Old Nov 17, 2011, 07:30 AM
TURBOOMNI is offline
Find More Posts by TURBOOMNI
Trailer Down By The River
Joined Sep 2004
I ordered a spare head so I had a clean template for a flexplate or flapping hinge. I use polycorbonate for it now.
TURBOOMNI is offline Find More Posts by TURBOOMNI
Old Nov 19, 2011, 05:27 PM
minirotor is online now
Find More Posts by minirotor
minirotor's Avatar
QLD Australia
Joined Oct 2009
Finally some videos of my HK C30 gyro
See here;
http://www.rcgroups.com/forums/showt...3#post19919315
About a 5-10kt headwind[good 10kts+ up higher]
The low battery flight was because I had a brain fade and used a 2cell battery instead of a 3cell 850mAh nano techs.
I get about 5-6mins on the 3cell 850mah.
All flights are with the 5'' blade extensions on each blade.
It now weights apx 850g, ready to fly.[bit heavy but goes well--making longer and wider blades soon]
I find 1.5mm fibreglass makes a good durable flex plate for the head[fibreglass boat building and repair shops usually have bits spare.
Some people are using fibreglass ciruit board type things.
minirotor is online now Find More Posts by minirotor
Old Dec 22, 2011, 10:56 AM
Joined Sep 2004
I finally saw you first vid,,,Nice work!!
Old Jan 02, 2012, 05:34 AM
minirotor's Avatar
QLD Australia
Joined Oct 2009
Finially the new wider blades
Well as mentioned a long while back, I was making a new set of wider blades for my HobbyKing C30.
Well they are finially formed/balanced/covered and fitted.
Now just need some good weather[its wet summer here] and short grass field to do some test hops first, and then hopefully some circuits.
Actually the origional HobbyKing blades with my 5" extensions looked more realistic, but hopefully these blades will allow it to fly nice and slow in calm air.
The whole Gyro now weights 920g RTF.
Regards, M
Old Jan 02, 2012, 08:41 AM
ask21! is offline
Find More Posts by ask21!
Be here now!
ask21!'s Avatar
Rome,Ciampino
Regards, M
Had a bad experience with my homebuilt blades on my cierva.
They where long the same but wider.
When reaching high side of spin-up, they used to "flutter" and slow down very quickly...
So I returned to the original ones.
ask21! is offline Find More Posts by ask21!
Old Jan 02, 2012, 11:43 AM
Joined Sep 2004
Are you using the stock flapper hinge that came with the rotor head? Could be it is just too flexable. I use clear polycarbonate and while still flexible it is abit stiffer than stock. May I ask did you put the mounting hole for the blades at the cord CG point on all 3 blades and some lead weight at the leading edge of each blade near the tip??
Old Jan 02, 2012, 01:04 PM
ask21! is offline
Be here now!
ask21!'s Avatar
Rome,Ciampino
I'm usin hinge like yours.
About the hole location, I believe you are right. That was an old set of rotor blad, and I just mounted them and went out to fly.
I have to check the CG and Hole position. I'm 90% sure that's the problem
Thanks!
Old Jan 04, 2012, 10:40 PM
Joined Sep 2004
Let us know if that was your problem,,,I would like to know as if it is or not we will gain a litltle more knowlege.
Thanks!!
Old Jan 06, 2012, 09:05 AM
Jockadopolus is online now
Find More Posts by Jockadopolus
Jockadopolus's Avatar
Scotland
Joined Jan 2010
At last had my second flight today I need to re balance the blades there was some vibration and move the CG forward a little but other than that it flew well
Joe
HK C30.wmv (1 min 51 sec)
Jockadopolus is online now Find More Posts by Jockadopolus
Old Jan 06, 2012, 11:57 AM
ask21! is offline
Be here now!
ask21!'s Avatar
Rome,Ciampino
Thanks!!
I add a little weight to the tip(the blade were made of the lightest balsa) and relocate the hole.
It seems to be ok now. No difference with the old blade
Old Jan 06, 2012, 09:50 PM
minirotor's Avatar
QLD Australia
Joined Oct 2009
Jackadopolus--great takeoff and landing.
I've never been game to do a hand launch[I carn't get to the sticks quick enough]
ash21--good to see the blades are working now.
Interesting question about the c of g, lengthwise and crosswise, in relation to the bolt holes.
The origional HK blades that came with the C30 are apx balanced at 50% lengthwise.
And 40% crosswise from the leading adge[LE]
However the bolt holes are apx 30% from the leading eadge[this also happens to be the thickest section of the blades as well]
So they have the c of g apx 10% behind the bolt holes.
Does anybody know what are the figures apx for Aerobalsa blades?
or any comments about this matter?
Regards, M
Old Jan 06, 2012, 10:01 PM
Joined Sep 2004
Great flight Jackadopolus!! That was much better than the last video I saw of yours,,,well done! As far as making blades goes I have only made a total of 4 blades on my HK cierva.
One was damaged in a minor crash. I used the plans for the Spiro blades and either from the Spiro plans or that very good 2 part video on making autogyro blades was instructed to balance cordwise and then make the blade mounting hole on the that CG.The blades have worked perfectly though.
Old Jan 07, 2012, 02:28 AM
Scotland
Joined Jan 2010
My local flying sites are waterlogged so hand launch is the only way to get a flight with the risk of tail strikes when you land
I hope to visit another site today weather permitting they have a tarmac runway
Re-balanced the rotor also had a bent motor shaft
Will post video of any flights
Joe (Jockadopolus)
Old Jan 07, 2012, 03:55 AM
minirotor's Avatar
QLD Australia
Joined Oct 2009
Well, tried my new wider/longer blades on the HK C30 today.
Did a few hops.
The grass is really too long here at the moment to easily get a good easy run up.
It appears to fly really nice and slow[which is what I really was aiming for]
An interesting finding was that as the blades had a lot more lift than anything I've used previously, I had to move the C of G foreward quite a bit to get it to fly level without full foreward stick.
Hopefully a circuit and a video new week.
Regards, M
Old Jan 07, 2012, 11:18 PM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
If you were only using the stock blades on you previouse flights ,then you will find that they were only 4.7 mm thick ( to thin ) compared to the 6 mm ( I presume) ones you have made.
Chris.....
britinoz is offline Find More Posts by britinoz
Question Canister mufflers from China WinginIt Giant Scale Airplanes 5 Nov 01, 2010 02:53 PM
Gallery More pics from the Gaelic heart of Nova Scotia Bolter Aerial Photography 15 Aug 28, 2010 03:33 PM
Discussion Buying discount merchandise from china? sea20 Batteries and Chargers 26 Aug 13, 2010 10:07 AM
Discussion Advice: Shipping from China Dan203 Micro Helis 2 Jul 25, 2010 02:58 AM
