page 2
Latest blog entry: Wicked Powered Tech One Neptune EDF!
Actually the battery wires on plugged in can be pushed to the side quite easily. I will post a photo.
I did maiden the model today and it flew very well. Speeds doppler right at 90 mph on a fresh lipo but all I had was an older 4S 1500 25C lipo. I am guessing with a better 30C lipo it will be closer to 95 mph. This model does suffer from excessive tail incidence as the case in the F86. My CG was forward of the recommended position and it was tail heavy on the maiden. I moved the lipo forward and it was perfect. I am also certain the excess drag of the incidence is also robbing me of some mph as it is eating power. I will post my throws and some additional photos shortly. Don |
OK here is how the lipo wire is routed when I fly. The other photo shows my CG position. It is 1 3/16 (30mm) from the wing line as seen in the photo. The plane flies great that way and does not act nose heavy at all. The stabilizers really need about 2 degrees removed and the CG moved back. Not sure why some of these they have a lot on tail incidence built in as the others are essentially zero.
I flew a 3 minute flight today and put back in 1300 mah so that come out to an average of 26 amps or about 375 watts on the 4S. That is close to what the Wicked 6000 on 3S gets and I expect the 6000 combo on this jet to be about 80-85 mph so I think that is a better setup if you as me. Don |
The CGs ranges they give work fine for stock power as that is how they were designed. CG and incidence are related to each other. The more incidence, the more forward the CG will have to be if the speed is greater than the designed trim speed. Why the F-86, Mig 15 and T-45 had so much tail incidence makes no sense to me. The L39, F35, F16 and F18 have little incidence and fly fine with higher power at the stock CG locations. My T45 has down trim and a CG way ahead of the stock location and does not act nose heavy at all. A setup like this is draggy because basically you are flying around with up elevator and adding nose weight to hold the nose down.
This should be it.
Don |
I would go forward with any setup with more than stock power. It is safer with a forward CG, you can always move it back if you need too much up trim to fly. I balance right side up. On models like this I hold a 12" ruler on edge in my hand then sit the model on it with the other hand.
In regards to the Wemotec issue, I already have a different 50mm fan on the way and some new motors for it. I had once researched an alternative fan unit before as I had delivery issue once in the past and thought that was a one time thing but it seems not to be the case. The new fan is basically like the stock fan, 6 blade but made by a different company and the motors I am going to test for it are actually inrunners made by the same company who made the BI3600 motors I was selling for 70mm fans. Since these models need about 350 watts to make them fly well an inrunner will work OK. I will post more when I get all the items in sometime in the next week or so. Don |
The wicked wemo to me is the best combo especially at higher watts. This new fan is one I have no experience with but it is a very stiff plastic which is a good thing. The motors are from the same company I used for my BI-3600 inrunners for 70mm and they have a nice cooling hole through the motor. The outrunners are good for higher watts but these 50mm jets really only need about 300-350 watts to fly well and an inrunner should be OK, but that is what testing is for! If the inrunners are no good then I will work on a special adapter for the Wicked motor to hook up to this new fan unit. The inrunner solution will be the lowest cost, I was trying to avoid a special standoff adapter and rotor adapter which raises the cost of an outrunner solution.
| Thread Tools | |
| Build Log Wicked Powered Banana Hobby Jpower 50mm AMX | The Don | Don's RC | 199 | Dec 19, 2012 08:19 PM |
| Discussion Wicked Powered Banana Hobby JPower 50mm F-18 | The Don | Don's RC | 83 | Sep 16, 2012 09:45 PM |
| Build Log Wicked Powered Banana Hobby JPower 50mm F-16 | The Don | Don's RC | 180 | Dec 01, 2011 09:19 PM |
| Build Log Wicked Powered Banana Hobby JPower 50mm F-86 | The Don | Don's RC | 126 | Aug 11, 2011 09:05 PM |
| Sold Receiver ready Wicked powered Jpower 50mm F86 | The Don | Aircraft - Electric - Jets (FS/W) | 4 | May 02, 2010 10:33 AM |
