Old Oct 09, 2010, 07:35 PM
norstaroption is offline
Find More Posts by norstaroption
norstaroption's Avatar
Pacifica, CA USA
Joined May 2009
Help!
HK-3026-1600 and Phoenix ICE 50
Will this motor and ESC combination work with my Trex 500 for FFF but no hard 3d. I have these laying aournd and hoping I don't have to buy another ESC. I'll be running Turnigy 6s 3000mah 30c. If it will work please suggest what pinion gear size please.
norstaroption is offline Find More Posts by norstaroption
Old Oct 10, 2010, 01:56 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
I used a 14 tooth pinion on an Ice 75. It had decent 3D power. You would be over the 50 amps on a 14 tooth. I usually peaked around 56 amps, doing basic 3D. I think the 50 might take it ok.
A 13 tooth would probably be a better option on the 50 amp. I never ran the 13 tooth so can't tell you how many amps it would draw.
The motor shaft is longer than the stock motor. So you have to cut the shaft down, or drill out the step in the pinion. You can also buy pinions without the step.
Roto Rob is offline Find More Posts by Roto Rob
Old Oct 10, 2010, 03:26 AM
Pacifica, CA USA
Joined May 2009
Thank you very much!
Wanted Scorpion HK-3026-1600 motor for Trex 500 (or similiar...) dbrown777 Aircraft - Electric - Power Systems (FS/W) 2 Jul 17, 2010 03:19 PM
Found Scorpion HK-3026-1600 motors pmisuinas Aircraft - Electric - Power Systems (FS/W) 1 Jun 17, 2010 07:58 AM
Sold Scorpion hk-3026-1600 NEW In Package ministeve2003 Aircraft - Electric - Power Systems (FS/W) 4 Feb 16, 2010 09:50 PM
For Sale Scorpion HK 3026-1600 Rollingball Aircraft - Electric - Power Systems (FS/W) 9 May 14, 2009 04:48 AM
For Sale Scorpion HK-3026-1000 and Hk 3026-1210 booger Aircraft - Electric - Power Systems (FS/W) 2 Oct 10, 2008 08:51 PM
