Old Dec 01, 2010, 11:22 AM
Roswalt is offline
Find More Posts by Roswalt
Capt, USAF
Roswalt's Avatar
United States, NV, Las Vegas
Joined Feb 2009
You sir, are a repair hero! Hard to believe that's my old wrecked jet in your video... Truly incredible work you should be very proud of.
Next time I suffer a Class-A Mishap on an RC aircraft you will be the first one I get in contact with!
Roswalt is offline Find More Posts by Roswalt
Old Aug 31, 2011, 10:58 AM
dirdredd is offline
Find More Posts by dirdredd
Dir_D_Redd
dirdredd's Avatar
United States, GA, Clayton
Joined Jan 2010
We must be cut from the same cloth. I like the challenge of puzzling back repairable things. And the best of it all is building Plane which is 80% of the fun and the other 20% is Flying.
dirdredd is offline Find More Posts by dirdredd
Old Aug 31, 2011, 02:11 PM
WRXpilot is offline
Find More Posts by WRXpilot
WRXpilot's Avatar
Bethesda, MD
Joined Jul 2006
I know this is old, but that is a fantastic job, considering what that plane looked like when you started.
Just so I get it straight - you use tape to keep the glue line expansion minimal and relatively flat, then use a dremel w/ sanding drum to knock down the glue that does seep up, followed by lightweight spackle for surface finishing?
I love GG, but have found its lack of sandability annoying. Never thought to bust out my Dremel... not sure why, it's brilliant. Thanks!
WRXpilot is offline Find More Posts by WRXpilot
Old Aug 31, 2011, 03:05 PM
denial15 is offline
Find More Posts by denial15
swede
denial15's Avatar
United States, UT, Vineyard
Joined Aug 2005
I assume you're talking about post #23. In that case, I had to fill in a lot of gaps. Sometimes they expand a bit and create a bump, but that's not too often.
This glue is very strong. I find if I am getting very much glue expanding out of the joint, then I probably used too much, or got it too close to the edge.
It is good to have it expand to the tape, that way it is sure to fill all of the gaps, but if it starts to lift the tape, or go too much outside of there, then that's too much.
denial15 is offline Find More Posts by denial15
Old Dec 21, 2011, 01:24 PM
bigtruck169 is offline
Find More Posts by bigtruck169
United States, NY, New York
Joined Dec 2009
wish i could have patient and steady hands like urs.
did u boil, or have the broken pieces in hot water to bring it to shape?
the gorilla glue + water method is liked toothpick the glue on, wait few minutes and put the two pieces together and tape over the join for holding overnight?
how about hot glue? as this is the most perfer glue i use all the time. ( no question gorilla glue is widely discussed type of glue )
thanks for the thread
bigtruck169 is offline Find More Posts by bigtruck169
Old Dec 04, 2015, 01:54 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
Wow, I'm not sure how I missed this post. Better late than never I guess.
I didn't boil anything on this plane. I have boiled some foam in the past, or used steam, but it makes the foam all bubbly looking.
The white gorilla glue dries pretty fast. If you are careful you can remove the tape after about 20 minutes, and continue working. The full cure is still 12 to 24 hours. Hot glue is fast, but heavy.
Old Dec 04, 2015, 02:27 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Denial, Ive done the same on my f-35, 2 times on my f-18. Lots of work. I would rather buy a replacement part now. your repair was great.
capt soap is offline Find More Posts by capt soap
Old Dec 04, 2015, 02:31 PM
adamtoo is offline
Find More Posts by adamtoo
Go foam or go home!
adamtoo's Avatar
Sweden, Norrbotten County, Luleň
Joined Sep 2014
Yeah that's what I'm thinking. For 40$ it will look like new
adamtoo is offline Find More Posts by adamtoo
Old Dec 04, 2015, 04:02 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
I agree. When I did this rebuild, the plane was still pretty new. Parts were much more expensive.
I now have V2 frame with retracts sitting in my garage waiting for me to make the swap.
Rave "Pre-crashed" F-35 but VASTLY Improved customer service. Thanks, Hobby-Lobby. Smokescreen38 Hobby Express (Formerly Hobby Lobby) 0 Jul 20, 2010 08:40 AM
Sold Hobby-Lobby / FREEWING F-35 Lightning II Parts TKK Aircraft - Electric - Jets (FS/W) 0 Apr 12, 2010 10:27 PM
Sold Hobby-Lobby / FREEWING F-35 Lightning II TV Parts TKK Aircraft - Electric - Jets (FS/W) 0 Apr 10, 2010 12:26 PM
