Old Oct 10, 2010, 03:20 PM
finn is offline
Find More Posts by finn
USA, FL, Middle Keys
Joined Sep 2010
Build Log
1955 37' merritt
In driving back and forth on us1 in the florida keys I would pass a boat in a yard in islamarada that to me looked like what a boat should look like.I stopped one day,took some photos and basic measurements and thought this should be my next project.The next time I went by,the boat was gone.To make a long story short,I found out where it had gone,contacted the new owner and got enough measurements to start.It is a 1955 Merritt,hull number two.Merritt is the most storied sportfishermen name in the world.I have included some pics of BLACK BART,first boat to catch 100 marlin in one year,record holder with a 1646 lb blue marlin,and lost an estimated 3000 lb marlin after an all day and night battle.
The first step was to build a building board curved to the shape of the shear. 4 pieces of cedar,3" x1 1/2" were run through the bandsaw to the shape of the shear and glued together for a total width of 12" and then glued to a 1" piece of plywood.The keel,transom and 5 stations measured from the original were cut out of .250 mahogany and assembled on the board.The shear and chine are each two strips of .125 x .250 mahogany to help with the bend.
finn is offline Find More Posts by finn
Old Oct 10, 2010, 03:30 PM
mrbassman is offline
Find More Posts by mrbassman
mrbassman's Avatar
Chula Vista, Ca.
Joined May 2006
Looks nice ! What's the length of the hull?
It was nice of the new owner to let you measure everything.
mrbassman is offline Find More Posts by mrbassman
Old Oct 10, 2010, 03:31 PM
finn is offline
Joined Sep 2010
1955 37' merritt
An extra member of .250 mahogany was added on the sides where the flare is the greatest to insure the correct flare.The sides are then planked with .062 plywood on the diagonal,then covered with 4 oz cloth and west sys epoxy.
Old Oct 10, 2010, 03:35 PM
finn is offline
Joined Sep 2010
1955 37' merritt
Sorry,1/14 scale,hull is 31.75".The current owner is completing a first class resto,he has a log of his resto if you google "first choice fishing"
Old Oct 10, 2010, 03:53 PM
finn is offline
Joined Sep 2010
1955 37' merritt
The bottom from the bulkhead forward is planked with .063 plywood,and with .125 plywood from the bulkhead aft.the sides are taped off the prevent dripping epoxy on them.The bottom is then covered with 4 oz cloth and west sys epoxy.After curing over night,the hull is cut loose from the building board prison with a razor knife
Old Oct 10, 2010, 04:07 PM
finn is offline
Joined Sep 2010
1955 37' merritt
The front deck bows are cut from ,250 mahogany,epoxied to the frames,planked with plywood and covered with 4 oz cloth and west sys
Old Oct 10, 2010, 04:20 PM
finn is offline
Joined Sep 2010
1955 37' merritt
The transom frames are cut from .250 mahogany,epoxied to the frame and left to cure overnight.I have not had good luck with any of the fast curing epoxy so I only use west system epoxy,The transom,.080 mahogany,is bent and epoxied to the frames.
Old Oct 10, 2010, 05:20 PM
finn is offline
Joined Sep 2010
1955 37' merritt
Shaft stuffing boxes located and epoxied in place.I bought 2 mack 3600 motors,I have never used this type before and hope they will be ok.I still have not decided on weather to have the whole cabin be removable or just the cabin roof.Of course the floor needs to be removable,probably just the center section
Old Oct 10, 2010, 07:34 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Looks like you could have just scaled an Elco 77 footer PT for that hull with the sweet reverse sheer.
patmat2350 is offline Find More Posts by patmat2350
Old Oct 10, 2010, 07:43 PM
frankg is online now
Find More Posts by frankg
Joined Dec 2004
FINN- I think using two counter rotating props (0937/3 and 0937/3R) you will have plenty of speed to plane off that hull with ease as well as get a pretty good run time. Oh and the props are scale 3 blade Michigan Propellers. Just what the boat called for.
http://www.mackproductsrc.com/props_p2.htm
frankg is online now Find More Posts by frankg
Old Oct 10, 2010, 08:50 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Nice!
Aerominded is offline Find More Posts by Aerominded
Old Oct 10, 2010, 11:54 PM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Nice build.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Nov 01, 2010, 02:13 PM
finn is offline
Joined Sep 2010
1955 37' merritt
The rudder stuffing boxes can only be .660" and still stay under the floor.I used the motor mount that came with the mack 3600 motor,but mounted them on their side to keep them as low as possible.I used dumas bronze struts,allowed to self locate with a dummy shaft and epoxied in place.Once cured the 2-56 screws will be installed.I have only 1 of the old style bronze struts left,there was one on ebay that I missed,any help would be appreciated
Old Nov 01, 2010, 03:30 PM
norgale is offline
Find More Posts by norgale
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
That's very nice and neat Finn. Good work on the boat too. What will you use for batt's? Pete
norgale is offline Find More Posts by norgale
Old Nov 01, 2010, 03:35 PM
Boatfox is offline
Find More Posts by Boatfox
Give the dog a bone
Boatfox's Avatar
USA, NV, Las Vegas
Joined Aug 2005
Very nice work. Looks great.
Boatfox is offline Find More Posts by Boatfox
Discussion Nebraska: Merritt Reservoir - Sloping Site? Mitch G Slope 1 Feb 06, 2006 01:43 PM
Looking for the 1955 Miss Thriftway hydroplane swingbozo Scale Boats 7 Nov 30, 2005 02:50 PM
Prop Repair circa 1955 Carnifax Electric Plane Talk 14 Oct 24, 2004 08:40 PM
