Old Oct 10, 2010, 10:16 AM
2400RDR is online now
Find More Posts by 2400RDR
Out of helis, sanity returning
United States, FL, Lake City
Joined Feb 2009
Question
Remedial DLG 101- what am I doing wrong?
My TopSky launches nicely, flies well in trim with hands off and indicates lift well. The problem is that when I fly into lift, the nose goes up, speed drops off, and I enter a gentle stall. If I try to circle in lift, the plane porpoises nose up, stall, nose up, etc.
In the notorious dive test, it seems to be completely neutral and would drill into the ground without recovering or tucking if I let it.
As far as I can tell, CG is withing design parameters- 78-84 mm. I recently moved it from about 81 to 78 out of curiosity, but not much changed.
What am I doing wrong?
Rick
2400RDR is online now Find More Posts by 2400RDR
Old Oct 10, 2010, 10:25 AM
cptsnoopy is online now
Find More Posts by cptsnoopy
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
Sounds like you are trying to fly it too slow. Also, you do need to fly it, you cannot just initiate a turn with the rudder/ailerons and expect it to handle pitch all on its own. Perhaps, your down aileron is traveling further than your up aileron? When you do the dive test are you in the same camber setting as when you try to thermal?
Charlie
cptsnoopy is online now Find More Posts by cptsnoopy
Old Oct 10, 2010, 11:16 AM
jcats is online now
Find More Posts by jcats
Launch high. Fly low.
United States, CA, Lake Elsinore
Joined Aug 2003
+1
Flying too slow with too much elevator are habits that I've been trying to get rid of for the longest time.
Jun C.
Charlie
jcats is online now Find More Posts by jcats
Old Oct 10, 2010, 11:29 AM
grouch is offline
Find More Posts by grouch
Nothing Special
grouch's Avatar
Middletown, CT
Joined Dec 2003
When my nose goes up, I am in sink. The tail goes up, I am in lift. It sounds to me like you are trying to climb in sink and stalling as a result. Apart from the nose, what other indications are you getting to indicate you are in lift?
grouch is offline Find More Posts by grouch
Old Oct 10, 2010, 01:35 PM
Joined Feb 2009
Plane is rising before it stalls
Actually I've gotten fairly adept at recognizing lift from flying the big ones at altitude with a motor glider. I also have a Gambler that thermals nicely when I can throw it high enough to catch a thermal (rarely).
I had some encouragement from a friend who said he found good lift in the neighborhood yesterday (I thought it was over for the year), so I went to fly today. For the first time, I tried using the thermal camber setting in lift, and lo, I was thermalling. Don't laugh- I'm just learning this art.
Anyway, I think what Jun and Charlie said might be the case- flying too slow with too much elevator. Also, I didn't realize that the dive test needed to be done with the wing cambered for thermals. I'll have to try that next time I'm out.
Still open to advice though!
Rick
Old Oct 10, 2010, 01:42 PM
Joined Feb 2009
Charlie-
When you say "down" and "up" aileron, do you mean the direction the aileron actually moves, or the way the wing moves when the aileron is deflected (opposite of the aileron direction).
I know you're speaking of differential aileron here; what is a good setting for that?
Rick
Charlie
Old Oct 10, 2010, 01:46 PM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Canada, ON, Morriston
Joined Apr 2010
LMAO..You are trying to fly a blade wing like a gas bag. Just kidding but it sounds like the glider is twitchy as it is with a rearward C/G and you are just flying to slow
DLGjunkyard is online now Find More Posts by DLGjunkyard
Old Oct 10, 2010, 01:53 PM
Joined Apr 2010
Originally Posted by 2400RDR View Post
Charlie-
Rick
A good place to start is 50 percent SOOOO half as much down is up!
Old Oct 10, 2010, 02:30 PM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
But then Mark Drela recommends no differential.
Gary
GaryO is offline Find More Posts by GaryO
Old Oct 10, 2010, 02:50 PM
rcgeorge is offline
Find More Posts by rcgeorge
usaf3kteam
rcgeorge's Avatar
Joined Sep 2005
When any part of my plane goes up for me it is lift.
rcgeorge is offline Find More Posts by rcgeorge
Old Oct 10, 2010, 05:43 PM
Wave Glider is offline
Find More Posts by Wave Glider
Kyle Clayton
Wave Glider's Avatar
United States, VA, Dinwiddie
Joined Feb 2008
You could also have too much camber dialed in for your thermal camber setting which is slowing you down too much.
Wave Glider is offline Find More Posts by Wave Glider
Old Oct 10, 2010, 11:12 PM
Nathan Schmoekel is offline
Find More Posts by Nathan Schmoekel
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
I'm just getting my Preditor two fine tuned and was having the same issue. I finally discovered that while pulling and holding the elevator for the thermal turn that my thumb was also creeping and adding in aileron. I dialed up the exponential setting on the ailerons to 20% so that when my thumb moved side to side slightly the ailerons would not move so much. That little trick really let the wing foil stay cleaner and I can thermal without falling out now.
I have also found that I like the ~~50% down travel aileron differential set-up. In thermal mode when the wing is cambered I use even more differental (probably around 75% less down travel) to avoid the flap like drag of down traveling aileron.
Gave up on rudder to aileron mixes too, because the ratio is seldom perfect, getting rid of the mix also helped keep me from down circling. I basically tune like I'm flying a rudderless ship, except for the fact that I actually have a functioning rudder. I find the rudder is a must for steering with the flaps fully deployed, which is about 60 degrees down for me. In landing mode my aileron differential is set for zero down movement, 100% up; with 125% rudder mixed to the ailerons.
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old Oct 10, 2010, 11:46 PM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
I personally noticed a large increase in thermalling performance simply by adding aileron differential. It helps keep the wing flatter in the turns for better performance.
Too much camber is also a possibility. My plane is on the heavy side (11.1oz, AG series foils) and really likes to keep the speed up. If I get too slow it stalls, more camber can make the stall sharper and thus make the problem worse. Lately I have been using cruise mode for thermaling (even in the light stuff) and been having better luck. Its also a matter of time with the plane. An hour a day for a week makes a HUGE difference. If you have any desire to compete, you need to practice, practice, and practice some more. On those days where there is no lift, there really is lift and you can get 3+ minute flights out, its just much harder.
samc99us is offline Find More Posts by samc99us
Old Oct 11, 2010, 12:22 AM
like.2.fly is online now
Find More Posts by like.2.fly
Mike M.
like.2.fly's Avatar
United States, UT, Eden
Joined Jan 2010
Originally Posted by samc99us View Post
I personally noticed a large increase in thermalling performance simply by adding aileron differential. It helps keep the wing flatter in the turns for better performance...
My limited understanding of aerodynamics is not letting me grasp the concept of how aileron differential helps with making flatter turns. Please expound. When I want flatter turns I just tell my thumbs to use less aileron and more rudder.
like.2.fly is online now Find More Posts by like.2.fly
Old Oct 11, 2010, 01:37 AM
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
Charlie-
Rick
Hi Rick,
I am talking about the aileron movement itself. If you give left aileron command at the tx, the right aileron goes down and as it does the left one goes up. If the right aileron goes down more degrees than the left one goes up the overall effect is the same as adding some positive camber (flaps). This will likely also cause the nose to climb as you roll into your turn. If you use equal up and down deflection hopefully you will not have this effect but then you will need to add up elevator as your bank angle increases to prevent the nose from dropping too far.
charlie
GWS Tiger Moth and M100. What am I doing wrong? HardLander Foamies (Kits) 16 Jan 08, 2003 06:28 PM
What am I doing wrong? (1500mah LiOn & Qualcomm desktop charger) thwang99 Batteries and Chargers 4 Dec 26, 2002 05:16 AM
What am I doing wrong? hkowalczyk Beginner Training Area (Aircraft-Electric) 31 Jun 23, 2002 06:47 PM
NMH Batteries: what am I doing wrong. rcav8r2 Parkflyers 2 Mar 12, 2002 03:26 PM
