Old Oct 10, 2010, 12:19 AM
bbrstorm is offline
Find More Posts by bbrstorm
Member of the RC OCD Group
bbrstorm's Avatar
United States, WA, Gig Harbor
Joined Jan 2010
Build Log
Night Flying GWS Slowstick
I have slowly lost some of my heli addiction long enough to enoy Night Flying. It really is a lot of fun
Nightfly in the street (1 min 38 sec)
Click on my name to check out my blog
bbrstorm is offline Find More Posts by bbrstorm
Old Oct 10, 2010, 12:22 AM
bbrstorm is offline
bbrstorm's Avatar
Joined Jan 2010
I'll add the info from my blogg here:
Been taking a break from helis and really enjoying my GWS slow sticks. I few buddies are into night flying and got me into it.
Night Flying is really a lot of fun and these slow sticks give you a nice sized, easy to fly and inexpensive planes work very well for this. They are easy to learn on and I think easier to fly and get your orientation with a good light pattern. You'll see on mine that I have RED and White on top and Blue and Green on the bottom. The arrow design makes orientation very easy to see a lot of fun to fly.
Now that I have enough experience flying. I'm now able to fly it in the street out front and it brings out all the neighbors to come see the UFO lol.
Cheap setup:
- GWS Slowstick - $30 (Basic plane)
- 1050 Alpha 370 -$11 Hobbypartz.com
- 30amp ESC - $11 Hobbypartz.com ( yes you could use 18amp +)
- 2 x Tpro Servos - $6
- LED Lights - about $40 from hobbyking for all the colors and enough for 2 planes.
- Dubro Wheels and Linkage $10
- Cheap 2.4 RX/TX $30-50 depending on what you get.
- Steerable tail wheel for slow sticks $5 - LHS
That's it, well except for all the soldering and wiring
The slow stick is a fine flyer as it is but you can really stiffen it up and get a little more our of it. It's very durable and if you crash, tape and CA typically fix you right up in a few minutes.
There are a few mods I did to improve the overall performance and longevity of the plane.
1. Down and right thrust. 2 washers takes care of this. You want to do this as you are adding a lot of weight with the lights and mods so this helps the plane fly straight and hands off once trimmed.
2. Carbon rod and clear packing tape to make the folds in the rudder and elevator. Then taped the rest of the ruder and stabilizer. This really stiffens up the tail and improves the performance.
3. Upgraded linkage hardware - The stuff that comes with it works but these are better (see pics) Gotta Love Dubro
4. Fixed the flimsy landing gear by adding a piece of music wire about the same thickness as the stock landing gear. Use that as an axle and attach it to the stock landing gear with wire and solder. Cover it with shrink wrap and your done
6. Steerable tail wheel - This upgrade is a must and works ok as it comes. But I upgraded the thickness of the tail wheel wire to the same thickness as the front landing gear. I'll go more into this later....
7. Night lights - This takes a while. Get the strip led lights from hobbyking as they are the cheapest. Cut them into the 3 LED sections and tin the little soldiering spots. Lay them all out on the plane and then measure out the amount of wire and start soldering ( It's easy to tie things in to each other at it's all 12v and runs direct on the battery, see my pics) Tin everything first to avoid cold solders joints on the little circle spots.
8. Weights for the nose when you set your CG. Front mount your 2200Mah 11.1v lipos under the esc just behind the motor.......
Dan
www.themicrocamguy.com
Old Oct 11, 2010, 04:14 PM
VROOMSTER is offline
Find More Posts by VROOMSTER
AMA #953123
VROOMSTER's Avatar
Eugene, ORYGUN
Joined Mar 2009
I have a night flying Slow Stick too. They are a pleasure to fly at night. Very forgiving and docile.
VROOMSTER is offline Find More Posts by VROOMSTER
Old Oct 11, 2010, 07:07 PM
bbrstorm is offline
bbrstorm's Avatar
Joined Jan 2010
Pic
Old Oct 12, 2010, 12:11 AM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Nice dude... the Slow Stick is a great night plane. Been flying mine a couple years now - it was my first plane and became a night plane later.
jasmine2501 is offline Find More Posts by jasmine2501
Video GWS slowstick hovering in the snow... invertmast Electric Plane Talk 8 Feb 04, 2010 10:42 PM
Sold GWS SlowStick Slow Stick Parts, TONS! markusvt Aircraft - Electric - Airplanes (FS/W) 2 Oct 09, 2009 09:12 PM
For Sale NIght flying SlowStick GFBurke Aircraft - Electric - Airplanes (FS/W) 1 May 25, 2009 08:42 PM
Video NIght flying IFO and SlowStick SparkFlyer Electric Plane Talk 3 Oct 21, 2007 12:17 AM
