Old Jan 12, 2011, 12:49 AM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
About 2 years ago, oran gave me this black gold when I bought his mini-graphite. About 2.1mm thick means it's perfect as a support for my rear sled. Used the proxon mini saw, blade was almost dead when I started, I need to bury it now as it needs new teeth
la528it is offline Find More Posts by la528it
Old Feb 06, 2011, 05:01 PM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
Progress in slow motion.
Yuri.
Dbox is offline Find More Posts by Dbox
Old Feb 07, 2011, 03:58 AM
Protocooler is offline
Find More Posts by Protocooler
sloping addict
Protocooler's Avatar
France
Joined Feb 2003
A question on the 1509: there seem to be "long nose" and "short nose" ones, ie some have the extra 10-15mm of material to hold geabox in front, while some others have a shorter motor with the gearbox fitted right onto the rotor case (without a motor extension the diameter of the gearbox as in Yuri's photo).
I thought it was related to a design change and all newer motors (2010+) would be the short ones, but Yuri, yours seem to be latest production but is still the long one...
I have a long nose 1509 1.5Y 6.7 from 2007 and a short 1509 2D 6.7 from 2010.
Anybody knows why this difference?
Protocooler is offline Find More Posts by Protocooler
Old Feb 07, 2011, 04:06 AM
jjmouris is offline
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
Proto, in this case it's a 5.2:1 gearbox and Steve still makes all 5.2:1 motors with the long gearbox.
I don't know why Yuri has gone for a 5.2:1 motor in this case but i am sure he will let us know.
jjmouris is offline Find More Posts by jjmouris
Old Feb 07, 2011, 09:59 AM
la528it is offline
la528it's Avatar
Joined Dec 2007
You need a long nose if you want to run a pinion. The short gearbox can only be used if the shaft is cut into a gear. Some people like having an actual pinion for a 6.7 setup, because it allows them to change gearboxes on the motor to 5.2 if wanted. Note: you cannot have short 5.2 ever, and you cannot have short 6.7 on 11xx series motor, since output shaft is too small to cut gear into
Old Feb 08, 2011, 09:39 AM
bigandy is offline
Find More Posts by bigandy
Pesky Landings!
bigandy's Avatar
Abergele, North Wales, UK
Joined Apr 2004
Good afternoon all.
I've recently taken delivery of a new Viking 2e that I am about to start building once a servo order arrives. I have a couple of queries for those who have built/flown one already.
First of all, When mounting the motor bulkhead, is anyone bonding the bulkhead in place with any side/down thrust built in? Or is it better to bond it in square, and adjust the motor mounting with packing washers?
Secondly, What sort of CG range should I be aiming for with this model? I normally prefer my models to have a slightly forward CG, giving a gentle pull up in a dive test.
Finally, what sort of control throws and other mixes should I be looking to try out (snap flap, reflex, flap to aileron etc etc).]
Oh, one more sorry, are people normally using the canopy to load/unload battery packs, or is that more for accessing the battery connector?
Cheers!
Andy (who is hoping he can do a build as nice as the ones pictured in this thread!)
bigandy is offline Find More Posts by bigandy
Old Feb 08, 2011, 12:35 PM
PiNa is offline
Find More Posts by PiNa
Czech Republic, Hlavní město Praha, Prague
Joined Jul 2004
Hi Andy,
in case of hotliners, there is no need for side/down trust just make it square and you are done.
Also check out the other Viking 2 E build thread for more pictures from Dalibor.
http://www.rcgroups.com/forums/showthread.php?t=1186001
Good luck with your build, you wont be disappointed, Viking 2E is a great ship.
Martin
http://www.PiNa.cz
PiNa is offline Find More Posts by PiNa
Old Feb 09, 2011, 12:59 AM
PiNa is offline
Joined Jul 2004
These are the values recommended by Jiri Sodomka for his Viking 2 Glider
http://www.f3x.cz/viking2_settings.html
Canopy is used for accessing the "main switch" only. You will load your battery packs into the nose before joining it with the rest of the fuselage.
Martin
http://www.PiNa.cz
Old Feb 09, 2011, 03:20 AM
bigandy is offline
Pesky Landings!
bigandy's Avatar
Joined Apr 2004
Thanks for the advice Martin, it's much appreciated. That video you posted of the 4kW Viking has certainly got some of my club mates expecting something big from mine!
I've thought of one more question I meant to ask. When it comes to retaining the nose cone with big power onboard, are you relying on just the two wing incidence pegs to hold the nose on, or is it advisable to install an additional retaining feature. (The nose on my Graphite 2e with 1.8kW was held on with a single m3 bolt)
Andy
Old Feb 09, 2011, 03:48 AM
PiNa is offline
Joined Jul 2004
Andy,
your club mates were right about short life of Dalibor's Lipos (up to 75% discharge only). The day before his battery pack died after 10 cycles he discharged it way too much. So it seems you can safely follow Dalibor's way to surprise them with 4kW
Until we've visited Jiri lately, Dalibor was relying on just the two wing incidence pegs to hold the nose on. It was before maiden of his Viking 2 E Race. Jiri showed us that it is still possible to bend nose cone a bit. So Dalibor put one extra bolt on the top just to be safe.
You can see Dalibor in the backgroud as he is trying to bend my Viking 2 E nose cone to see how serious this "problem" could be
Martin
http://www.PiNa.cz
Old Feb 09, 2011, 04:13 AM
PiNa is offline
Joined Jul 2004
... and nice piece of tuning for Dalibor's V2E Race. It will sustain 6kW.
Martin
http://www.PiNa.cz
Old Feb 09, 2011, 05:12 AM
sloping addict
France
Joined Feb 2003
Aeronaut yoke stuck on plastic spinner ?
Can you show the inside ?
thanks !
Old Feb 09, 2011, 06:15 AM
PiNa is offline
Joined Jul 2004
attached
Old Feb 10, 2011, 09:24 PM
la528it is offline
la528it's Avatar
Joined Dec 2007
Martin, very nice spinner, please let me know ingredients.... looks much stronger than rfm yoke.
I tested motor tonite: 1409 1.5y 6.7... 7s 3300 45C... results are good:
See below... happy about rpm, this means on 17x13 it will be a touch slower, but still efficient. I did not want to try 17x13 rfm yet, because if GM pils = no need to grind flat on shaft... for rfm I will... UNLESS GM starts selling spinners for no twist, large rfm props.... (please) or martin shares where he and Dalibor hunt reindeer
Old Feb 11, 2011, 01:06 AM
sloping addict
France
Joined Feb 2003
Get yourself a Klemm or HM spinner (they both use same concept but just have the screws reversed) => no set screw anymore and holds firm on dound shaft. Best system I've found to date...
Available in large variety of sizes.
Lindinger.at or Hoellein for example sell these.
Martin: is that a home made or commercial unit? It still has a set screw right ?
Cool HD Video: Viking F3X-E Landing on a dime PiNa High Performance 14 May 04, 2012 09:31 PM
Question Another Dingo or a Viking 2??? SpeedMaster Multi Task F3X 7 Jul 31, 2010 05:59 AM
Cool Video: 2.5kW F3X Viking E - maiden in HD PiNa High Performance 10 Mar 29, 2010 01:13 PM
