Old Jul 09, 2003, 01:17 AM
Desert-Racer is offline
Find More Posts by Desert-Racer
Desert-Racer's Avatar
Eagle Mountain, Utah
Joined Mar 2003
What gearbox and prop should I use on a SlowStick with Speed400 motor?
What gearbox and prop should I use on a SlowStick with Speed400 motor (6v)?
I have a couple of these motors, and no $$ for a brushless yet.
I feel like the SS is underpowered at my altitude (Utah), and more power will help with the local wind too.
What gearbox / gearing do I need, and what prop is best.
I run 8 cell packs and a 30amp Jeti SC.
Is it possible to modify the stock gearbox to work?... doesn't seem like it.
Thanks.
Desert-Racer is offline Find More Posts by Desert-Racer
Old Jul 09, 2003, 08:49 AM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Try an MPJet at 5:1 with a 12x6 prop. If you use AAA packs, they won't work very well with a speed 400. Try 950 KANs. Should move the plane right along.
The motor won't fit a GWS box.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Jul 09, 2003, 08:56 AM
sierra-gold is offline
Find More Posts by sierra-gold
Joined Sep 2002
S400 for SS
Or for about $20 you can get a GWS EPS 400 with your choice of gear ratio and of course it mounts on the motor stick.
You could use your existing S400 motors as spares.
Sierra Gold
AMA 12351
sierra-gold is offline Find More Posts by sierra-gold
Old Jul 09, 2003, 09:38 AM
seanpr123 is offline
Find More Posts by seanpr123
seanpr123's Avatar
United States, FL, Boynton Beach
Joined May 2002
Yea, I agree. Get a gws 400C-maybe G gearing. Once I find one around here Im going to be doing the same thing cause my 300C-D keeps dieing with my battery packs... The G gearing seems to be the best when looking at the stat sheet drawing 8.9A and giving 17oz of thrust with the 12x6. Tell us how it works!
seanpr123 is offline Find More Posts by seanpr123
Old Jul 09, 2003, 01:11 PM
Joined Mar 2003
I Certainly will.
Thanks for the info !!
Old Jul 09, 2003, 08:46 PM
seanpr123's Avatar
Joined May 2002
Well it looks like I get to tell a little before you do... IT FLYS AWSOME! I just got back from a flight in my back yard. Climbing is much better although the extra weight does really come into play when gliding... As long as the motor dosnt die quickly I would whole heartdly reccomend using the 400C-G geared motor in replacement for the 300... My friend has a camera and we are putting together a video of us called the "Foam Flying Freaks" but I'll try to get some footage of my new and improved SS and let you guys decide for your selfs.. See ya!
Old Jul 09, 2003, 11:52 PM
Joined Sep 2002
EPS 400
seanpr123 -
Are you flying with 10 cells?
I have read in at least two threads that there is significant difference in performance with 10 as compared to 8. The stat sheets seem to show that also for 2 or 3 of the gear ratios.
Old Jul 10, 2003, 01:19 AM
tomlescal is offline
Find More Posts by tomlescal
braidwood,il.
Joined Dec 2002
slow stik with 400
my slow stik with 400 flew sweet! 12 x8 prop is better.dont worry about the amps,just fly it.crashed it then went to astro 010 with 10x8.chop chop,now we have something.my other slow is not so slow anymore either.i call it the funny stik,funny park wing with a short stik fuse,300 12x8 and 10 cell 720's.talk about climb,it wouldn't stop climbing unless you cut the throttle,also tried the p-51 wing on thiswrong answer.get an E-STARTER it flew great before a bad battery killed it. i love these things
"it's not if it will crash,it is when will it crash" trust me tom
tomlescal is offline Find More Posts by tomlescal
Discussion What size of prop should be used w/ brushed 350 motor on my Slow-stick? kfc2 Parkflyers 10 Aug 12, 2008 07:01 PM
Help! What prop should i use on HXT 35-42A 1450kv martseger63 Power Systems 12 Jun 11, 2007 02:33 PM
What size prop would I use on this motor? randall1959 Electric Plane Talk 15 Sep 28, 2005 04:45 PM
What type of oil should I use on GWS IPS gearbox and motor? The Other Dave Parkflyers 5 Jan 28, 2002 12:47 AM
What prop should I use on a Jeti Brushless 15/4 powered Zagi? Ryan Nau Foamies (Kits) 0 Jul 03, 2001 06:11 PM
