Old Oct 08, 2010, 09:02 PM
Chophop is online now
Find More Posts by Chophop
Glad I'm not a Boll Weevil
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
Stuck on Mounting the ESC and Battery AGAIN !
Man, I spent 3 days scratching my head on how to mount the ESC and battery on my latest build, a Radical RC Stick 400. I do that on every plane I build.
I did finally work out the ESC mount, photo later in the Stick 400 build thread.
What I ended up doing is to CA glue some wood blocks the same thickness as the esc, then CA a wood strip across it at each end. I can simply pull the wood off and re-glue it if I need to remove the ESC. Most people don't remove their ESC and show it off, so I guess I am ok there.
Now the battery. I can't use velcro and cross my fingers so the best I can usually do is make a battery box from a wood frame for an oversized battery, then fill the space with foam blocks. They have to fit in a way that they can be easily removed to load a larger battery and I keep other foam blocks handy for smaller batteries.
That is about the best I can do for this situation.
This is easy on heli's, but man do I scratch my head on how to mount this stuff on airplanes.
Chophop is online now Find More Posts by Chophop
Old Oct 08, 2010, 09:56 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Velcro, velcro, velcro. If there's no room, then simply remount in a different location.
Using CA not only will damage your components, but it gets everywhere too.
Xpress.. is offline Find More Posts by Xpress..
Old Oct 08, 2010, 11:10 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
I'm about to deal with the same issue on another Radical RC plane. I'm thinking some sort of "bench," probably 1/8" plywood, mounted to the plane's bottom with balsa blocks. The bench is raised off the bottom just enough so I get velcro-tie downs under it and back over the battery.
The trick is to not block access to the landing gear tie-downs, but I think it's do-able.
rafe_b is offline Find More Posts by rafe_b
Old Oct 08, 2010, 11:14 PM
Art Schmitz is offline
Find More Posts by Art Schmitz
Crossville, TN
Joined Dec 2004
Cut two pcs of 1/16 ply the size of your battery.
Wax fuselage ahead of front wing seat.
Cut four 3/4" long sections from 3/8 sq.motor stick stock. [assuming that your fuselage is like the stock SS]
Center fuselage on one of the 1/16 ply parts and glue the four blocks one on each side front and rear. Go for a tight fit.
Shim the tops of each of the four blocks with scrap 1/64 ply or thick paper.
Glue the remaining 1/16 part to the tops of the four blocks.
This will result in a tight fitting sliding mount for the battery on the bottom and the ESC on the top.
Use thin velcro for both and follow up with tie-wraps.
Use a GWS cowl screw to hold the double deck sliding tray where balance dictates.
Works for me. art
Art Schmitz is offline Find More Posts by Art Schmitz
Old Oct 09, 2010, 05:45 AM
Chophop's Avatar
Joined Sep 2006
Art's way is similar to what I did on other planes. Not only Radical but all of the scratch build types. Velcro is ok but after some use it looses some grip. That is unless there is a good quality brand available. Getting it loose from a tight space can be a problem too.
Back later, chores to do.
Cool Funny FPV video (Plane stuck on the tree) Eugz FPV Aircraft 11 Jul 31, 2010 03:23 AM
Discussion quick help!? stuck aileron servo on microP51! RickBee Micro Ready-to-Fly 6 Jul 27, 2010 12:34 AM
Discussion battery to esc connection question banana type plug to deans on esc Danokazaki Rock Crawlers 1 Feb 05, 2010 09:57 AM
Discussion Battery and ESC conncetor stuck muddy_4_life Off-road Cars 5 Apr 05, 2007 06:47 PM
ESC Wire Strain Relief & Battery Mounting ToddO Beginner Training Area (Aircraft-Electric) 10 May 23, 2001 08:20 AM
