This thread is privately moderated by miniphase, who may elect to delete unwanted replies.
Old Oct 08, 2010, 03:54 AM
miniphase is offline
Find More Posts by miniphase
miniphase's Avatar
United Kingdom, Kent
Joined Nov 2004
2m wing
I cut a set of cores several years ago and tried bagging them using wax paper as a carrier. It turned out far too difficult to get all the air bubbles out from under the paper, so I ended up with a patchy finish.
The cores sat sulking in the garage, I nearly binned them when I last moved house. The other week I pulled them out from the back of the shed and decided to do a quick lashup to get the wing flying.
Well I'm glad I didn't sling them out, the wing feels rock solid in the air. Handles conditions from about 4mph up to about 13mph and has a reasonable speed range despite the 12% section. A real stress free flyer, I'll have to make a tidier version at some point.
flap design thread here
Update...the wing has flown in 20mph wind, probably its upper limit. The coastal air was very smooth which must have helped, and the model felt solid and stable. I've always been an advocate for more reward cg positions and all the data says I could move it further back on this wing. However I'm not sure I'll bother as I like it just the way it is.
flying wing at Minster (0 min 54 sec)
and here it is with functioning flaps
miniphase is offline Find More Posts by miniphase
Old Jan 01, 2014, 12:07 PM
theshredder is offline
Find More Posts by theshredder
Joined Jan 2014
Hi!
Axay here. I am on this wing's tail!!
Would you recommend some foam cutting videos?
theshredder is offline Find More Posts by theshredder
Old Jan 02, 2014, 04:13 AM
miniphase's Avatar
Joined Nov 2004
Hi Axay
Here is my method for cutting foam wings.
cutting foam wings (2 min 0 sec)
and don't forget to include washout when cutting!
Old Jan 05, 2014, 01:06 AM
Joined Jan 2014
cool music, sir!
I am thinking of powering this one up with an electric motor. Please suggest ideal motor setup.
once again, groovy music ! =)
Old Jan 08, 2014, 10:27 AM
miniphase's Avatar
Joined Nov 2004
I'm a glider man mostly so motor set ups aren't my strong point. The prototype came in at around 650g, so if you allow say another 250g for motor esc and battery, you've got a couple of lbs auw, so probably be wise to stay above 150 watts, go for a lower kv motor maybe around 900 or so? Remember this model has a thick wing section so treat it more like a powered glider than a speed wing.
Hope this helps!
Wanted 2m wing timbuck Aircraft - Sailplanes (FS/W) 2 Sep 11, 2010 10:54 PM
Wanted Chrysalis 2M Electric sailplane kit (with the three piece wing kit) bfraser Aircraft - Sailplanes (FS/W) 0 Aug 14, 2010 02:01 AM
Sold 2m Wing Bag With Fuse Sleeve, And Tail Covers screamin' eagle Aircraft - Sailplanes (FS/W) 3 Aug 03, 2010 08:33 AM
Sold RTF All Molded "Manta" 2M Flying Wing ***** Joe Pierson Aircraft - Sailplanes (FS/W) 2 Sep 10, 2009 03:49 PM
