Old Sep 18, 2012, 12:32 AM
Jockadopolus is offline
Find More Posts by Jockadopolus
Jockadopolus's Avatar
Scotland
Joined Jan 2010
You may have the new blades with no negative pitch
Check my post 973
Joe
Jockadopolus is offline Find More Posts by Jockadopolus
Old Sep 18, 2012, 10:24 AM
Bimbeau is offline
Find More Posts by Bimbeau
Bimbeau the helifreak
United States, CO, Denver
Joined Sep 2012
Hi Joe, indeed I don't seem to have any pitch on the blades. I read this topic from te start to more or less halfway, but not far enough it seems, why th do they change the blades to non-working anyway...
How much pitch is needed more or less? I have no reference you know... I do have a pitch gauge though
Bimbeau is offline Find More Posts by Bimbeau
Old Sep 18, 2012, 04:19 PM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Somebody will correct me if I'm wrong I think you will find the pitch is set by the piece of timber at the blade grip. 2deg negative is the target blade pitch, with the rotor head 6deg back.
Mick
Bravo47 is offline Find More Posts by Bravo47
Old Sep 18, 2012, 08:25 PM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
Now regarding the pitch.....As Joe pointed out in in #973, there should be a "wedge" of timber on the blade where it bolts to the center hub.This wedge gives the blade a negative incidence ,helping the blades to spin
.It would appear as if this no longer happens with the H/K blades and so the T/E of the blade has to be lifted in some way.
If you look at #973,you will see that a thin strip of wood has been attached to the rear underside of the blade, giving the blade the negative pitch that is required..............
Happy Landings
Chris.............
britinoz is offline Find More Posts by britinoz
Old Sep 18, 2012, 10:19 PM
Bimbeau is offline
Joined Sep 2012
Mick, I don't think the blade pitch depends on the tilt of the rotor. I'll go for 2 degrees negative to start with.
Chris: I've read post 973, thats why I had this question. Please define 'a thin piece of wood', how thin is thin? 1mm? 2mm? I'll try some stuff to get to 2 deg and see what happens. I was just wondering if someone knew which angle works, and go from there.
Old Sep 19, 2012, 12:45 AM
Tinmar is offline
Find More Posts by Tinmar
Tinmar's Avatar
South Africa, GP, Nigel
Joined Sep 2009
Most of my blades is 2.5deg neg.
Tinmar is offline Find More Posts by Tinmar
Old Sep 19, 2012, 04:44 AM
Bravo47 is offline
Australia
Joined Jun 2010
I never said it did
Old Sep 19, 2012, 12:29 PM
Bimbeau is offline
Joined Sep 2012
Originally Posted by Bravo47 View Post
I never said it did
Oh... guess I got your comment wrong then (i'm not native to english). Thanks for the tips anyway!
Old Sep 19, 2012, 03:47 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
Re the pitch angle.......2 is good....3 is max........................
Old Mar 27, 2016, 03:02 PM
kaisaras is offline
Find More Posts by kaisaras
kaisaras's Avatar
Joined Aug 2007
Hi guys
Sorry for replying in this very old thread!
Which is the best solution for spare blades in this model?
kaisaras is offline Find More Posts by kaisaras
Old Mar 27, 2016, 04:25 PM
TURBOOMNI is offline
Find More Posts by TURBOOMNI
Trailer Down By The River
Joined Sep 2004
I never liked the blades it came with . They are too small for the gyro to fly anything but fast.
I made my own blades and it was actually quite easy. I made my blades slightly longer but a good bit wider and she fly's much better.
Do they still make this kit? I would buy another one.
TURBOOMNI is offline Find More Posts by TURBOOMNI
Question Canister mufflers from China WinginIt Giant Scale Airplanes 5 Nov 01, 2010 02:53 PM
Gallery More pics from the Gaelic heart of Nova Scotia Bolter Aerial Photography 15 Aug 28, 2010 03:33 PM
Discussion Buying discount merchandise from china? sea20 Batteries and Chargers 26 Aug 13, 2010 10:07 AM
Discussion Advice: Shipping from China Dan203 Micro Helis 2 Jul 25, 2010 02:58 AM
