Old Oct 23, 2010, 09:02 PM
William Gomes is offline
Find More Posts by William Gomes
Brazil
Joined Feb 2007
Blades conning solution !
Mine arrive today , very well package but without instructions and there are many,,,many small parts to fit.
I love the rotor head and think HK should sell the rotor blades and rotor head as a spare part they will make a nice money , there are a lot of scratch builders and these parts are very dificult to find (buy). The head dont alow the blades to conning very well , so I think a small sand in the blade suport to produce a very small gap between the blade suport and rotor head could make all diference and solve this problem. You can sand a bevel in the upper part . I try and I think will work ,,, someone whith more expertise here ??
The servo suport looks a bit small to fit a metal gear servo.
And I sugest some more glue in firewall and rotor post.
The dummy engine is very well made could be a nice spare to be sold to.
After solve these problems If the giro flys as they say it will be a winner.
William Gomes is offline Find More Posts by William Gomes
Old Oct 23, 2010, 09:51 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I received mine a couple of days ago. it all arrived AOK and no damage. I have been studying it some before I put it together. I have some motors on order too, so I am waiting on them to arrive.
Do you think we ought to glue some carbon fibre strips along the main mast post or not. Is it strong enough?
One thought is if it really needs more coning angle or not. I am not a autogyro expert by any means but in thinking about it, the ailerons or left and right cyclic become more effective with less dihedral or coning angle in the rotor blades. The 3D heli's have super stiff blades and rotor heads to eliminate any coning angles completely or reduce them to really small amounts. If you had a lot of coning angle (dihedral) in the rotor head and blades then you tend to need the rudder to compendate for the turns as the ailerons or left and right cyclic would be weak or ineffective. of course maybe that doesn't apply to autogyros. So I don't know.
earlwb is offline Find More Posts by earlwb
Old Oct 24, 2010, 05:17 AM
JochenK is offline
Find More Posts by JochenK
JochenK's Avatar
Joined Jan 2005
William, Earl,
it's simple: keep coning down to a minimum.
Jochen
JochenK is offline Find More Posts by JochenK
Old Oct 24, 2010, 05:49 AM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Extra coning will only bring on unwanted trim changes, but once trimmed will be fine if its not too great.
It adds no extra stability other than making the mass of the fuselage further away from the blades. The longer the mast the more stable it will feel but the less effective the roll control is.
The flatter the disc the less roll trim you will need to add which makes ROG far easier to do.
Well that is what I have found.
Here is a video that I made a few years back
Pusher Gyro cone testing (6 min 39 sec)
Regards Rich
SafeLandings is offline Find More Posts by SafeLandings
Old Oct 24, 2010, 06:08 AM
The_RattleSnake is offline
Find More Posts by The_RattleSnake
The_RattleSnake's Avatar
Joined Jul 2007
I put together a tutorial on how to take off with this gyro:
First takeoff attempt RC Gyrocopter Crash (0 min 22 sec)
The_RattleSnake is offline Find More Posts by The_RattleSnake
Old Oct 24, 2010, 07:46 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
rattlesnake, where is the tutorial? Bummer on the crash though.
SafeLandings, Thanks for the excellent video and experiment.
I was reading in post #26 about coning in the sticky thread at the top of the autogyro category:
http://www.rcgroups.com/forums/showt...=614030&page=2
So technically we don't really want a lot of coning angles, very little is probably better. The more coning angle you have then the more the plane wants to roll to the left. Thus you need more right trim to compensate.
Thanks everyone.
Old Oct 24, 2010, 08:50 AM
Joined Dec 2007
Yes,
But due to the nature of a rotor disc there will always be some form of cone. But if you have a model of the PCA-2 or the like I just dont think it would look scale without cone and in these cases trimming would be needed.I have got my C30 kit out and had a look at the head and blades, with mine there is very little flap up but I think there is enough. The blades are very flexible to what I have used before.
As Chris has stated the blades are very thin compared to others, I think I will assemble mine on to the rotor hub and take them up to the field this afternoon. I'm interested to see what kind of lift I will get as Chris's seemed not to provide the lift he expected.
Regards Rich
Update:
I have been up to the field this afternoon and held the mast assembly along with the blades fitted into the brisk cold wind. Mine spin up quick and I have plenty of pull but I have either an out of balance rotor system or a tracking problem.
Old Oct 24, 2010, 01:20 PM
jet A is offline
Find More Posts by jet A
Spain
Joined Mar 2009
Helo every one.
This are pictures of my C30, I have already finished it. Im waiting for next weekend to maiden it.
Im worried about the power plant, I had about 750 gr of thrust with a 10x5 propeller Im not sure is enought power for a TOW of 670 gr.
I try to use finally a 1000 mAh 3s, in order to save weight.
Regards
jet A is offline Find More Posts by jet A
Old Oct 24, 2010, 06:57 PM
pcphill is offline
Find More Posts by pcphill
Plain Broke and Broke Planes!
pcphill's Avatar
Hoschton, GA
Joined Jul 2003
I have a an autogyro rookie question: Do you want the pushrod on the head to go up on the appropriate side for roll axis? IE right servo up, left down for for a right turn, or the opposite? I can't find a thread that mentions the correct direction of travel...
Thanks!
pcphill is offline Find More Posts by pcphill
Old Oct 24, 2010, 09:21 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I was wondering as to what motor, propeller and battery pack size you are using in these autogyros? I wanted to get a feel for what you all are using.
Old Oct 24, 2010, 09:27 PM
Boneswamped is offline
Find More Posts by Boneswamped
RC Group therapist
Boneswamped's Avatar
DeRidder LA.
Joined Nov 2008
Thanks!
When looking at the model from behind; Right roll(aileron) will cause the disc to tilt to the right when set up properly. Jut opposite of what you posted.
Good luck.
Boneswamped is offline Find More Posts by Boneswamped
Old Oct 25, 2010, 12:01 AM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
Flying the c30
Good news or bad news .I cant work it out.
Thanks Rich for the test.Glad that your set I works.I must just be out of luck ,because the set up does not work for me. I removed the top plastic rail that holds the top bolt assembly,and replaced it with hardwood and mounted a ball raced spindle assembly [as in Spyro].I then used a set of blades[as in Minimum] and test flew this machine OK. the assembly spun OK and generated lift OK. I could not get these results with the supplied parts. I TRIED.I had a friend take some pictures of the launch but for some reason ,not one of them came out.On the first flight I damaged one rotor blade and on the second flight I damaged the rudder. The Fuz is quit strong and should take a bit of rough play.
The model climed rapidly on take off and required a reduction in power followed by a reduction in back trim. Around 4 deg back trim should be OK 6 DEG down thrust is required on the motor.I hope to fly again tomorrow and will advise on my findings.
Hobby King advise that this model fly as easy as a CUB.This is true,but only after it has been trimmed,and that may be a problem for those with out experience.good luck
Chris..........
britinoz is offline Find More Posts by britinoz
Old Oct 25, 2010, 07:02 AM
pcphill is offline
pcphill's Avatar
Hoschton, GA
Joined Jul 2003
Thanks!
Good luck.
Old Oct 25, 2010, 09:58 AM
Joined Jul 2007
Im using this motor: TR 28-30B 14A 1050Kv Brushless Outrunner
This Prop: 3 Blade EP Propeller 8x6 / 204x178mm
I found that I could fit my 2200mah 3slipo in before I set everything up but once the motor was installed, the shaft protruding towards the back stopped it. 1800mah 3s lipo's will JUST fit, I recommend 1600mah 3s.
Old Oct 25, 2010, 10:00 AM
Joined Jul 2007
Thanks everyone.
My vid was the tutorial, it was a joke that didnt work
Question Canister mufflers from China WinginIt Giant Scale Airplanes 5 Nov 01, 2010 02:53 PM
Gallery More pics from the Gaelic heart of Nova Scotia Bolter Aerial Photography 15 Aug 28, 2010 03:33 PM
Discussion Buying discount merchandise from china? sea20 Batteries and Chargers 26 Aug 13, 2010 10:07 AM
Discussion Advice: Shipping from China Dan203 Micro Helis 2 Jul 25, 2010 02:58 AM
