Old Jan 08, 2012, 04:02 AM
minirotor is offline
Find More Posts by minirotor
minirotor's Avatar
QLD Australia
Joined Oct 2009
Yes Chris.
Do you add wts to make the crosswise C of G on the highest point of the chord, and put the bolt holes on this position also?
The 4.7mm/5mm thickness of HK blades is apx 30% of the chord, which according to tests reports I've read is supposed to the about the right thickness for that width blade.
But the jury is still out about all this, however Aerobalsa seem to have the eadge over everybody with blade design/performance as yet.
I,am going to try the standard HK blades on a much ighter Benson Style gyro later in the year.
I think they will go well--BUT, I also plan to try a 2 blade rotor.
So I will have to make some more longer blades with a lot of weight in the tips[that this years project]
''Its the crosswise C of G position and the bolt hole position in relation to the blades highest chord point that confuses me at the moment''
Regards, M
minirotor is offline Find More Posts by minirotor
Old Jan 08, 2012, 08:06 PM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
I do not add weight to the L/E of my blades ,but I do use a 6 mm square pine on the L/E which moves the balance point forward. I put my bolts just Behind the C/G ,making the blades nose heavy.
Chris........
britinoz is offline Find More Posts by britinoz
Old Jan 08, 2012, 08:28 PM
TURBOOMNI is offline
Find More Posts by TURBOOMNI
Trailer Down By The River
Joined Sep 2004
thats interesting Chris.. what effect does that have on performance and how far behind the cg do you go?
TURBOOMNI is offline Find More Posts by TURBOOMNI
Old Jan 09, 2012, 02:39 PM
Jockadopolus is online now
Find More Posts by Jockadopolus
Jockadopolus's Avatar
Scotland
Joined Jan 2010
Flew again today got the throws better still a lot of vibration I will need to work on that.
Got a good ROG but the wind was just off the runway (my excuse ) and had a couple of tip overs on landing with no damage
I have had a few problems with the hinge on the C30 heads I bought a few for other projects on three of them when assembled hinges have broke just bolting the blades on I would advice you all to check the condition on your heads
Joe
c30 w calder.wmv (3 min 42 sec)
Jockadopolus is online now Find More Posts by Jockadopolus
Old Jan 09, 2012, 03:17 PM
Joined Sep 2004
Nice flying! You seem to have dialed in very well. As far as the hinge goes ,mine also broke and I ordered a new head and removed the hinge to use as a template. I use clear polycarbonate which is within a few thousands in thickness as the stock hinge. Although abit stiffer than the stock one it works well and is very durable and I started using it as of last June with no breakage. I got the polycarbonate at my hobby shop and it is made by Midwest products. Others have mentioned using tupperware lids and such too. I always remove the blades after flying and never transport or store it with the blades on .
Old Jan 09, 2012, 06:31 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
G'day Joe
That machine looks as if it handles the wind OK. The funny thing is that I find my smaller models perform better in the wind than the large ones
Turbo
I know you have seen Rich's video for balancing blades ,well I use the same method with the bolt only 1 mm behind the balance C/G.just enough to make the blade L/E heavy. I have always used this method ,and it works fom me OK.
Happy Landings
Chris..........
Old Mar 08, 2012, 07:33 AM
The_RattleSnake is offline
Find More Posts by The_RattleSnake
The_RattleSnake's Avatar
Joined Jul 2007
One thign I don't understand is this:
On a previous post it shows that "you need to reverse the rotor head".
or it wont create any lift.
I was looking at the 2 photos and realised that doing that doesn't actually
change the angle of the blades.
you can see that the 2 bolts run paralell with the blade and that they
are inline with the center "Spin" point.
when you reverse the rotor head, the 2 bolts are still paralell with the blades
and the 2 bolts are still inline with the spin point which shows that the
BLADES dont actually change angle.
The head does but I cant see where the blades change.
The_RattleSnake is offline Find More Posts by The_RattleSnake
Old Mar 09, 2012, 03:11 AM
minirotor's Avatar
QLD Australia
Joined Oct 2009
Look at the blades endon, and see what happens to the blade angle/pitch when you lift the blade up as it would when it cones up in flight and turning due to 'G' loads.
Better still, if you have a digital model heli pitch measuring meter, attach it on th end and see what happends as you raise the tip of the blade.
Old Mar 09, 2012, 05:38 AM
Scotland
Joined Jan 2010
HK Head
Got some spare heads and blades for future projects
Good news the heads were assembled correctly for anti clockwise rotation
Bad news still a problem with the flexi plate out of the packet one of the blade grips was ready to fall off
Old Mar 09, 2012, 07:03 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
Joe
I have a couple of heads in transit from Honkers at the moment for upcoming projects,but I would not bother using the flexing plate. Tupperwear is the way to go...........
Chris..........
Old Mar 10, 2012, 02:39 AM
Scotland
Joined Jan 2010
Originally Posted by britinoz View Post
Joe
Chris..........
Chris totally agree getting some new ones made on my friends cnc router as well as an anti tail strike plate that will limit the down flex on heavy landings
Joe
Old Mar 12, 2012, 07:25 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
Just received a couple of heads in the post.I can understand why some people can find the direction hard to follow,as I got one of each............
The one on the RIGHT is the correct one to use on this model................
Happy Landings
Chris............
Old Mar 13, 2012, 09:31 AM
Scotland
Joined Jan 2010
My friend Geoff sent me the CNC cut test pieces for the head today fitted perfect
I need to fit them to a model and get out there and test them
Joe
Old Mar 13, 2012, 10:17 AM
sailr is offline
Find More Posts by sailr
Land O' Lakes, FL
Joined Aug 2003
Those wind generators are some big obstacles at your flying field! Wow!
sailr is offline Find More Posts by sailr
Old Mar 13, 2012, 10:21 AM
Scotland
Joined Jan 2010
A lot further away than they look outside of the flying area no problem
Joe
Question Canister mufflers from China WinginIt Giant Scale Airplanes 5 Nov 01, 2010 02:53 PM
Gallery More pics from the Gaelic heart of Nova Scotia Bolter Aerial Photography 15 Aug 28, 2010 03:33 PM
Discussion Buying discount merchandise from china? sea20 Batteries and Chargers 26 Aug 13, 2010 10:07 AM
Discussion Advice: Shipping from China Dan203 Micro Helis 2 Jul 25, 2010 02:58 AM
