Old Dec 03, 2010, 06:03 AM
JochenK is offline
Find More Posts by JochenK
JochenK's Avatar
Joined Jan 2005
Luca,
on my Minimum I used plastic screws and small brass tubes glued flush into the mounting holes in the blades. Those brass tubes allow the plastic screws to shear cleanly without ripping the wood of the blades.
Jochen
JochenK is offline Find More Posts by JochenK
Old Dec 03, 2010, 06:56 AM
XavierM is offline
Find More Posts by XavierM
XavierM
Joined May 2010
Congratulations everyone !
XavierM is offline Find More Posts by XavierM
Old Dec 04, 2010, 10:10 AM
angelfood is offline
Find More Posts by angelfood
Joined Sep 2009
Looks like I might be able to use old health insurance cards to make the new plastic connectors for my blades-ironic, that.
angelfood is offline Find More Posts by angelfood
Reply With Quote  (Disabled)
Old Dec 04, 2010, 10:50 AM
Lucam is offline
Find More Posts by Lucam
Fuzzy user
Lucam's Avatar
Italy, Lombardy, Griante
Joined Oct 2003
Originally Posted by JochenK View Post
Luca,
Jochen
Great idea!
Lucam is offline Find More Posts by Lucam
Old Dec 04, 2010, 11:05 AM
Joined Sep 2009
So, as there are no threads inside the tubes, do the screws act more like pins?
Old Dec 04, 2010, 01:42 PM
XavierM is offline
XavierM
Joined May 2010
Better with a 1800 mAh battery !
Cierva 30 autogyro Hobby King (4 min 54 sec)
Old Dec 04, 2010, 04:17 PM
JochenK is offline
JochenK's Avatar
Joined Jan 2005
Angel,
there's a nut at the bottom of the blade. Yes. those screws just keep the blade from moving around.
Jochen
Old Dec 04, 2010, 06:41 PM
odonata is offline
Find More Posts by odonata
Anything that flies
odonata's Avatar
Canberra, Australia
Joined Jan 2005
Originally Posted by XavierM View Post
Your Cierva flies beautifully!
Did the 1800 mah battery affect the C of G much-did you have to change anything else?I am taking your advice and getting a Rotoshape to learn with.
odonata is offline Find More Posts by odonata
Old Dec 04, 2010, 07:18 PM
Lucam is offline
Fuzzy user
Lucam's Avatar
Joined Oct 2003
really Great!
mine is almost ready for maiden. I just need some finishing and wait for a nice day
I've soldered the landing gear wires, I was sure the stock joint, just a bit of shrink tube, won't survive first takeoff run; so I soldered with the help of some copper wire. I used a 80 W soldering iron to do the job.
I'll go with a 1550 Rhino 2S pack and a 900 KV engine spinning a 10x7 prop; I belive I need more thrust than airspeed, but in case I can switch to a 3S 1550 pack and a 9x6 prop; let's see
Unfortunately I'm in my holydays home right now, and there I have not a scale, so I don't know how much its weights.
Old Dec 05, 2010, 12:34 PM
XavierM is offline
XavierM
Joined May 2010
Please check throws, CG and hub (see post 202) before flight !
XavierM is offline
XavierM
Joined May 2010
Odonata,
the 1800 mAh 3 S (+160 grams) battery provides more power than the first one I tried (1550 mAh), longer flights (6/7 minutes). And it gives a better CG (heavier nose) too, the other was a little light (140 grams) in my opinion.
The Rotorshape flies great, the Cierva too but it's heavier. That's why I began with a light simple model !
Rotorshape Style Autogyro (3 min 4 sec)
Good flights !
Old Dec 05, 2010, 02:52 PM
Lucam is offline
Fuzzy user
Lucam's Avatar
Joined Oct 2003
Yeah my CG looks right even with 2S 1550 Rhino; may be because my tail is light due to pull -pull cabling and ultralight tail wheel. and rotor is checked and 90 deg with mast, pic does not mater, is in a random position
Old Dec 06, 2010, 04:07 AM
con244 is online now
Find More Posts by con244
con244's Avatar
Australia, SA, Clarence Park
Joined Apr 2008
The Real Deal
Hi guys have just finished reading this thread and found it very interesting. You might be interested in this:
[url]http://www.powerhousemuseum.com/collection/database/?irn=211799
I saw this autogyro recently when I visited the Powerhouse Museum in Sydney Australia. I couldn't get real close as they had it and several other planes hanging from their ceiling, but it was certainly a real eye catcher.
Cheers
Con
con244 is online now Find More Posts by con244
Old Dec 06, 2010, 05:42 AM
minirotor is online now
Find More Posts by minirotor
minirotor's Avatar
QLD Australia
Joined Oct 2009
The Rotorshape company also make a C30 and a Benson type
2 blade Gyro[LA500];
http://www.laheli.com/web/article.php?kid=10
Interesting to see their C30 design.
It's much lighter, with much longer rotors.
Re;
http://www.powerhousemuseum.com/coll...se/?irn=211799
If you look closely at the windscreen of the back seat, you will see a 'OverHead Control Stick' going up to the head.
This was their early control system[no joystick-simular controls to a hanglider]
And a 'pre-rotator' drive sharft in front of the front windscreen, going up to the head from the motor.
minirotor is online now Find More Posts by minirotor
Old Dec 06, 2010, 06:02 AM
Lucam is offline
Fuzzy user
Lucam's Avatar
Joined Oct 2003
Cheers
Con
This is the Cierva 30 preserved in Museo della Scienza e della Tecnica here in Milan, Italy.
Question Canister mufflers from China WinginIt Giant Scale Airplanes 5 Nov 01, 2010 03:53 PM
Gallery More pics from the Gaelic heart of Nova Scotia Bolter Aerial Photography 15 Aug 28, 2010 04:33 PM
Discussion Buying discount merchandise from china? sea20 Batteries and Chargers 26 Aug 13, 2010 11:07 AM
Discussion Advice: Shipping from China Dan203 Micro Helis 2 Jul 25, 2010 03:58 AM
