Latest blog entry: Estes Rubber Band Condor gets powered...
Latest blog entry: Vintage Kyosho Buggies, why I love 'em...
Now your blaming Canada ?
Come on now! |
do you guys think - that this fuse would fit the MSR? or could be made to fit?
![]() Other thing, can any of you BravoSX owners use subtrim for the tail? When I activate subtrim mode, on my heli the trim for the tail goes to zero on the display, but it also resets the tail to zero trim, so it will start spinning right away if you needed a few clicks. And what is worse, besides not being able to steer the tail in subtrim mode, the rudder trim button has no effect as well, so there is no way to get the tail to act right, except leaving subtrim mode, and trim it in normal mode. This would also mean you can't fly in subtrim mode to finetune aileron and elevator trim, since the heli will only stop spinning if your tail already held with rudder trim perfectly center. Well, I bet most helis will need a few clicks for that, and sometimes even different batteries need a different tail trim setting. I already asked Rick if he was aware of this issue, but was wondering if more had the same experience, that in subtrim mode you simply can't trim the tail at all any more. |
Hi,
But the other way round: Then the tail of the canopy of the Bravo SX it too long for at least the standard Solo Pro tail (do not know, if the MSR tail has the same length). Prolonging the tail boom should be possible, but maybe not that easy. Walter |
Received my replacement NE 150 battery from the German seller I got my white Bravo SX from. And this one is... 4.32g, like the ones Donaldsneffe received. Label is the same as the 4.70g NE 150s I got with my white and dark blue SX, but the weight is 0.4g less for the same capacity...
![]() Seems like there are different batches of these 150 mAh batteries are going 'round... |
Thanks, it was a cheap scale, but after we got the same reading for the HK150s as you, it couldn't have been a fault of the scale any more...
I'll ask Rick from ClubHeli if he also got mixed batches. He seems to be able to make contact with Nine Eagles, and even get a reply on his questions. ![]() Well, I'll go testing this new battery soon, hope it performs better than the heavier ones. |
anyone weight the SX fuse?
if so, how much in grams? |
