Old Oct 09, 2010, 06:35 PM
goodhumormarc is offline
Find More Posts by goodhumormarc
figuring it out...sort of!
goodhumormarc's Avatar
USA, OR, Happy Valley
Joined Jul 2010
Help!
walkera ga005 charger
I just got a #38 tandem. I go charge the battery with the charger supplied. The red light turns on then when I plug in my battery It blinks what seems to be very fast. I waited two and a hlaf hours and nothing changed. the charger seems quite hot. I tried my buddies Esky charger which works fine....Is this normal operations for this charger? am I to anxious? How long should it take to charge a new battery?
goodhumormarc is offline Find More Posts by goodhumormarc
Old Oct 09, 2010, 09:33 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
First of all, the lipo pack that comes with the Walkera #38 is a 2S 2200mah and the Walkera GA005 balance charger has an output of 800mah. so that means if you are charging a fully discharged pack which would read 7.4V total (3.7V per cell x 2 cells in series) so the indicator LED would change from blinking red (which indicates charging to solid Green when the full charge pack voltage reaches which is 8.40 v ( 4.20V per cell x 2 cells) which will take from start to end approximately 2.75 hours to 3 hours for a 2200mah pack, .8AH charge rate is a very low .34C where virtually all Lipo packs can be charged at a charge rate of at least 1C which in the case your 2200 mah pack, that means you can charge it safely at up to 2200 mah rate which is 1C and would take approx. 1 hour for a fully discharged pack that size. that's why I use my digital hobby grade chargers to balance charge all my detachable lipo packs. The cheapo dumb chargers that are included with these RTF toy helis are just too slow and inefficient.
Doubletap is offline Find More Posts by Doubletap
Old Oct 10, 2010, 12:22 AM
Joined Jul 2010
Thats all I have for the moment. can you suggest a good charger? Thanks.
Old Feb 05, 2015, 08:36 AM
ANNIHILATOR1000 is offline
Find More Posts by ANNIHILATOR1000
United States, IL, Chgo
Joined Jan 2015
I too have the same problem my 5200 mah lipo left it all night charging and the light still blinking
ANNIHILATOR1000 is offline Find More Posts by ANNIHILATOR1000
For Sale NiMH/NiCd charger and Walkera charger RNAF Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 25, 2010 09:33 AM
Discussion Using walkera charger for parkzone batteries? wparsons DIY Electronics 0 Oct 20, 2009 03:41 PM
Discussion who makes a similar charger like the walkera #52 11.1v 3 cell wall charger.? raptorddd Micro Helis 2 Sep 10, 2009 06:25 PM
Discussion anybody has a free or cheap walkera #52 stock charger. raptorddd Micro Helis 0 Sep 07, 2009 10:58 PM
Wanted walkera #52 stock charger raptorddd Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2009 11:43 PM
