Espritmodel.com Heli Air
Old Nov 28, 2010, 01:07 AM
Boneswamped's Avatar
DeRidder LA.
Joined Nov 2008
This one looks a bit more Robust than the foamie from LA Heli. My LA Heli is stock except I added rudder. Which one of you guys will loop the version in this thread first?
I just may have to get one of these.
C.30 LOOP! (trimmed) (1 min 31 sec)
-Mike
Boneswamped is offline Find More Posts by Boneswamped
Old Nov 28, 2010, 02:03 PM
Joined Sep 2009
Taxi, test, today, successfully completed. I'm scared of this thing!
angelfood is offline Find More Posts by angelfood
Reply With Quote  (Disabled)
Old Nov 28, 2010, 02:04 PM
Joined Sep 2009
http://www.youtube.com/watch?v=mBQ7C...eature=related
-Mike
The pines of Louisiana!
Old Nov 28, 2010, 06:58 PM
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
G'Day Mike
I must admit that I have looped my C-30 a couple of times, [but that was during the first trimming flights,so I don't know if that counts.]:
Chris............
britinoz is offline Find More Posts by britinoz
Old Nov 29, 2010, 06:48 PM
Fuzzy user
Lucam's Avatar
Italy, Lombardy, Griante
Joined Oct 2003
just a few building shot.
Front landing gear, nothing to say; just screw in place the A and B wood plate, and trim as needed strut holes;
Notice that all wires are joint together simply with a bit of shrinking tube, and this solution WON'T survive first landing, in my opinion, so I need to think something stronger; maybe soldering, IF these wire could be soldered, let's see further;
I don't want so much tail weight, and I don't like stock wheels, so I changed with more scale-like front wheels and usewd a really lightweight rear wheel.
Lucam is offline Find More Posts by Lucam
Old Nov 29, 2010, 07:05 PM
Fuzzy user
Lucam's Avatar
Joined Oct 2003
In order to keep as light as possible the tail section, I replaced the original, heavy linkage with a much lighter Pull-Pull solution.
For rudder, I used a digital HS 55 servo. Wire is a metal fishing wire covered with plastic; the great is that you can heat it with a lighter for secure your knot.
I don't know which kind of wire it is, or which kind of fish is supposed to be used for, but I'm sure your local fishing shop can help you
Old Nov 29, 2010, 08:57 PM
Manila Ninoy Intl, Philippines
Joined Nov 2001
@lucam
Very nice rudder set up.
Is your tail wheel going to be steerable?
How did you link it to the rudder?
deadduck is offline Find More Posts by deadduck
Old Nov 29, 2010, 09:00 PM
Joined Sep 2009
Duck,
Just use a smaller gauge control rod and go with the existing tube and lever: you'll be happy with the result, your tailwheel will track the rudder perfectly and you will have a more pleasing (aesthetically)(an opinion) setup.
Mine works just fine with the 2mm gauge rod provided, if you make appropriate bends in both ends to relieve tension!
Old Nov 29, 2010, 09:01 PM
Joined Sep 2009
I do wish I'd trusted my instincts on that little notch in the horizontal stab, but mine came out just fine arse backwards.
The stab is either symetrical or so close it won't likely matter.
Old Nov 29, 2010, 09:22 PM
Joined Nov 2001
Angelfood,
I'm using a slightly different set up for rudder pushrods.
In retrospect I think the picture posted on the Cierva page for the tailwheel / rudder arm and in the build hints should be reversed (upside down).
This will bring the holes of the EZ connectors closer to the thrustline of the rudder pushrod.
Unfortunately, I glued the tailwheel strut into the arm before I realised this.
Old Nov 29, 2010, 09:25 PM
Joined Sep 2009
Fortunately, there are many means of acheiving the same result-my rudder setup looks pretty much as above.
Old Nov 30, 2010, 01:27 AM
Fuzzy user
Lucam's Avatar
Joined Oct 2003
Originally Posted by deadduck View Post
@lucam
No, I want a ligt setup, so I don't care about a steerable tail wheel: I go simple and straight
Old Nov 30, 2010, 09:06 PM
Joined Nov 2001
Ventral Fin
Is there a slot under the covering for the Ventral fin (the one below the fuselage)?
Or does it just glue on to the keel?
Old Nov 30, 2010, 09:10 PM
Joined Sep 2009
The slot is there: I used a soldering iron to open it up.
Old Dec 01, 2010, 01:31 AM
Joined Nov 2001
Thanks! couldn't tell by just feeling it.
Slowly getting it done.
An ok kit to build.
Question Canister mufflers from China WinginIt Giant Scale Airplanes 5 Nov 01, 2010 02:53 PM
Gallery More pics from the Gaelic heart of Nova Scotia Bolter Aerial Photography 15 Aug 28, 2010 03:33 PM
Discussion Buying discount merchandise from china? sea20 Batteries and Chargers 26 Aug 13, 2010 10:07 AM
Discussion Advice: Shipping from China Dan203 Micro Helis 2 Jul 25, 2010 02:58 AM
