Old Oct 07, 2010, 10:10 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
Question
How tough are carbon blades?
I'm dabbling in bigger heli's now. Up to this point, most of my little heli's have used plastic or wood blades. I've noticed that most of these bigger(450+) helis use fiberglass or carbon fiber for the blades. Not yet being an expert, I fully expect to crash atleast a few times. Compaired to the FG blades, how much tougher are the CF blades? How much better will they handle a crash? Is the CF's druability worth the extra cost, or are they just another nifty looking part? Thanks for the info.
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Oct 07, 2010, 11:31 PM
Druss is offline
Find More Posts by Druss
Canada, AB, Edmonton
Joined May 2008
CF blades are definitely worth the cost when you're ready for them but... don't use them until you think you need them (each of us needs to decide when that is).
While CF blades perform better, they will also transmit the shock of impact in a crash to the rest of the head causing more damage than wooden blades which break on impact. With wood blades you basically damage blades, feathering shaft, maybe main shaft but rarely the other head pieces unless you go in with full throttle or inverted.
Don't buy durable blades to save $10-$12 on wooden blade replacements and have to spend $50 on a new head.
Druss is offline Find More Posts by Druss
Old Oct 08, 2010, 01:59 AM
Roto Rob is online now
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Carbon blades vary. Crash damage is often as much or more, as a wood blade. Other models can be more durable.
The more delicate are often sold as the higher performance light weight blades.
Roto Rob is online now Find More Posts by Roto Rob
Old Oct 08, 2010, 12:11 PM
rotoraddict is offline
Find More Posts by rotoraddict
Joined Jul 2008
I have had good wood blades that were tougher and flew better then some of the cheaper Carbon Fiber blades I have had in the past.
So just because it is a C/F blade does not always mean it is a better blade.
rotoraddict is offline Find More Posts by rotoraddict
Old Oct 08, 2010, 12:44 PM
metalbenderusn is offline
Find More Posts by metalbenderusn
My dog is PERFECT in my eyes
Joined Mar 2010
I use FRP fiberglass blades. Once they're balanced and things are set up, they're great even with mild 3D. I ran ONE set of CF, they were great but as stated, they rip the head apart even in a mild impact, and it don't take much of a hit to ruin CF blades. In other words, I don't think the cost justifys the means, especially if you're still having head strikes off and on. I'll continue to run fiberglass for a LONG time....they're light, decient rigidity, and a minor hit will not ruin the blade.
metalbenderusn is offline Find More Posts by metalbenderusn
Old Oct 08, 2010, 01:37 PM
ChillPhatCat is offline
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
Yeah, not that it hasn't been said, but CF blades are made for performance, not durability. And, blades are the first thing you want to break over other parts in a crash. Wood is the way to go for sure when just starting out.
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Oct 08, 2010, 03:25 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Yup... they have ZERO durability actually. ANY damage to a carbon fiber blade means you need to replace it. An impact can cause invisible micro-cracks in the structure, and this can cause a complete failure. It's probably a good idea to replace CF blades periodically even if you don't break them.
jasmine2501 is offline Find More Posts by jasmine2501
Old Oct 08, 2010, 07:37 PM
phoenixheli is offline
Find More Posts by phoenixheli
Committed heli addict...
phoenixheli's Avatar
Joined Jan 2010
Zero durability is right, lol. Almost any damage, except for some small scratches, makes them unusable. Wood blades usually can take a blade strike fairly well, due to the flexible nature of the wood.
I do most of my flying with woods as I'm more of an easy flyer. The sound of woods chopping the air is soothing to me. I'll throw some cf's on when I want to throw the heli around hard. Full collective punches require stiff blades (cf or fg), because the rotor disk begins to cone, especially with woods, and it decreases the total lift, also making the cyclic less responsive.
Cf's also provide a precision feel to the cyclic, but this can be counter productive if you fly easy, because woods have a softer and almost absorptive quality when dealing with turbulances and cyclic or pitch inputs.
So, like most people it comes down to costs and wants. For the price of a single set of cf's you could buy 3 or 4 woods. But, you can't get the performance of cf's with woods.
phoenixheli is offline Find More Posts by phoenixheli
Old Oct 08, 2010, 09:38 PM
Evansville, WI
Joined Dec 2006
Thanks for all the info, it's just the kind of thing I was looking for I hadn't though of wood blades as a head saving device, but it makes perfect sense.
Old Oct 08, 2010, 10:04 PM
Rocket Programmer
Joined Jul 2007
Well some wood blades are pretty dang stiff too - the Align blades are not bad. You can also try fiberglass blades - they are cheaper, generally in between wood and CF for stiffness, but they still don't take impacts well.
Old Oct 09, 2010, 11:35 PM
Evansville, WI
Joined Dec 2006
I imagine that the same holds true for carbon VS plastic tail rotor blades?
Old Oct 12, 2010, 05:04 PM
Joined Jan 2010
Yep, you need a stiff tail for hard flying or the tail rotor will cone out just as the main rotors would. In my experience cf tail rotors are worth the money. Plastics have always exploded on me with a little tail contact. The one set of cf's I used took a tail strike and only scratched the tips, but that energy was transfered from the blades to the shaft and bent it. Same reason I never upgrade head components to metal, the energy just pushes though like a newtonian demonstrator and damages components further down the system. Cheaper to replace a blade grip than a servo or swash. However, with a high speed hs, you shouldnt use plastic head componets anyhow.
Mystery - Are the Align "Carbon" blades really carbon?? Hoverup Mini Helis 17 Jan 21, 2008 10:36 PM
Discussion How are Carbon Fiber Blades? Pipercub18 Micro Helis 9 May 12, 2006 08:50 AM
How durable are carbon blades? KasperE Micro Helis 1 Aug 25, 2003 02:42 AM
Just built my FMA RAZOR - How tough are these things? Darn Servo ! Foamies (Kits) 10 Jul 25, 2002 08:24 PM
Are the carbon hornet blades THAT much better than the stock blades? Spaulding Electric Heli Talk 10 Apr 04, 2002 07:29 PM
