Old Oct 11, 2010, 12:41 PM
learn2turn is offline
Find More Posts by learn2turn
United States, MA, Medfield
Joined Jul 2010
temperature sensor for charger
My B6 has a couple alligator clips for a temp sensor.
I see tons of $3 sensors on ebay that have a rx/batt/servo type connector.
Is that what I want? Then just clip alter the connection to hook it up?
Does that need to be permanently be mounted to a pack or can it just be held against it when charging?
Is there some other one recommended that would be better?
-l2t
learn2turn is offline Find More Posts by learn2turn
Old Oct 11, 2010, 01:42 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
The alligator clips are for charging, the Temperature sensor uses a 3 pins connector as discussed in that thread:
http://www.rcgroups.com/forums/showthread.php?t=778508
Temperature sensors are usually just tapped on the battery,some have a clamp type fixture (Triton,Ice). You need only one sensor which stay with the charger,the charger needs to be programmed for a given cut-off temperature.
coriolan is online now Find More Posts by coriolan
Discussion Temperature sensor for Turnigy Accucel-6? bkboggy Batteries and Chargers 2 Jan 31, 2009 08:43 AM
Infrared temperature sensor rocky79 DIY Electronics 2 Jul 12, 2005 04:38 PM
FS: Triton charger - like new, with temperature sensor & Deans Ultra charging lead kyril Aircraft - Electric - Airplanes (FS/W) 6 Jun 23, 2004 08:42 AM
temperature sensor on triton??? buckeyes1997 Batteries and Chargers 1 Feb 14, 2004 04:58 PM
Temperature sensor? SargeNZ Batteries and Chargers 4 Mar 30, 2003 07:30 AM
