Old Oct 07, 2010, 07:15 AM
cheech2 is offline
Find More Posts by cheech2
Slovenia
Joined Jan 2005
Question
Graupner Li Charger 4 Plus Lipo/LiIo/Life
hello,
does anybody have this charger.
I have ask our local vendor and without success.
is this charger use only balance connector to charge or it should be conected main + and - from battery also. simple question, no answer.
in user manuals is not clearly mentioned, so I ask if somebody owned this charger and can provide 100% information to me.
thank you in advance. Simon
cheech2 is offline Find More Posts by cheech2
Old Oct 07, 2010, 08:13 AM
freechip is offline
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
It just chargers threw the balance lead, many do this. Most of all the STOCK RTF chargers that come with your plane charge threw the balance tab. As long as the current is not too high you're ok.
3A output is a bit high I think for balance tab wires but I guess not according to the charger manufacturer.
freechip is offline Find More Posts by freechip
Old Oct 07, 2010, 08:31 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Hi Simon,
the manual and the technical information is pretty clear. This is a 30W charger with 3A max. charge current and 0.1A max. balancing current:
http://www.graupner.de/mediaroot/fil...s_de_en_fr.pdf
Charge mode
Connect a suitable genuine GRAUPNER Lithium-Polymer battery pack to the output of the Li- charger 4 plus. The pack must consist of no more than four cells. Connect the balancer connector Graupner/EH to the balancer output.
First you connect the normal battery connector to the charger, then you connect the balancer connector.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Sold Ripmax Quattro Plus 1-4 Lipo Charger Cheap! GetterDragun Aircraft - Electric - Batteries & Chargers (FS/W) 2 May 07, 2010 02:08 PM
Sold Graupner LiPo-Charger 4 Automatic Charger Greg Gimlick Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 18, 2010 02:42 PM
Sold Celectra 4-Port, 1-Cell, 3.7, 0.3A DC Li-Po Charger, Plus 3 240MAH Single Cell Packs. jafo216 Aircraft - Electric - Batteries & Chargers (FS/W) 9 Jan 01, 2010 11:55 AM
Sold Celectra 4-Port, 1-Cell, AC/DC Li-Po Charger, *Plus 2 240MAH Single Cell Packs. jafo216 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jan 01, 2010 11:53 AM
For Sale Graupner Li-Po Charger 4 robspook Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 30, 2009 07:41 AM
