Old Nov 22, 2010, 11:17 PM
flapaway is offline
Find More Posts by flapaway
United States, CA, Tustin
Joined Sep 2007
Originally Posted by AlanGyrohead View Post
Hello folks
I've got one and it was the first autogyro I flew successfully. I had a PT 15 for months and had lots of trouble. Now I know what I did wrong it's just fine, but if it wasn't for the Cierva I may have given up on gyros.
I crashed my Cierva many times, firstly due to hand launching without full power, then more crashes due to orientation problems. I never had to do more more than stick a few bits of foam back into place and put splints on the landing gear legs before it was ready to fly again. It flew fine with most of the landing gear smashed off and a chunk of tailplane missing.
It can hover in a breeze and it flew fine in conditions which grounded electric gliders.
I am well pleased with mine.
What motor and battery do you have in the Cierva?
flapaway is offline Find More Posts by flapaway
Old Nov 23, 2010, 12:09 PM
angelfood is offline
Find More Posts by angelfood
Joined Sep 2009
O.K., you guys have been of great help and I've reversed the head thingy, but not yet attached the blades (I'm afraid to!).
Now, what is this delta mix thing? If one servo goes to aileron and one to elevator, which one goes where? (from behind, does the right servo go into the aileron or elevator channel).
Thanks!
angelfood is offline Find More Posts by angelfood
Reply With Quote  (Disabled)
Old Nov 23, 2010, 12:56 PM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
I use elevon mix which I think is the same. Plug in your servos, one to the aileron socket the other to the elevator socket. Set your delta/elevon mix on your transmitter.
If your rotor disc moves the the right (looking from behind) when right aileron is applied on your stick then this is correct this is called 'roll'. The same on your elevator stick, apply up and your rotor should tilt backwards.
If this doesn't happen first try swapping over your servo leads into the receiver. If its still wrong you will need to reverse on or both of these controls. You may have to revert back to swapping your servo leads into the receiver.
Eventually you will get the right combination.
UP- rearward tilt/pitch (elevatator stick)
DOWN- forward tilt/pitch (Do not go more than a few degrees past zero degrees)
LEFT- Left tilt/roll (aileron stick)
RIGHT- right tilt/roll
Hope this is of help?..once you have done it you will see how easy it is.
SafeLandings is offline Find More Posts by SafeLandings
Old Nov 23, 2010, 01:27 PM
Joined Sep 2009
Thanks, Safe!
Any tips on how to drill the blade thingys to fit the head thingy? (It appears that each blade, closest to the "head," has a flat spot, right?)
Thanks, guys, for bearing with me as I hope to be an autogyro fan soon!
Old Nov 23, 2010, 02:19 PM
Joined Dec 2007
Surely they are pre drilled?
Old Nov 23, 2010, 02:34 PM
Joined Sep 2009
Nup-or, at least, mine aren't.
Per Hobby City: Okey, doakey, no more jokey, no more holes to pokey!
Old Nov 23, 2010, 03:55 PM
Joined Sep 2009
Works like a charm! Many, many thanks-now, to drill those blades....
Old Nov 23, 2010, 05:37 PM
Joined Sep 2009
Doh! Poked around the blade inner ends with a small screwdriver and found covering over two holes! I removed the fabric and mounted the blades. I'm close.
So, now, as I understand it, viewed from above, the blades turn counterclockwise, or the opposite of Mickey's little tail, right?
Do you give it a manual spin before running?
Old Nov 23, 2010, 08:52 PM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
If you go to #63 you will see the information I posted to help with the launch.If there is no wind then you will have to flip the blades ,but with a little wind the blades should spin OK and you will feel the model pulling on your arm.Not a heavy steep launch,more like a gentle horizontal push,with about 2/3 power. I have not had to run,as autoratation of the blades,can be reached at walking pace.make sure the model is level,not leaning left or right.Yes you are correct with the direction of the blades.
Happy Landings
Chris............
britinoz is offline Find More Posts by britinoz
Old Nov 23, 2010, 09:05 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
Flapaway
The report you highlighted was not about this model. Alangyrohead was talking about the LA heli C-30 model.
The motor I used in this kit is an Emax CF 2822 with a SF 9x4.7 prop and a 2250 ma 3cell pak This size lipo is far to large but ballast was required in the nose to get the hang angle correct.
Good Luck
Chris...........
Old Nov 24, 2010, 08:03 AM
Joined Sep 2009
O.K., does one "fly" this thing with the rudder, or is that only for ground use?
So far, I've mixed in 15% rudder with "elevator," and about 35% expo on all surfaces.
I hope to maiden with a week or so.
Thanks to all who have helped with this little puzzle!
Old Nov 24, 2010, 10:32 AM
owlsabie is online now
Find More Posts by owlsabie
owlsabie's Avatar
South Africa
Joined Feb 2009
Hey Angelfood - how about a pic? Good luck with the maiden
Owl
owlsabie is online now Find More Posts by owlsabie
Old Nov 24, 2010, 10:45 AM
Joined Sep 2009
Power system will be added, today: the paper in the cockpit is my "punch list" of items to finish or secure with loctite (old age!).
I choose to remove some cockpit material rather than bend the rotor pushrods as suggest by the kind fellow who posted some build instructions on the Hobby City web page.
Old Nov 24, 2010, 12:26 PM
owlsabie's Avatar
South Africa
Joined Feb 2009
Its looks stunning!
Old Nov 24, 2010, 12:29 PM
Joined Sep 2009
Thanks, but from your great distance, I suspect it's an optical illusion!
The thing scares my donkey just thinking of trying to fly it.
Question Canister mufflers from China WinginIt Giant Scale Airplanes 5 Nov 01, 2010 02:53 PM
Gallery More pics from the Gaelic heart of Nova Scotia Bolter Aerial Photography 15 Aug 28, 2010 03:33 PM
Discussion Buying discount merchandise from china? sea20 Batteries and Chargers 26 Aug 13, 2010 10:07 AM
Discussion Advice: Shipping from China Dan203 Micro Helis 2 Jul 25, 2010 02:58 AM
