Old Oct 07, 2010, 06:45 AM
ziomatrixacs is offline
Find More Posts by ziomatrixacs
Registered Abuser
ziomatrixacs's Avatar
Joined Oct 2006
Ground station wiring harness
I just got an Oracle diversity controller and another 900mhz RX for my ground station. The wiring for two receivers, diversity and the power harness is a little messy and I want to clean it up but keep it modular. Do you guys use shorter AV cables or just zip tie them? To keep the system powered by a single battery and make it plug and play, should I have a circuit board with micro deans connectors on acting as a power rail and when I add/removed something, just unplug it? I dislike barrel connectors since they are not all the same, usually keep those with the component. I wish they made 6",9" and 12" AV wires instead of 3 feet...
ziomatrixacs is offline Find More Posts by ziomatrixacs
Old Oct 07, 2010, 06:59 AM
StealthWorkx is offline
Find More Posts by StealthWorkx
What was that...
StealthWorkx's Avatar
UK
Joined Nov 2009
Have a look at the new immersion RC Power box
http://www.rcgroups.com/forums/showthread.php?t=1318707
StealthWorkx is offline Find More Posts by StealthWorkx
Old Oct 07, 2010, 07:23 AM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
Check out http://www.monoprice.com/home/index.asp they have great prices and service.
I got some short ones for mine there.
scrape is offline Find More Posts by scrape
Old Oct 07, 2010, 05:48 PM
Registered Abuser
Joined Oct 2006
Im trying to not buy more stuff I just need to make a simple circuit board with 3-4 Deans soldered on so I can plug my battery stuff into.
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4493 May 19, 2016 02:53 PM
Sold 4-servo wing wiring harness from RC Harness RCPC Aircraft - Sailplanes (FS/W) 1 Sep 01, 2010 09:55 AM
Discussion Newb wiring harness help gfulton FPV Talk 2 Aug 23, 2010 06:39 AM
For Sale Ready to fly Prangster with engine and ground station Protocrash Aircraft - Fuel - Airplanes (FS/W) 0 Aug 10, 2010 10:02 AM
