Old Oct 08, 2010, 09:01 PM
idocdave01 is offline
Find More Posts by idocdave01
Joined Mar 2010
Non RC Lipo
My wife has a "WORX GT"Lithium and the battery does not
charge they are sending a new one but I would like to see if
I can fix the old one. I've been inside the pack everything
seems ok, same voltage on all cells, no burned spots on the
board. The battery is labeled 18V Lithium Power and the
contacts are labeled left to right + BS Vcc T -. It charges
about 10 seconds and then the charged light comes on, it
will only run for about 30 seconds then stop. Any ideas.
Dave
idocdave01 is offline Find More Posts by idocdave01
Old Oct 08, 2010, 09:05 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Check each individual cell with a VOM. One of the cells is probably bad, IE has been overcharged or over discharged. When you find the bad cell, remove it and rebuild the pack as a smaller one. Then use a balancer when charging it.
If none of this makes sense to you, throw the battery away as it is too dangerous for a novice to fool around with.
Kmot is offline Find More Posts by Kmot
Old Oct 08, 2010, 09:16 PM
Joined Mar 2010
The voltage is the same on all cells. She left it on the charger but her dad does also and his is fine I was wondering if it has something to do with a voltage check when charging through the charger or something like that. Also the voltage goes up when I check in series (2.4 - 4.8 and so on )
Old Oct 08, 2010, 09:19 PM
nick_75au is online now
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
First of all, what are you doing sending your wife out to to the whipper snippering
I've seen laptop batteries with the same issue, it usually has to do with the circuit board inside, which acts as a cell balancer and low voltage protection, having a fault.
Batteries can be charged with an RC charger set up to charge Li-ion batteries, the pack has to be modified though.
Nick
nick_75au is online now Find More Posts by nick_75au
Old Oct 09, 2010, 05:47 AM
Joined Mar 2010
She wants to do it and didn't like my gas powered one so she got this one just like her dads.
Old Oct 09, 2010, 10:10 AM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
Faulty chargers sell many batteries. Does the charger work on anything else?
mfr02 is offline Find More Posts by mfr02
Old Oct 09, 2010, 03:36 PM
785boats is online now
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Have you tried charging the battery up on your dear wifes fathers charger?
That will tell you if it's the battery or the charger.
Paul.
785boats is online now Find More Posts by 785boats
Old Oct 09, 2010, 09:04 PM
Joined Mar 2010
Paul.
I'll have her try it this week.
Discussion Using a servo as a non-RC actuator. lbl25a DIY Electronics 5 Jul 30, 2010 03:10 AM
Alert For Sale: RC and non RC stuff for sale local PU pcphill Atlanta Area RC 7 Jan 23, 2010 05:29 PM
Question RC charger with non-rc li-ion? t0ny-p40 Batteries and Chargers 2 Nov 24, 2009 12:16 AM
Question Any non-GP and non-CMP Lancair RC for 15-30cc ? NikolayTT Scale Fuel Planes 0 Aug 30, 2007 12:03 PM
Non-RC related lipo fires in the news.. TheLost Batteries and Chargers 4 Jun 26, 2004 11:10 AM
