Joined Jun 2011
Keljuk,
I tested as you asked. I'm not sure how helpful it will be but here it is:
You can see that there are fluctuations in tail rotor RPM because the tail is vibrating left-right a bit. I also noticed that fluctuations vary depending on the main motor rpm. This said, this seems to be normal operation since this heli flies well and the fluctuations can not be observed during flight. Hope this helps. Regards, Chris |
I think the motor controller chips on the Rx are bad. This was a replacement Rx for another Rx with a suspected bad tail motor controller chip. I think there's a QC problem with RX-01 2010-7-27 Rx boards. |
MyRCMart has generously offered to take the Rx back for NE factory repair even though the time period for item returns and exchanges has expired. |
Joined Jun 2011
Well, if you want a small heli that is component based so that you do not have to replace the whole RX every time something goes wrong, I would recommend the WASP 100. They are affordable and they come with small servos, a stand alone receiver. I think they are pretty darn cool. I actually plan to buy one soon to add to my small fleet.
![]() I think it's better than the Solo Pro and Bravo SX. For one, you won't have to worry about flybar strikes with this little heli. Here's what it looks like under the hood:
Note that I'm recommending this bird because it's in the same price range as the NE helis of its size. There are really nice helis in the 100 size category made by other companies but you have to pay more for them. |
Wasp 100
http://www.rcgroups.com/forums/showt...1350697&page=2 |
Joined Jun 2011
The initial reports aren't that bad from where I look at it. Main thing is the bad brushed motor but it can easily be upgraded to BL. As for the plastic quality, this is only an issue if you crash it hard. I very rarely crash 4 channels helis anymore. Also, miraclemart stocks 90% of the parts and they are cheap. They sell the RTF WASP 100 for 50 bucks... The price is right, in my opinion. It's 20 bucks cheaper than the Bravo SX.
Regards, Chris |
