Old Oct 11, 2010, 12:04 PM
Gundy is offline
Find More Posts by Gundy
Blu-Core is my friend
Gundy's Avatar
La Crosse, WI
Joined Apr 2006
Futaba 9c, Dragon Link, Eagle Tree OSD Pro.
I know there are guys that are running this set up.
I just finished my new install in my skywalker.
Everything works great… I would like to use the simple “flip the switch” to test the RTH.
How do I do this?
I have looked at the posts about using the – trim on the throttle, but I am not sure how to get it set.
Later,
Gundy
Gundy is offline Find More Posts by Gundy
Old Oct 12, 2010, 01:27 AM
Blackrat is offline
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
you need to go thru the OSD manual ... its not just flip the switch, you gotta set it all up first, you can see the settings in the OSD menu
Blackrat is offline Find More Posts by Blackrat
Old Oct 12, 2010, 09:21 AM
Gundy is offline
Gundy's Avatar
La Crosse, WI
Joined Apr 2006
Great answer
Originally Posted by billpa View Post
Hi Gundy,
You just need to program the throttle failsafe position in the DL to correspond with a throttle position that you can only reach when you trim down beyond the normal trim point. Then, just run the RTH wizard, and select "PCM" and "1 failsafe" in the Safety Mode menu.
for those who e-mailed me about this...
Later,
Gundy
Help! Eagle Tree OSD Pro, No Aileron Output i-dru Eagle Tree Systems 6 Nov 01, 2010 04:12 PM
Discussion Where can I find RTH Manual Eagle Tree OSD pro? rapghsi FPV Talk 3 Oct 04, 2010 02:11 PM
Discussion Eagle Tree OSD pro package deal dbramley FPV Talk 1 Oct 03, 2010 11:37 PM
Sold Eagle Tree OSD and E-Loggers For Sale avropilot Aircraft - General - Miscellaneous (FS/W) 7 Sep 13, 2010 09:29 AM
Discussion Dragon link RSSI + Eagletree OSD PRO ecampos FPV Talk 2 Sep 09, 2010 12:51 AM
