Old Nov 24, 2010, 04:09 PM
Lucam is offline
Find More Posts by Lucam
Fuzzy user
Lucam's Avatar
Italy, Lombardy, Griante
Joined Oct 2003
Just arrived mine!
LOL, I love balsa planes, and I love gyrocopter
Unfortunately, my model came without any instructions, so I hope it isn't too trick to build properly the rotor head and linkage.
I like it really much, it's so... so... RAW
The pieces in my lab
Lucam is offline Find More Posts by Lucam
Old Nov 24, 2010, 04:23 PM
angelfood is offline
Find More Posts by angelfood
Joined Sep 2009
All done but the power system: assembling this thing is as much fun as a beating in a dark alley by an ugly woman.
angelfood is offline Find More Posts by angelfood
Reply With Quote  (Disabled)
Old Nov 24, 2010, 09:53 PM
deadduck is offline
Find More Posts by deadduck
Manila Ninoy Intl, Philippines
Joined Nov 2001
Just got mine too. Finally.
Here is a pic of the head as received.
Looks upside down? (compared to Pics from #74)
deadduck is offline Find More Posts by deadduck
Old Nov 24, 2010, 11:29 PM
deadduck is offline
Joined Nov 2001
Weight data
Weighed all the bits
This is what mine came to:
Fuselage 162g
Head / Mast 81g
Landing Gear +m wheels 56g
Horizontal/ rudder/ struts 48g
Trim: Engine / Fairing 30g
Blades 53g
Engine mount/misc wood bits /Control parts/Hardware pack 46g
Total 476g
This is with items removed from plastic bags.
Quoted Flying weight in specs at Hobbyking is 600g, wildly optimistic.
Flipped the head screws over.
Old Nov 25, 2010, 06:58 AM
Lucam is offline
Fuzzy user
Lucam's Avatar
Joined Oct 2003
Never seen a manufacturer weight declaration less than wildly optimistic... or merely rubbish
Old Nov 25, 2010, 11:39 AM
Joined Sep 2009
Fuselage 162g
Head / Mast 81g
Blades 53g
Total 476g
Hi, Duck,
The instructions you provided, by link, were adequate, but tough for a layman at times.
If anyone has any questions, fell free to ask me, the least sophisticated builder!
Everything is complete with the exception of a motor, and once I've added that, I'll post a gross weight!
I used HXT 900's throughout.
I'm pretty scared of the maiden, and have read that elevator changes should be avoided whenever possible in favor of thrust.
Anyone have an opinion on "rudder-elevator" mixing as that's my setup for now?
Expo?
"Best" motor wattage?
Old Nov 25, 2010, 11:50 AM
Boneswamped is offline
Find More Posts by Boneswamped
RC Group therapist
Boneswamped's Avatar
DeRidder LA.
Joined Nov 2008
Hello,
I personally would not mix the rudder and elevator. Throttle is your primary UP/Down, while elevator is going to control speed. While some back elevator may be required in turns, it varies with the angle of bank,winds,airspeed ect. To set a mix that covers everything would be limiting I think. Some guys mix, and love it, I don't care for it. I prefer to keep the control inputs limited to what I intended. Rudder will turn you just fine to begin with, apply oppsite roll to keep he turns more level until you are comfortable with the flight envelope. Gyros can get exciting in steep turns.
Have no fear of the maiden. Take your time, don't over control, keep it close. Most of my gyros will recover and land hands off by simply reducing the throttle and leaving everything else alone.
Good luck with the maiden!
-Mike
Boneswamped is offline Find More Posts by Boneswamped
Old Nov 25, 2010, 11:52 AM
Joined Sep 2009
I'll take your advice-aren't you near BR?
How do I tell if the head is "neutral" in all axes before the first flight?
Many thanks
Old Nov 25, 2010, 12:03 PM
RC Group therapist
DeRidder LA.
Joined Nov 2008
I was just sharing my opinion, and wht has worked fo me, but there are many ways to skin a cat. I live west of BR by a couple hours. I' currently stuck in Florida supporting the swamp phase for the Army Rangers.
You arent looking for everything to be nuetral, you should have a bit of aft, and left tilt. Also make sure that full forward stick doesn't go more than a degree or two beyond level. The first flight is always a bit exciting becauseyou will have your hands full flying and trimming. When Possible I always do small hops and adjustments. Since you are hand launching you don't have that option. I would get help for the launch, and make sure the launch helper understands how to release the model. With practice, when you get over the feeling that it won't fly when you let it go, you'll toss it into the air without regard.
Good luck man, don't forget to get video!
Old Nov 25, 2010, 12:08 PM
Joined Sep 2009
Thanks for the tips-I'll be in BR for Christmas-father in law.
Have a great Thanksgiving.
Old Nov 25, 2010, 02:58 PM
JochenK is offline
Find More Posts by JochenK
JochenK's Avatar
Joined Jan 2005
Angel,
here's some advice for hand launching a Minimum pusher, but it's valid for other gyros too:
http://www.rcgroups.com/forums/showp...0&postcount=12
Jochen
JochenK is offline Find More Posts by JochenK
Old Nov 25, 2010, 03:15 PM
Lucam is offline
Fuzzy user
Lucam's Avatar
Joined Oct 2003
Originally Posted by angelfood View Post
Hi, Duck,
Expo?
I won't use elevtor, because for my previous scratchbuildt gyro (see pic) simply add thrust was the most effective way to climb, when rotor-up was great for decelerate and land; I'm not a gyrocopter expert, but I guess elevator is useful to change pich, and pitch is great for an airplane, but I'm unsure it's as good for gyrocopter.
Old Nov 27, 2010, 02:46 PM
deadduck is offline
Joined Nov 2001
I'm finding that when installing the horizontal stabilizer (1) there is a small block inside the fuse, at the leading edge, which results in a slight gap at the fuse and leading edge, when, (2) the "slot" is used to locate the trailing edge.
Is this right?
Why is that block inside the fuse?
angelfood, you probably know this already, but it might help someone just starting their build.
The horizontal stab has a notch at the leading edge, which is covered over.
It indexes to the little block.
Very tight fitting, I almost feel that it does not need glue. Will just put a little on edges once it's centered.
Old Nov 27, 2010, 02:54 PM
deadduck is offline
Joined Nov 2001
Relocating through bolt on mast / servo holder
I decided to use metal geared servos as advised.
I found that the through bolt head and nut fouled on the servo case with the TP MG90s servos that I want to use. Causing them to skew over.
I relocated the hole a little further away.
Servo now sits flat on servo holder.
I noticed that the holes burnt for the servo mounting screws were 2mm diameter so the normal servo mounting screws won't work. Used some of the supplied 2mm bolts.
Using a TP 9g (=HXT900) servo for the rudder / tailwheel.
Old Nov 27, 2010, 08:08 PM
Joined Sep 2009
Duck, the following is from the instructions you provided by link, and though I would have done as you did, I followed these (I doubt it matters):
Horizontal Stabilizer:
There is a pre-existing notch in the trailing edge under the covering. Locate it, expose it and align it with the notch in the rear of the fuselage. I test fitted it and traced along the fuselage onto the stab with an x-acto and then removed the covering in that area for gluing.
Question Canister mufflers from China WinginIt Giant Scale Airplanes 5 Nov 01, 2010 02:53 PM
Gallery More pics from the Gaelic heart of Nova Scotia Bolter Aerial Photography 15 Aug 28, 2010 03:33 PM
Discussion Buying discount merchandise from china? sea20 Batteries and Chargers 26 Aug 13, 2010 10:07 AM
Discussion Advice: Shipping from China Dan203 Micro Helis 2 Jul 25, 2010 02:58 AM
