosen plane, which hasn't been covered yet, and doing some fuselage designing, using a foam core base, and adding the necessary stringers for the scale look. I think I can scale down the fuselage correctly, with my framed up Nosen plane, and get the measurements, and structure details from it. I'm going to photograph every step of the project, and hopefully, in a couple months, I'll be able to post some of the results. Many thanks for ur input, and help. I just have a thing for high wing cabin monoplanes, and the DGA6 is probably my favorite. Dean
Old Oct 30, 2010, 04:39 PM
KOMET 44 is online now
Find More Posts by KOMET 44
D.G.B.
KOMET 44's Avatar
Southington, Connecticut, United States
Joined Jun 2000
I have a set of plans for a 58" rubber powerd Mr.Mulligan.Pm me if your interested.
KOMET44
KOMET 44 is online now Find More Posts by KOMET 44
Old Nov 10, 2010, 03:55 PM
cauley65 is offline
Find More Posts by cauley65
USA, DE, Dover
Joined Sep 2010
check with stuflyrc@verizon.net, I belived he just finished his Mr mulligan.
cauley65 is offline Find More Posts by cauley65
Old Feb 22, 2011, 02:54 PM
rszanti is offline
Find More Posts by rszanti
Cincinnati, Ohio
Joined May 2002
I have a 52" ws RC version of a Mr. Mulligan picked up at a swap meet. It has ailerons and flaps but the flaps have been glued shut and covered over. I'm wondering why. Any idea of who may have produced a kit of this size ?
Richard
rszanti is offline Find More Posts by rszanti
Old Feb 22, 2011, 08:04 PM
piperjoe is offline
piperjoe's Avatar
Joined Dec 2009
World Engines offered a small RC Mr. Mulligan back in the late '70's - early '80's that was about the size you quote. Fuselage was mostly a lite-ply build; they also offered a J-3 Cub.
Soft landings,
Joe
Old Feb 22, 2011, 11:02 PM
rszanti is offline
Cincinnati, Ohio
Joined May 2002
Piperjoe -
Apparently that's what I have, a Wolrd Engines version, 52"ws, about 400 sq.in. and plywood formers and sides for the fuse. Even has the little Gulf decals up by the cowl. But this one has an engine mount sized and drilled for a very large engine (4" across outside of engine mounts). I thought maybe a 70 four stroke or a 46 sized 2 stroke would be the right fit. Any suggestions ?
Richard
Old Feb 23, 2011, 08:42 AM
piperjoe is offline
piperjoe's Avatar
Joined Dec 2009
Richard, I think you'd have a real handful with the two engines you are considering; if the plane survived it would most likely look like a Sabre jet when it landed LOL!! Since the Mr. Mulligan was a racing aircraft, perhaps that's what the original builder was considering. I don't recall what engines the plane called for but, having built the J-3 Cub of the same size "back then" I think I used something like a .35 at the most. It boils down to what you and the model can handle; bottom line: if it was my plane and seeing as it was built by someone else and considering its age I'd either replace the engine mount for something smaller or strip the covering off the airframe and go over the build and glue joints to look for potential problems that could develope with a big engine on the nose. Also, search for information on this and other sites that will alert you to any problems with this plane.
Soft landings,
Joe
Old Feb 23, 2011, 06:19 PM
rszanti is offline
Cincinnati, Ohio
Joined May 2002
Thanks Joe, I do have a .35 that will work.
Richard
Old Feb 23, 2011, 06:31 PM
piperjoe is offline
piperjoe's Avatar
Joined Dec 2009
Let us know how the Mr. Mulligan does and good luck to you! Maybe a pic or two?
Soft landings,
Joe
Wanted Bud nosen mr. Mulligan plans Kilowatts Aircraft - Fuel - Airplanes (FS/W) 3 Mar 16, 2015 09:52 AM
Contest Funbuild 3 - Howard DGA-6 "Mr. Mulligan"/Pat Tritle plans jofrost Scale Kit/Scratch Built 78 Apr 14, 2011 07:43 PM
Wanted sig stits flutterbug kit or plans paulatgis Aircraft - Fuel - Airplanes (FS/W) 2 Oct 20, 2010 06:38 PM
Wanted Bud Nosen Mr. Mulligan Plans Kilowatts Aircraft - Fuel - Airplanes (FS/W) 0 Mar 17, 2010 04:42 PM
Wanted 3 views, plans or maybe a kit for a Mr. Mulligan??? SteveT. Aircraft - Fuel - Airplanes (FS/W) 2 Jan 04, 2009 09:06 AM
