Old Oct 11, 2010, 03:47 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
FYI, if anyone is interested, the auto-Gyro is back in stock at Hobby City, they had more than 10 of them at the moment I looked.
earlwb is offline Find More Posts by earlwb
Old Oct 12, 2010, 04:35 AM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
G'Day folks
Now for the good news, I have one on the way so pretty soon I hope to give you the word,although ARF is a not the way I do things ,but for that price .Most ARF's that I have come across usually look OK from the outside and tend to be poorly constructed,Lets hope this is not the case.
EMS from Honkers to OZ is usually about 4 days,so I will keep you up to date.
Happy Landings
Chris......
britinoz is offline Find More Posts by britinoz
Old Oct 12, 2010, 11:21 AM
jodini is offline
Find More Posts by jodini
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
We'll be watching Chris!
jodini is offline Find More Posts by jodini
Old Oct 12, 2010, 08:44 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Well those went quick, only one left at this very moment at Hobby City. I pulled the trigger and bought one too. But that was before I mentioned they had them in stock.
But it takes about three weeks or so to get them from Hong Kong into the USA. So I am sure a bunch of you will be flying them before I do.
Old Oct 13, 2010, 05:34 PM
Texasredrider is offline
Find More Posts by Texasredrider
Mines faster than your's
Texasredrider's Avatar
USA, TX, Houston
Joined Jan 2007
Well guys, I received my kit today. Lots and lots of different pieces. Looks like pretty good quality. Only thing is, I received no instructions. Too many pieces to try to figure it out. Hopefully HK will post the manual so I can start the build, otherwise it will stay in the box...
Texasredrider is offline Find More Posts by Texasredrider
Old Oct 13, 2010, 09:01 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Oh Boy, no instructions. This is going to be challenging once again for a RC plane.
Old Oct 14, 2010, 04:09 AM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
Take it easy guys .I should be receiving mine in the next few days.and hopefully should be able to give some advise.I am sure it is not that complex.It just helps to know the angle of the dangle.
Happy Landings
Chris........
Old Oct 14, 2010, 04:42 AM
MaxYmus2010 is offline
Find More Posts by MaxYmus2010
Australia, NSW, Wanaaring
Joined Apr 2010
man!, this is the third time I try to buy one and they are on BK, bummer.
I don't care if it comes without instructions
I think amongst some guys expertise here, these could be assembled just fine.
MaxYmus2010 is offline Find More Posts by MaxYmus2010
Old Oct 14, 2010, 08:10 AM
The_RattleSnake is offline
Find More Posts by The_RattleSnake
The_RattleSnake's Avatar
Joined Jul 2007
Woke up one morning and decided to check the stock status ( was on backorde rlast i looked).
And there were 16 in stock!
Count me in as another person that has ordered one! Should be here tomorrow.
One question, how is the steering setup?I read a comment on HK that said it was vtail mix for the rotor , then the rudder, is this correct?
The_RattleSnake is offline Find More Posts by The_RattleSnake
Old Oct 14, 2010, 12:17 PM
Talajouy is offline
Find More Posts by Talajouy
Australia, QLD, Gold Coast
Joined Aug 2007
I received mine this Monday and put it together, its a nice built model and very easy to install, now its ready to fly but I don't know the CG!!?
I will give it a try in next few days, This is my first auto gyro.
Any one can help and suggest the CG??
Talajouy is offline Find More Posts by Talajouy
Old Oct 14, 2010, 04:11 PM
USA, TX, Houston
Joined Jan 2007
Dont know about the CG, but I sure could use some advise on putting this together. Jason at HK said that they didnt have the resources to print a manual and since this is a Hobby King made kit, they probably won't. I hope someone will do a video set up or something.
On a side note, it says that Talajouy is 9297 miles away from me. Never seen that high a number from any of the guys in other threads. Just thought that was cool...
Old Oct 14, 2010, 04:41 PM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
I have a build cd with my kit (which looks the same) I will try and dig it out over the weekend and get the required info for you.
Rich
SafeLandings is offline Find More Posts by SafeLandings
Old Oct 15, 2010, 02:36 PM
Gaz-b is offline
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Just received one of these today seems to be very good for the money A couple of things to ask the more experienced people the motor has 0 thrust angle ? and I have no idear what angle the disc should lean back at for level flight A ball park figure would be great if I am within trim adjustment for the maiden would be nice.
Thanks Gary
Gaz-b is offline Find More Posts by Gaz-b
Old Oct 15, 2010, 08:53 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
G Day Gaz
This is going to be a little different to a Heli to fly.
With most of my Autogyros the Motor has about 6 deg down thrust.The disc will have 4-6 deg back tilt with 2-3 deg left tilt.These are ball park angles and I would not suggest that you apply them as they MAY NOT BE SUITABLE FOR THIS MODEL.The other critical point is the [CG] Hang Angle.This is considerably greater than that of Fixed wing models.
Remember Patience is a Virgin or is that a Virtue ,[I never get that one correct]
I am sure the correct info will appear in the next few days
Happy Landings
Chris.........
Old Oct 15, 2010, 09:33 PM
USA, TX, Houston
Joined Jan 2007
http://www.autogyro.com/technic/specs.htm
I just found this which I think will help folks alot in understanding autogyro setups
Question Canister mufflers from China WinginIt Giant Scale Airplanes 5 Nov 01, 2010 02:53 PM
Gallery More pics from the Gaelic heart of Nova Scotia Bolter Aerial Photography 15 Aug 28, 2010 03:33 PM
Discussion Buying discount merchandise from china? sea20 Batteries and Chargers 26 Aug 13, 2010 10:07 AM
Discussion Advice: Shipping from China Dan203 Micro Helis 2 Jul 25, 2010 02:58 AM
