Old Nov 22, 2010, 12:00 PM
Tinmar is offline
Find More Posts by Tinmar
Tinmar's Avatar
South Africa, GP, Nigel
Joined Sep 2009
Head for PT Profile
Okay, I hope this will make things a bit more clear on the head issue,
Regards,
Martin,
The head on the left is for blades that turn clockwise.
The head on the right is for blades that turn counter or anti clockwise.
Maybe somebody must just confirm that as well.
Tinmar is offline Find More Posts by Tinmar
Old Nov 22, 2010, 12:02 PM
Boneswamped is offline
Find More Posts by Boneswamped
RC Group therapist
Boneswamped's Avatar
DeRidder LA.
Joined Nov 2008
Ok guys, you're making this hub thing more complicated than it is. Here is the simple answer:
When you look at your hub from the top, and turn the hub counter-clockwise; the blade grips should appear to sweep forward toward the direction of rotation. If they are sweeping aft of the rotation(as in the picture of the replacement hub above) they are installed wrong.
This is a delta offset style hub and an incorrect sweep angle will prevent the model from flying.
Take another look at the picture in post #74, or #134 and pay attention to the difference in the angle of the blade grips(the white plastic part with the angle on the end). Remove your grips, flip them over, and re-install. Done deal guys.
Hope this helps,
-Mike
Boneswamped is offline Find More Posts by Boneswamped
Old Nov 22, 2010, 12:05 PM
RC Group therapist
DeRidder LA.
Joined Nov 2008
Regards,
Martin
In Martins pics (assuming a counter-clockwise rotating system), the pic on the left is wrong, and the pic on the right is correct. If your blades were set for clockwise rotation the left pic is correct, and the right pic is incorrect.
-Mike
Old Nov 22, 2010, 02:58 PM
Texasredrider is offline
Find More Posts by Texasredrider
Mines faster than your's
Texasredrider's Avatar
USA, TX, Houston
Joined Jan 2007
So does this model from HK turn clockwise or counter clockwise?
Texasredrider is offline Find More Posts by Texasredrider
Old Nov 22, 2010, 03:34 PM
RC Group therapist
DeRidder LA.
Joined Nov 2008
I do not own this kit. Not to talk down to you, but I'm not sure if you are asking how to determine rotation direction, or which rotation direction this particular kit has; To determine the direction a blade is set up for, lay the blade sideways in front of you with the leading edge away from you, and the trailing edge closest to you. If the hole is on the left....it is for counter-clockwise rotation/If the hole is on the right....it is for clockwise rotation. Again, not trying to condescend, just trying to help out.
Regards,
-Mike
Old Nov 22, 2010, 03:42 PM
angelfood is offline
Find More Posts by angelfood
Joined Sep 2009
Bubba, there ain't no holes (in the blades) and all this is as clear as mud!
angelfood is offline Find More Posts by angelfood
Reply With Quote  (Disabled)
Old Nov 22, 2010, 06:27 PM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
The blades on the HK C-30 turn in the counter clock direction when viewed from above.The picture on #125 shows the head '''''INCORRECTLY'''' assembled. Please study the pictures I posted on #74 carefully and you should be able to see what is correct.
The kit I received had the head assembled incorrect.
Chris..............
britinoz is offline Find More Posts by britinoz
Old Nov 22, 2010, 06:30 PM
Joined Sep 2009
Chris, we are getting there-why "one" hole on your blades rather than "two?"
The Hongy Kongy thingy is set up for two holes, right? (to attach the blade)--OOPS, just went back and looked-you have two-hole mounting.
I'm still puzzling over your photos-doh!
Old Nov 22, 2010, 06:38 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
OK picture #125 ,the plate is ''upside down''.If yours is like that turn it over and remount all the bolts the other way round.
Old Nov 22, 2010, 06:41 PM
Joined Sep 2009
Thanks!
I'm guessing the "plate" thingy is the top, blue part....
Looking at the first pic of the head in post 53, is that one "wrong?"
Old Nov 22, 2010, 06:54 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
#53 is Wrong #72 is CORRECT
and do as in #73
Old Nov 22, 2010, 06:57 PM
Joined Sep 2009
Here is mine, which I reckon is "wrong," right?
Old Nov 22, 2010, 06:58 PM
JochenK is offline
Find More Posts by JochenK
JochenK's Avatar
Joined Jan 2005
#53 is set up for cw operation, #72 is set uo for ccw opertation. The short side of the blade holder points in the direction the blade is turning.
Jochen
JochenK is offline Find More Posts by JochenK
Old Nov 22, 2010, 07:01 PM
Joined Sep 2009
Jochen
Can you use it "either" way, i.e., clockwise or counterclockswise?
Say, hang on, the guy in South Africa is in the Southern Hemisphere: does the coriolis effect matter?
Old Nov 22, 2010, 07:36 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
Yours is incorrect for this model As Jochen pointed out,it is set up for clockwise operation With the blades in the kit ,you require counter clockwise direction.''Flip it over''.
Chris......... South Australia........
Question Canister mufflers from China WinginIt Giant Scale Airplanes 5 Nov 01, 2010 02:53 PM
Gallery More pics from the Gaelic heart of Nova Scotia Bolter Aerial Photography 15 Aug 28, 2010 03:33 PM
Discussion Buying discount merchandise from china? sea20 Batteries and Chargers 26 Aug 13, 2010 10:07 AM
Discussion Advice: Shipping from China Dan203 Micro Helis 2 Jul 25, 2010 02:58 AM
